查看: 9536|回复: 0
[基础教程] 树莓派3,configuration.yaml添加了组件 为何主页不显示
发表于 2018-4-20 13:11:42 | 显示全部楼层 |阅读模式
我是按照网上的一篇教程一步一步做的,configuration.yaml添加了设备 为何home assistant主页没有显示相关设备 以下是文件代码 请大神帮我分析分析   # 天龙功放
media_player:
  - platform: denon
    host: 192.168.1.13
这段是我添加了 按照教程上说添加完后 重启home assistant 会在主页显示相关设备
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 32.0617
  longitude: 118.7778
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: Asia/Shanghai
  # Customization file
  customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
  # Secrets are defined in the file secrets.yaml
  # api_password: !secret http_password
  # Uncomment this if you are using SSL/TLS, running in Docker container, etc.
  # base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
# Cloud
cloud:
# 天龙功放
media_player:
  - platform: denon
    host: 192.168.1.13
group: !include groups.yaml
script: !include scripts.yaml
weather:
  -platform: yweather
   woeid: 2151849
GMT+8, 2026-1-3 18:00 , Processed in 1.090118 second(s), 9 queries , MemCached On.
