查看: 7329|回复: 9
0.67.1 总是提示python3.6问题
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-4-20 19:53:03 | 显示全部楼层 |阅读模式
broadlink platform也崩溃了
Error while setting up platform broadlink
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 82, in async_setup
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/usr/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
    return fut.result()
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/broadlink.py", line 60, in setup_platform
    broadlink_data = BroadlinkData(update_interval, host, mac_addr, timeout)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/broadlink.py", line 109, in __init__
    self._device = broadlink.a1((ip_addr, 80), mac_addr, None)
TypeError: __init__() takes 3 positional arguments but 4 were given
MQTT也是崩溃
Error while setting up platform mqtt
    return fut.result()
  File "/usr/lib/python3.6/asyncio/coroutines.py", line 210, in coro
    res = func(*args, **kw)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/switch/mqtt.py", line 46, in async_setup_platform
    config = PLATFORM_SCHEMA(discovery_info)
  File "/usr/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 267, in __call__
    return self._compiled([], data)
  File "/usr/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 587, in validate_dict
    return base_validate(path, iteritems(data), out)
  File "/usr/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 425, in validate_mapping
    raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: required key not provided @ data['command_topic']
/usr/lib/python3.6/site-packages/homeassistant/components/shell_command.py (ERROR)
/usr/lib/python3.6 就没有这个目录,homeassistant的python是安装到/usr/local/lib/python3.6 下的
活跃会员教程狂人
发表于 2018-4-20 23:14:18 | 显示全部楼层
你是重刷系统了么....
所有过往,皆为序章。
发表于 2018-4-21 08:43:56 | 显示全部楼层
我的只有broadlink有问题mqtt没问题
nnkn 手机认证
发表于 2018-4-21 16:57:26 | 显示全部楼层
broadlink的问题貌似官网论坛里有解决办法了,替换__init.py__就可以,然而,我也和楼主一样,/usr/lib/python3.6 就没有这个目录,是不是和docker有关呀?
官网论坛的解决链接:
https://github.com/home-assistant/home-assistant/issues/13998
发表于 2018-4-21 18:21:28 | 显示全部楼层
nnkn 发表于 2018-4-21 16:57
broadlink的问题貌似官网论坛里有解决办法了,替换__init.py__就可以,然而,我也和楼主一样,/usr/lib/pyt ...
英文不好看不懂,能告知一下具体操作方式么
nnkn 手机认证
发表于 2018-4-21 18:33:44 | 显示全部楼层
https://bbs.hassbian.com/forum.php?mod=viewthread&tid=3508&page=1#pid85029要替换的文件
__init__.py (29.69 KB, 下载次数: 8)
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-4-21 18:49:43 | 显示全部楼层
https://community.home-assistant ... -broadlink/50514/10
感谢你们提供地址,让我找到这个解决办法。
grea09
I have the same problem !
I fixed it by manually updating the file /homeassistant/deps/lib/python3.6/site-packages/broadlink/__init__.py to its latest version. It has a type check missing.
I reported the issue there : https://github.com/home-assistant/home-assistant/issues/13998
地址在这里:/homeassistant/deps/lib/python3.6/site-packages/broadlink/__init__.py  也就是配置文件夹中的deps文件夹,这个你们应该都有,没有的话自己按照这个目录新建一下,替换文件即可、
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-4-21 18:53:30 | 显示全部楼层
看上楼~~~~
发表于 2018-4-21 19:13:55 | 显示全部楼层
已按上述方法解决,感谢分享
fhvk 手机认证
发表于 2018-4-25 13:45:06 | 显示全部楼层
博联通过上述方法已解决
GMT+8, 2026-1-3 13:17 , Processed in 0.483120 second(s), 11 queries , MemCached On.
