查看: 12423|回复: 8
[技术探讨] 请问有0.68 homekit插件的使用教程?
mrok
发表于 2018-5-3 14:20:51 来自手机 | 显示全部楼层 |阅读模式
看到说homekit可以顶替homebridge,但是不太会安装,有使用教程吗?
发表于 2018-5-3 14:29:45 | 显示全部楼层
一句homekit: 搞定
mrok
 楼主| 发表于 2018-5-3 16:19:24 来自手机 | 显示全部楼层
不用安装?
发表于 2018-5-3 20:55:39 | 显示全部楼层
试了出现报错 无效配置
发表于 2018-5-4 14:18:16 | 显示全部楼层
About
Home Assistant
0.68.1
Path to configuration.yaml: /home/homeassistant/.homeassistant
Developed by a bunch of awesome people.
Published under the Apache 2.0 license
Source: server — frontend-ui
Built using Python 3, Polymer 2.6.0, Icons by Google and MaterialDesignIcons.com.
Frontend JavaScript version: es5
Failed to connect to bulb 192.168.0.190, yeelight_rgb_34ce0084e2ce: A socket error occurred when sending the command.
下午2:17 components/light/yeelight.py (ERROR)
Not a valid device. Check the mac adress and update the firmware.
下午2:17 components/xiaomi_aqara.py (ERROR)
Got error element in data {"error":"No device"}
Setup failed for homekit: Could not install all requirements.
下午2:17 setup.py (ERROR)
Not initializing homekit because could not install requirement HAP-python==1.1.9
下午2:17 requirements.py (ERROR)
Unable to install package HAP-python==1.1.9: Command "/srv/homeassistant/homeassistant_venv/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-8t36j1_7/ed25519/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-0z1s8yhs/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/homeassistant_venv/include/site/python3.5/ed25519" failed with error code 1 in /tmp/pip-install-8t36j1_7/ed25519/
下午2:17 util/package.py (ERROR)
Press the button to load the full Home Assistant log.
2018-05-04 14:17:08 ERROR (Thread-20) [homeassistant.util.package] Unable to install package HAP-python==1.1.9: Command "/srv/homeassistant/homeassistant_venv/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-8t36j1_7/ed25519/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-0z1s8yhs/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/homeassistant_venv/include/site/python3.5/ed25519" failed with error code 1 in /tmp/pip-install-8t36j1_7/ed25519/
2018-05-04 14:17:08 ERROR (MainThread) [homeassistant.requirements] Not initializing homekit because could not install requirement HAP-python==1.1.9
2018-05-04 14:17:08 ERROR (MainThread) [homeassistant.setup] Setup failed for homekit: Could not install all requirements.
发表于 2018-5-4 17:25:55 | 显示全部楼层
HAP-python 安装失败,手工安装下下吧
活跃会员
发表于 2018-5-4 19:35:11 | 显示全部楼层
试试
apt install libgmp-dev libmpfr-dev libmpc-dev libffi-dev build-essential python3-pip python3-dev
pip3 install --user homekit
发表于 2018-5-5 09:07:52 | 显示全部楼层
嗯,搞定了
pip install HAP-python
发表于 2018-5-6 11:37:52 | 显示全部楼层
guitengyue 发表于 2018-5-5 09:07
嗯,搞定了
大神,这个要怎么安装,菜鸟一个啊
GMT+8, 2026-1-3 13:17 , Processed in 0.585629 second(s), 12 queries , MemCached On.
