查看: 21241|回复: 10
[技术探讨] Home Assistant显示的配件无法在HomeKit上显示添加
发表于 2018-4-17 22:57:15 | 显示全部楼层 |阅读模式
大神们好!图一是configuration上添加好的小米网关及他的配件。
下面是苹果手机上只能看到一个HA的桥,没有显示或者添加别的配件!求指导怎么操作才可以显示跟添加!!谢谢!!
在IO插件HB里 已经修改过    "pin": "632-25-283"
  "description": "Homebridge for Home Assistant",
  "accessories": [],
  "platforms": [
      "platform": "HomeAssistant",
      "name": "HomeAssistant",
      "host": "http://192.168.3.233:8123",
      "password": "123456",
才看到的苹果手机上一个桥  就是找不到HA里的配件
 楼主| 发表于 2018-4-17 23:39:32 | 显示全部楼层
在HB记录里显示这样
[HomeAssistant] Received event: {"event_type": "state_changed", "data": {"entity_id": "sun.sun", "old_state": {"entity_id": "sun.sun", "state": "below_horizon", "attributes": {"next_dawn": "2018-04-17T21:04:42+00:00", "next_dusk": "2018-04-18T10:52:55+00:00", "next_midnight": "2018-04-17T15:58:47+00:00", "next_noon": "2018-04-18T03:58:48+00:00", "next_rising": "2018-04-17T21:29:26+00:00", "next_setting": "2018-04-18T10:28:11+00:00", "elevation": -48.52, "azimuth": 351.74, "friendly_name": "Sun"}, "last_changed": "2018-04-17T13:18:59.255925+00:00", "last_updated": "2018-04-17T15:36:30.719921+00:00"}, "new_state": {"entity_id": "sun.sun", "state": "below_horizon", "attributes": {"next_dawn": "2018-04-17T21:04:42+00:00", "next_dusk": "2018-04-18T10:52:55+00:00", "next_midnight": "2018-04-17T15:58:47+00:00", "next_noon": "2018-04-18T03:58:48+00:00", "next_rising": "2018-04-17T21:29:26+00:00", "next_setting": "2018-04-18T10:28:11+00:00", "elevation": -48.55, "azimuth": 352.11, "friendly_name": "Sun"}, "last_changed": "2018-04-17T13:18:59.255925+00:00", "last_updated": "2018-04-17T15:37:30.721112+00:00"}}, "origin": "LOCAL", "time_fired": "2018-04-17T15:37:30.721273+00:00"}
发表于 2018-4-18 18:27:07 | 显示全部楼层
你是在树莓派还是群晖docker中设置的?
欢迎加我QQ:1137250
发表于 2018-4-21 23:21:13 | 显示全部楼层
我的最开始跟你问题一样,后来设置了HomeBridge的JSON文件就可以识别了
你再仔细看看那个文件,问题应该就那
 楼主| 发表于 2018-4-22 10:17:50 | 显示全部楼层
好的 我试试  谢谢
发表于 2018-4-22 19:37:00 来自手机 | 显示全部楼层
我也是,后来在ha的设置文件里添加homekit:项才解决,变化是8位密码从自己设定变成随机,我搞不明白,但homekit能用了。
 楼主| 发表于 2018-4-22 19:44:27 | 显示全部楼层
tqh5597 发表于 2018-4-22 19:37
我也是,后来在ha的设置文件里添加homekit:项才解决,变化是8位密码从自己设定变成随机,我搞不明白,但hom ...
兄弟  截个图看看  你怎么添加的homekit  变化8位密码 设置随机???
 楼主| 发表于 2018-4-22 19:47:43 | 显示全部楼层
我现在就是 要么手机压根HB看不到    要么就是手机连上HB 看不到HA里的小米设备~
发表于 2018-4-23 00:07:01 | 显示全部楼层
zhli2712 发表于 2018-4-22 19:47
我现在就是 要么手机压根HB看不到    要么就是手机连上HB 看不到HA里的小米设备~ ...
下面是我添加在configuration.yaml里的, include_entities:后面的实体你自己去http://xxx.xxx.x.x:8123/dev-state里找,我是小白,就是这样折腾出来的.你也可以去https://www.home-assistant.io/components/homekit看看。重启HA后,那个8位的密码会出现在xxx.xxx.x.x:8123的主页里,点忽略之前先记住。
homekit:
  auto_start: true
  port: 51826
  filter:
    include_entities:  switch.tc2_1, switch.tc2_2, switch.tv_projector, switch.tv_projector_ok, switch.air_conditioner_switch, switch.air_conditioner_cool, switch.air_conditioner_hot, switch.air_conditioner_temperature_up, switch.air_conditioner_temperature_down
发表于 2018-4-23 04:00:50 | 显示全部楼层
tqh5597 发表于 2018-4-23 00:07
下面是我添加在configuration.yaml里的, include_entities:后面的实体你自己去http://xxx.xxx.x.x:8123/d ...
老铁,为啥我加了你这段代码,HA启动不了
GMT+8, 2026-1-3 13:16 , Processed in 1.183162 second(s), 14 queries , MemCached On.
