查看: 8005|回复: 4
HB 设了开机启动后认不到小米灯
jh8
发表于 2018-5-3 22:43:45 | 显示全部楼层 |阅读模式
configuration.yaml:
light:
   - platform: yeelight
     devices:
       192.168.1.5:
         transition: 1000
customize.yaml:
light.yeelight_ceiling_7812dcaa6b9e:
  friendly_name: 书房灯
groups.yaml:
lights1:  #OK
    view: no
    entities:
      - light.yeelight_ceiling_7812dcaa6b9e
HB 的 config.json :
"supported_types": ["fan", "garage_door", "input_boolean", "light",  "lock", "script", "automation", "media_player", "rollershutter", "scene", "sensor", "switch", "vacuum"]
直接树莓派 运行
pi@hassbian:~ $ homebridge
在 iPhone 上连接桥后有找到 这个灯
改用下面开机自动启动 HB 后,其他设备都能找到,就缺这个灯, HA 上都正常 ,请大神帮看一下,哪里出了问题!
cd /etc/default
sudo nano /etc/default/homebridge
HOMEBRIDGE_OPTS= /home/pi/.homebridge
Ctrl + X, Y
cd /etc/systemd/system
sudo nano homebridge.service
[Unit]
Description=Node.js HomeKit Server
After=syslog.target network-online.target
[Service]
Type=simple
User=pi
EnvironmentFile=/etc/default/homebridge
ExecStart=/usr/bin/homebridge $HOMEBRIDGE_OPTS
Restart=on-failure
RestartSec=10
KillMode=process
[Install]
WantedBy=multi-user.target
Ctrl + x 然后 y 退出
cd /
sudo systemctl daemon-reload
sudo systemctl enable homebridge
jh8
 楼主| 发表于 2018-5-4 11:45:42 | 显示全部楼层
自己顶一下,哪位大神帮忙看一下啊
发表于 2018-5-4 14:35:04 | 显示全部楼层
使用yeelight的app,在里面打开局域网通信
jh8
 楼主| 发表于 2018-5-5 08:12:54 | 显示全部楼层
局域网通信 已经打开的, 手动启动 homebridge 是可以找到设备的,是设了开机自动启动 homebridge 后 就找不到这个灯
jh8
 楼主| 发表于 2018-5-5 08:59:47 | 显示全部楼层
解决了, 要加上
homebridge_hidden: false
GMT+8, 2026-1-3 13:17 , Processed in 0.289233 second(s), 14 queries , MemCached On.
