查看: 6764|回复: 3
小白求助各位大佬看看这是为啥?
发表于 2018-4-19 17:50:08 | 显示全部楼层 |阅读模式
树莓派装了hassio,配置了小米网关,然后概览中能看见设备也可以控制,但是安装homebridge插件后用iphone手机配对只能看见桥,小米网关下的开关一个也看不见是咋回事呀。
贴上bridge的config
  "bridge": {
    "name": "Home Assistant",
    "username": "B8:27:EB:4D:4C:0A",
    "port": 51826,
    "pin": "123-45-678"
  "description": "Homebridge for Home Assistant",
  "accessories": [],
  "platforms": [
      "platform": "HomeAssistant",
      "name": "HomeAssistant",
      "host": "http://192.168.1.140:8123",
      "password": "raspberry",
      "default_visibility": "hidden",
      "supported_types": [
        "automation",
        "binary_sensor",
        "climate",
        "cover",
        "device_tracker",
        "fan",
        "group",
        "input_boolean",
        "light",
        "lock",
        "media_player",
        "remote",
        "scene",
        "script",
        "sensor",
        "switch",
        "vacuum"
      "logging": true,
      "verify_ssl": true
发表于 2018-4-19 22:13:01 | 显示全部楼层
确定ha的密码是raspberry吗?如果没有设置过密码,就不能填
 楼主| 发表于 2018-4-20 16:34:24 | 显示全部楼层
确定哦,一开始设置的别的密码还怕有影响,特地把两个都改成raspberry
发表于 2018-4-20 17:04:12 | 显示全部楼层
这个版块有解决方案,自己翻一下吧··善用搜索
GMT+8, 2026-1-3 17:58 , Processed in 1.267500 second(s), 11 queries , MemCached On.
