查看: 10331|回复: 0
[基础教程] dashborad,AppDaemon3 摄像头问题
发表于 2018-4-26 22:39:10 | 显示全部楼层 |阅读模式
有个小米摄像头想加入dashborad
网上看了配置
camera
A widget to display a refreshing camera image on the dashboard
Mandatory Arguments
  • entity_picture
This can be found using the developer tools, and will be one of the parameters associated with the camera you want to view. If you are using a password, you will need to append&api_password=<your password> to the end of the entity_picture. It will look something like this:
http://192.168.1.20:8123/api/camera_proxy/camera.living_room?token=<your token>&api_password=<redacted>
If you are using SSL, remeber to use the full DNS name and not the IP address.
看不懂怎么填。。。。。。。。。
求教大神 dashborad怎么加摄像头
GMT+8, 2026-1-3 13:15 , Processed in 0.169714 second(s), 7 queries , MemCached On.
