查看: 9211|回复: 5
[求助] 大神帮我解决下问题
发表于 2017-6-17 15:42:26 | 显示全部楼层 |阅读模式
2017-06-17 07:38:43 WARNING (MainThread) [homeassistant.setup] Setup of mqtt is taking over 10 seconds.
2017-06-17 07:40:43 ERROR (MainThread) [homeassistant.setup] Error during setup of component mqtt
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/setup.py", line 187, in _async_setup_component
    result = yield from component.async_setup(hass, processed_config)
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/mqtt/__init__.py", line 380, in async_setup
    success = yield from hass.data[DATA_MQTT].async_connect()
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/mqtt/__init__.py", line 490, in async_connect
    self._mqttc.connect, self.broker, self.port, self.keepalive)
  File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
    value = future.result()
  File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
    raise self._exception
  File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
  File "/home/homeassistant/.homeassistant/deps/paho/mqtt/client.py", line 700, in connect
    return self.reconnect()
  File "/home/homeassistant/.homeassistant/deps/paho/mqtt/client.py", line 822, in reconnect
    sock = socket.create_connection((self._host, self._port), source_address=(self._bind_address, 0))
  File "/usr/lib/python3.4/socket.py", line 509, in create_connection
    raise err
  File "/usr/lib/python3.4/socket.py", line 500, in create_connection
    sock.connect(sa)
TimeoutError: [Errno 110] Connection timed out
2017-06-17 07:40:44 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of switch.mqtt. Setup failed for dependencies: mqtt
2017-06-17 07:40:44 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform switch.mqtt: Could not setup all dependencies.
主页
主页
wqqs 手机认证
活跃会员
发表于 2017-6-17 17:52:56 | 显示全部楼层
你把你的使用环境和要问的问题写清楚一点啊
严重灌水用户
发表于 2017-6-17 22:30:13 | 显示全部楼层
目测没有安装MQTT
ABC 手机认证
论坛风云人物
发表于 2017-6-17 22:51:08 | 显示全部楼层
mqtt没有启动
 楼主| 发表于 2017-6-20 08:52:48 | 显示全部楼层
问题已经解决了 谢谢
小白
发表于 2017-8-5 12:27:46 | 显示全部楼层
MQTT好像没有启动吧
GMT+8, 2025-12-25 15:39 , Processed in 0.095113 second(s), 20 queries , MemCached On.
