查看: 8105|回复: 0
[求助] 请教两个小米万能遥控器配置的问题?请大神指点,谢谢!
发表于 2018-4-23 09:11:36 | 显示全部楼层 |阅读模式
1、如何录制空调温度码
空调遥控器上有开关,温度上下调整,风力大小这些。但如何录制具体的温度(比如18度)的遥控码,遥控都没有18度这么一个按钮。
2、如何定义多个设备开关
config.json中可以自定义开关,我定义两个Custom段,代码检测通过,执行就出错,一个就可以。日志显示:Type Error: Cannot read property 'indexOf' of undefined
            "type": "Custom",
            "ip": "192.168.31.xx",
            "token": "xxx",
            "Name": "Custom-1",
            "data": {
                "on": {
                    "0": "0|xxx",
                    "1": "2|xxx",
                    "2": "5|xxx"
                "off": {
                    "0": "1|xxx"
            "type": "Custom",
            "token": "xxx",
            "Name": "Custom-2",
            "data": {
                "on": {
                    "0": "0|xxx",
                    "1": "2|xxx",
                    "2": "5|xxx"
                "off": {
                    "0": "1|xxx"
GMT+8, 2025-12-23 00:30 , Processed in 0.184886 second(s), 6 queries , MemCached On.
