查看: 23347|回复: 10
[技术探讨] 0.67.1 broadlink的问题
nnkn 手机认证
发表于 2018-4-21 17:07:23 | 显示全部楼层 |阅读模式
原来0.67的问题不见了,我sp mini的插座开关也出现了,但是不工作,出现新问题
Update for switch.spmini3 fails
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 204, in async_update_ha_state
    yield from self.async_device_update()
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 327, in async_device_update
    yield from self.hass.async_add_job(self.update)
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/lib/python3.6/site-packages/homeassistant/components/switch/broadlink.py", line 293, in update
    self._update()
  File "/usr/lib/python3.6/site-packages/homeassistant/components/switch/broadlink.py", line 298, in _update
    state = self._device.check_power()
  File "/usr/lib/python3.6/site-packages/broadlink/__init__.py", line 418, in check_power
    if ord(payload[0x4]) == 1 or ord(payload[0x4]) == 3:
TypeError: ord() expected string of length 1, but int found
我也在官方论坛找到了解决办法:
https://github.com/home-assistant/home-assistant/issues/13998
意思是下载这个文件覆盖一下就好了
https://github.com/mjg59/python-broadlink/blob/master/broadlink/__init__.py
现在问题来了,我是docker下安装的,我找不到/usr/lib/python3.6文件夹呀!!
求大神指点!
发表于 2018-4-21 18:03:33 | 显示全部楼层
/var/lib/docker/overlay2/***********************************/diff/usr/lib/python3.6/site-packages/broadlink/_init_.py
参与人数 1金钱 +7 收起 理由
jyz_0501 + 7 在下对你的景仰犹如滔滔长江之水,连绵不绝.
nnkn 手机认证
 楼主| 发表于 2018-4-21 18:25:06 | 显示全部楼层
liuyr 发表于 2018-4-21 18:03
/var/lib/docker/overlay2/***********************************/diff/usr/lib/python3.6/site-packages/br ...
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-4-21 18:57:19 | 显示全部楼层
nnkn 发表于 2018-4-21 18:25
感谢大神!!!搜到两个,我都替换了!重启HA就好了!!!!
你是docker装的话, 可以用samba
配置samba
sudo nano /etc/samba/smb.conf
在文件末尾添加:
[global]
netbios name = raspberrypi
server string = The Pi File Center
workgroup = WORKGROUP
hosts allow =
remote announce =
remote browse sync =
[Home Assistant]
path = /usr/share/hassio
comment = No comment
browsable = yes
read only = no
valid users =
writable = yes
guest ok = yes
public = yes
create mask = 0777
directory mask = 0777
force user = root
force create mode = 0777
force directory mode = 0777
hosts allow =
[Raspberry pi]
path = /
browsable = yes
read only = no
valid users =
writable = yes
guest ok = yes
public = yes
create mask = 0777
force user = root
hosts allow =
sudo service smbd restart
nnkn 手机认证
 楼主| 发表于 2018-4-21 19:57:47 | 显示全部楼层
[code][global]
netbios name = raspberryp ...
看你的代码,是把整个根目录全共享出去啦?不过我的问题是无法找到__init__.py在哪,现在按2楼的办法已经找到了,谢谢
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-4-21 20:01:00 | 显示全部楼层
nnkn 发表于 2018-4-21 19:57
看你的代码,是把整个根目录全共享出去啦?不过我的问题是无法找到__init__.py在哪,现在按2楼的办法已经 ...
对 自己在家操作方便,写cd  那么长的路径太麻烦~~
nnkn 手机认证
 楼主| 发表于 2018-4-21 20:19:48 | 显示全部楼层
嗯嗯,是呀,不过习惯了……
发表于 2018-4-21 20:59:30 | 显示全部楼层
[code][global]
小白问下 这个怎么用的
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-4-21 22:59:09 | 显示全部楼层
nuaawmy 发表于 2018-4-21 20:59
小白问下 这个怎么用的
然后复制到最下面
发表于 2018-4-24 13:13:12 | 显示全部楼层
对于这个问题,HASSIO是要放到哪里呢?
GMT+8, 2026-1-8 23:45 , Processed in 0.480402 second(s), 10 queries , MemCached On.
