查看: 12323|回复: 12
[已解决] baidu tts 出错
发表于 2018-4-17 20:44:50 | 显示全部楼层 |阅读模式
配置完百度TTS 后使用MPD测试一直无法成功
下面是log
高手看看是什么原因吧
2018-04-17 20:27:06 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall tts.baidu_say: entity_id=['media_player.mpd'], message=123>
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/core.py", line 1002, in _event_to_service_call
    await service_handler.func(service_call)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/tts/__init__.py", line 135, in async_say_handle
    options=options
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/tts/__init__.py", line 305, in async_get_url
    engine, key, message, use_cache, language, options)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/tts/__init__.py", line 319, in async_get_tts_audio
    message, language, options)
  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/home/homeassistant/.homeassistant/custom_components/tts/baidu.py", line 119, in get_tts_audio
    from aip import AipSpeech
  File "/srv/homeassistant/lib/python3.5/site-packages/aip/__init__.py", line 6, in <module>
    from .ocr import AipOcr
  File "/srv/homeassistant/lib/python3.5/site-packages/aip/ocr.py", line 7, in <module>
    from .base import AipBase
  File "/srv/homeassistant/lib/python3.5/site-packages/aip/base.py", line 14, in <module>
    from PIL import Image
  File "/srv/homeassistant/lib/python3.5/site-packages/PIL/Image.py", line 60, in <module>
    from . import _imaging as core
ImportError: libtiff.so.5: cannot open shared object file: No such file or directory
 楼主| 发表于 2018-4-17 21:49:51 | 显示全部楼层
换了一个VoiceRSS 的TTS就好了,可能是ha0.67版本不兼容baidu
发表于 2018-4-17 23:10:20 | 显示全部楼层
没问题 tts.baidu再0.67下用的挺好没见到这样的错误
 楼主| 发表于 2018-4-17 23:22:26 | 显示全部楼层
不知道呀 原来在0.66下也没问题 换了0.67就抽风了
发表于 2018-4-18 09:10:45 | 显示全部楼层
用的什么系统了,估计得安装一下libtiff.so
发表于 2018-4-18 09:11:23 | 显示全部楼层
楼主日志显示缺少 libtiff 库,试试运行 pip install libtiff 安装下?貌似还有 sudo apt install libtiff5
 楼主| 发表于 2018-4-18 09:12:20 | 显示全部楼层
hassbian的系统
 楼主| 发表于 2018-4-18 09:24:42 | 显示全部楼层
neroxps 发表于 2018-4-18 09:11
[md]
楼主日志显示缺少 libtiff 库,试试运行 `pip install libtiff` 安装下?貌似还有 `sudo apt install  ...
好的 我再去试试 谢谢
教程狂人论坛风云人物突出贡献
发表于 2018-4-18 09:28:21 | 显示全部楼层
换自定义插件https://bbs.hassbian.com/thread-1152-1-1.html
官方的依赖baidu aip经常出问题
 楼主| 发表于 2018-4-18 10:14:46 | 显示全部楼层
官方的依赖baidu aip经常出问题 ...
自制插件也无效,谢谢
GMT+8, 2025-12-24 09:30 , Processed in 1.621984 second(s), 11 queries , MemCached On.
