查看: 7283|回复: 1
[求助] 我安了N次HADashboard都失败,hello都没看到过
发表于 2018-4-27 21:43:44 | 显示全部楼层 |阅读模式
执行sudo pip3 install .后,是这样的,是不是直接就安装失败了?pi@raspberrypi:~ $ cd  appdaemon
pi@raspberrypi:~/appdaemon $ sudo pip3 install .
  File "/usr/bin/pip3", line 9, in <module>
    load_entry_point('pip==1.5.6', 'console_scripts', 'pip3')()
  File "/usr/lib/python3/dist-packages/pkg_resources.py", line 356, in load_entry_point
    return get_distribution(dist).load_entry_point(group, name)
  File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2476, in load_entry_point
    return ep.load()
  File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2190, in load
    ['__name__'])
  File "/usr/lib/python3/dist-packages/pip/__init__.py", line 74, in <module>
    from pip.vcs import git, mercurial, subversion, bazaar  # noqa
  File "/usr/lib/python3/dist-packages/pip/vcs/mercurial.py", line 9, in <module>
    from pip.download import path_to_url
  File "/usr/lib/python3/dist-packages/pip/download.py", line 25, in <module>
    from requests.compat import IncompleteRead
ImportError: cannot import name 'IncompleteRead'
hugo
发表于 2018-5-2 10:06:21 | 显示全部楼层
sudo pip3 install --pre appdaemon
看你输入好像不对,不知道你要安装什么,如果要安装HADashboard,用上面这个
或者你可以参考官网安装说明
http://appdaemon.readthedocs.io/en/stable/INSTALL.html
GMT+8, 2025-12-25 03:50 , Processed in 0.369243 second(s), 11 queries , MemCached On.
