查看: 9126|回复: 4
[技术探讨] command line switch为何总报command failed
发表于 2018-5-8 20:32:52 | 显示全部楼层 |阅读模式
我写了一个这样的配置
switch:
  - platform: command_line
    switches:
      remote_helper:
        command_on: "sudo systemctl start frpc"
        command_off: "sudo systemctl stop frpc"
        command_state: "sudo systemctl is-active frpc.service"
        value_template: '{{ value == "active" }}'
为何总报
Command failed: sudo systemctl is-active frpc.service
我的sudoer配置是不需要密码的,而且on和off执行都没有问题,就是在switch在off的状态下报这个error
wqqs 手机认证
活跃会员
发表于 2018-5-9 09:23:02 | 显示全部楼层
应该是权限问题, homeassistant用户不具备sudo的权限
 楼主| 发表于 2018-5-9 11:52:47 | 显示全部楼层
我已经加好和sudo 权限,使用homeassistan用户做相同命令的执行是没有问题的
 楼主| 发表于 2018-5-10 07:27:03 | 显示全部楼层
自问自答吧。先看看 command line switch的实现方法
    @staticmethod
    def _query_state_value(command):
        """Execute state command for return value."""
        _LOGGER.info("Running state command: %s", command)
        try:
            return_value = subprocess.check_output(command, shell=True)
            return return_value.strip().decode('utf-8')
        except subprocess.CalledProcessError:
            _LOGGER.error("Command failed: %s", command)
这里执行命令时,加了一个try,看了一下man systemctl我才想明白:
       is-active PATTERN...
           Check whether any of the specified units are active (i.e. running). Returns an exit
           code 0 if at least one is active, or non-zero otherwise. Unless --quiet is specified,
           this will also print the current unit state to standard output.
我直接python用了下subprocess.chect_output,发现确实丫exit 3了。解决也简单,我写了一个shell
#!/bin/sh
exit 0
然后把command_state改为执行这个shell就完事儿了。
 楼主| 发表于 2018-5-10 07:30:44 | 显示全部楼层
又想了一下,还有一个不写shell的更简单的方法:
subprocess.check_output('systemctl is-active frpc.service || exit 0',shell=True)
GMT+8, 2026-1-3 13:17 , Processed in 0.331773 second(s), 6 queries , MemCached On.
