查看: 5759|回复: 3
[求助] 关于Custom UI Tiles(UI 磁贴)的坑
发表于 2018-5-6 00:38:48 | 显示全部楼层 |阅读模式
按照cxlwill的HA中文文档配置了Custom UI Tiles,地址:https://home-assistant.cc/project/custom-ui-tiles/
log无报错,但是始终无法出现方块磁贴。
然后又按官方项目地址:https://github.com/c727/home-assistant-tiles来配置,但同样不能显示出方块磁贴。
官方的配置如下:
homeassistant:
  customize:
    input_boolean.tiles_showcase:
      custom_ui_state_card: state-card-tiles
      config:
        columns: 3
        column_width: 75px
        row_height: 75px
        entities:
          - entity: input_boolean.switch1
            label: S1
          - entity: input_boolean.switch2
            label: S2
            column: 3
            row_span: 3
          - entity: script.switches_off
            icon: mdi:power
            icon_size: 50px
            column_span: 2
            row_span: 2
          - entity: script.press_button
            icon: mdi:arrow-up-thick
            column: 2
            row: 4
            data:
              value: top
            icon: mdi:arrow-left-thick
            column: 1
            row: 5
            data:
              value: left
            image: /local/ok.png
            column: 2
            row: 5
            data:
              value: ok
            icon: mdi:arrow-right-thick
            column: 3
            row: 5
            data:
              value: right
            icon: mdi:arrow-down-thick
            column: 2
            row: 6
            data:
              value: value
    input_boolean.tiles_domains:
      config:
        columns: 4
        row_height: 50px
        entities:
            label: Script off
          - entity: scene.switches_on
            label: Scene on
          - entity: sensor.random
            label_sec: Sensor
          - entity: sensor.random_uom
            label_sec: Sensor uom
            label: Switch 1
            label_sec_state: input_boolean.switch1
            label: Switch 2
            label_sec_state: input_boolean.switch2
          - entity: group.switches
            label: Group
            label: Group more info
            more_info: group.switches
    input_boolean.tiles_templates:
      config:
        columns: 3
        row_height: 50px
        entities:
            label: From state
            label_sec_template: "if (state < 10) return '<10'; else return '>=10';"
            label: Other entity
            label_sec_template: "return 'S1: ' + entities['input_boolean.switch1'].state;"
            label: From attribute
            label_sec_template: "return attributes.unit_of_measurement;"
            label_sec: Icon
            icon_template: "if (state === 'on') return 'mdi:power-plug'; else return 'mdi:power-plug-off'"
            label: Style bg-image
            color_on: black
            color_off: black
            style_template: "return 'background-image: url(\"/local/' + state + '.png\");'"
            label: Style
            style_template: "if (state !== 'on') return 'text-decoration: line-through';"
config:
frontend:
  extra_html_url:
    - /local/custom_ui/state-card-tiles.html
  extra_html_url_es5:
    - /local/custom_ui/state-card-tiles_es5.html
input_boolean:
  switch1:
  switch2:
  tiles_showcase:
  tiles_domains:
  tiles_templates:
  - platform: random
  - platform: random
    unit_of_measurement: m/s
scene:
  - name: Switches on
    entities:
      input_boolean.switch1: on
      input_boolean.switch2: on
script:
  switches_off:
    alias: Switches off
    sequence:
      service: input_boolean.turn_off
  press_button:
    alias: Press button
    sequence:
      service: input_text.set_value
      data:
        entity_id: input_text.button
      data_template:
        value: "{{ value }}"
input_text:
  button:
group:
  tiles1:
    entities:
      - input_boolean.tiles_showcase
  tiles2:
    entities:
      - input_boolean.tiles_domains
  tiles3:
    entities:
      - input_boolean.tiles_templates
  switches:
    entities:
      - input_boolean.switch1
      - input_boolean.switch2
  other:
    entities:
      - input_text.button
      - script.press_button
      - script.switches_off
      - scene.switches_on
      - sensor.random
      - sensor.random_uom
panel_custom:
  - name: tiles
    sidebar_title: Tiles
    sidebar_icon: mdi:view-dashboard
    url_path: tiles
    config:
      bg_color: "#24292e"
      entities:
          label: Switch 1
  - name: tiles
    sidebar_title: Tiles Multi
    url_path: tiles_multi
    config:
      bg_color: "#24292e"  # optional
      title: Tiles as your dashboard  #optional
      columns: 2           # optional
      column_width: 1fr    # optional
      rows: 2              # optional
      row_height: 1fr      # optional
      gap: 8px             # optional
      header_color: "#FFF" # optional
      header_size: 2.5em   # optional
      multi:
        - header: 1        # optional
          row: 1           # optional
          row_span: 1      # optional
          column: 1        # optional
          column_span: 2   # optional
          tiles:
            columns: 1
            entities:
                label: Switch 1
                label: Switch 2
        - header: 2
          tiles:
            columns: 1
            entities:
                label: Switch 1
                label: Switch 2
        - header: 3
          tiles:
            columns: 2
            entities:
                label: Switch 1
                label: Switch 2
夏天来了,家里好多风扇想用这个做成遥控器控制的。。。呜呜呜。。。问题在哪里呢???
发表于 2018-6-2 13:53:01 | 显示全部楼层
收藏了谢谢
发表于 2018-6-2 14:03:29 | 显示全部楼层
谢谢分享
发表于 2018-6-19 08:23:30 | 显示全部楼层
强制刷新下浏览器,Ctrl + F5
GMT+8, 2025-12-25 01:50 , Processed in 0.051612 second(s), 14 queries , MemCached On.
