楼主: Mirukuteii
[插件集成] 【AsusWrt】自制路由器信息插件,支持华硕梅林,5月13日更新
发表于 2019-11-30 19:15:12 | 显示全部楼层
学习一下 我也想写插件
发表于 2020-1-1 13:56:41 | 显示全部楼层
我之前这四个都显示未知或者0
然后我根据ghostist提供的sensor.py在查询2.4G和5G列表后面加了这个
|sed 's/^/autho_sta_list /
就能用了
原以为照猫画虎的我就功德圆满了,说不定还能跟大伙儿说道说道,没想到啊,没得行。
在sensor中我也添加了
- bukemiaoshu
我的路由通过telnet可以执行查询命令
路由是K3的,刷的梅林,Ha版本是0.102.3
发表于 2020-3-11 17:59:32 | 显示全部楼层
这个感觉很好了,谢谢分享
发表于 2020-3-30 15:59:26 | 显示全部楼层
膜拜大佬
发表于 2020-4-4 16:08:24 | 显示全部楼层
请问大神这是什么原因?
asuswrt: Error on device update!
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 312, in _async_add_entity
    await entity.async_device_update(warning=False)
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 476, in async_device_update
    await self.hass.async_add_executor_job(self.update)
  File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run
  File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 240, in wrapper
    result = method(*args, **kwargs)
  File "/config/custom_components/asuswrt2/sensor.py", line 295, in _update
    self._state = get_data_dict(self._connection, _CMD_24GTXPWR, _REGEX_24GTXPWR).get(self._id)
  File "/config/custom_components/asuswrt2/sensor.py", line 514, in get_data_dict
    lines = connection.run_command(cmd_line)
  File "/config/custom_components/asuswrt2/sensor.py", line 386, in run_command
    from pexpect import pxssh, exceptions
  File "/usr/local/lib/python3.7/site-packages/pexpect/__init__.py", line 75, in <module>
    from .pty_spawn import spawn, spawnu
  File "/usr/local/lib/python3.7/site-packages/pexpect/pty_spawn.py", line 15, in <module>
    from .spawnbase import SpawnBase
  File "/usr/local/lib/python3.7/site-packages/pexpect/spawnbase.py", line 218
    def expect(self, pattern, timeout=-1, searchwindowsize=-1, async=False):
SyntaxError: invalid syntax
发表于 2020-4-4 21:10:59 来自手机 | 显示全部楼层
灰常稀饭!
发表于 2020-5-2 18:01:01 | 显示全部楼层
zeze247 发表于 2020-4-4 16:08
请问大神这是什么原因?
今天我也碰到这个问题,原因出在楼主这个插件指定的pexpect版本是4.0.1,但是python3.7已经不兼容4.0.1,解决办法就是升级pexpect到最新版(现在可以升到4.8),还有一点要注意,就是要把插件里面指定的版本去掉,不然重新后还是要重新更新回4.0.1
发表于 2020-5-2 18:04:56 | 显示全部楼层
详细的步骤是这样,如果你还没有安装插件,那么只要修改插件的”manifest.json“里面的"requirements": [
        "pexpect==4.0.1"
改成
"requirements": [
        "pexpect"
也就是把“==4.0.1”去掉,然后再拷贝到custom_components,再启动hass
如果你已经安装了插件,也就是hass里面已经安装了4.0.1版本了,那就手动更新一下
pip3 install -U pexpect
当然前面那个“manifest.json”还是要改。
zin
发表于 2020-11-26 21:01:57 | 显示全部楼层
是不是就是 现在官方的集成, 我设置外网ssh  key登录 python 半天登不上去  还耗费很多路由器资源 也是奇怪
发表于 2020-12-4 22:07:09 | 显示全部楼层
厉害厉害,好久没更新,不知道有没有开被迭代..
GMT+8, 2026-1-14 23:00 , Processed in 0.890133 second(s), 13 queries , MemCached On.
