查看: 19529|回复: 17
[基础教程] 小米萬能搖控器控制教學
发表于 2018-4-13 15:03:51 | 显示全部楼层 |阅读模式
首先感謝論壇的資源和分享
使得我可以從中學習相關HA的應用
今天要分享的是從導入HA以來
一直希望能利用小米萬能遙控器來控制家電(就如米家的功能一樣)
但是自己資質不足
研究了好多的論壇文章才成功
因此今天就把自己的經驗分享給有小米萬能遙控器的人
執行下面步驟時
請先參考https://homekit.loli.ren/docs/show/12
找到您的小米萬能遙控器token
步驟一:
小米萬能遙控器的接入(參考文章:https://bbs.hassbian.com/forum.p ... 9%E6%8E%A7%E5%99%A8)
configuration.yaml
依此方式增加您錄製的紅外碼
步驟二:
錄製控制設備的紅外碼
1.點選服務
2.依照下方圖示輸入與選擇
在按下CALL SERVICE時-請先將你要錄製的遙控器準備好
按下CALL SERVICE,小米萬能遙控器藍燈會開始閃爍
此時按下要錄製的遙控器紅外線碼小米萬能遙控器會停止閃爍(錄製完畢)
步驟三:
複製錄製好的紅外線碼
1.點選狀態
2.找到persistent_notification.notification(右側值會看到剛剛錄製的值)
3.複製message: Received command is:之後的紅外線碼
4.將剛剛複製的紅外碼複製到步驟一 -raw:後
範例如下:
remote:
  - platform: xiaomi_miio
    host: 192.168.31.xx
    token: 8dc34636bbbf4f850d39dc75191b233
    slot: 14
    timeout: 30
    hidden: false
    commands:
      1:
        command:
          - raw:Z6WDACsCAACVAgAAVAcAAFsJAACYCQAA8A0AAC8OAABWIQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA2EBAgIBAQECAQEBAQEBAQECAQEBAgICAgEBAQIBAgIHBFEBAgIBAQECAQEBAQEBAQECAQEBAgICAgEBAQIBAgIAA=
若是還要控制其他設備依照步驟三: 1到4 錄製設備紅外碼   取得紅外碼  然後在configuration.yaml 小米萬能設置下新增
X
   command:
       - raw:
範例如下(共錄製三個紅外碼)
#小米萬用遙控接入
remote:
    host: 192.168.31.XX
    token: 8dc346365771f4XXXXXXXX75191b233
    slot: 14
    timeout: 30
    hidden: false
    commands:
      1:
        command:
          - raw:Z6WDACsCAACVAgAAVAcAAFsJAACYCQAA8A0AAC8OAABWIQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA2EBAgIBAQECAQEBAQEBAQECAQXXXXXCAgEBAQIBAgIHBFEBAgIBAQECAQEBAQEBAQECAQEBAgICAgEBAQIBAgIAA=
      2:
        command:
          - raw:Z6VHAEICAAB9BgAAuggAAI0RAABkIwAA6JkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0AAAAAAAAAAAQEBAQEBAQEBAXXXXAAAAABAAEAAQEBBQJAA=
      3:
        command:
          - raw:Z6WDAF8CAAAlBwAAaAkAAB4OAAAnIQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjABAQEAAAABAAAAAAAAXXXAAAAAQEBAQAAAAEAAQEEAjABAQEAAAABAAAAAAAAAAABAAAAAQEBAQAAAAEAAQEAA=
步驟四:
設定按鈕控制錄製的遙控碼
#做一個控制門的按鈕
input_boolean:
  mi_open_door_temp:
    initial: off
#當按下按鈕時
automation:
#當按下按鈕時傳送紅外線去開門
  - alias: mi_open_door_temp
    trigger:
      - platform: state
        entity_id: input_boolean.mi_open_door_temp
        to: 'on'
    action:
    - service: script.open_door
#當門關時(門窗感應從on變成off時),將按鈕變成off狀態
  - alias: close_mi_od
    trigger:
      - platform: state
        entity_id: binary_sensor.door_window_sensor_158d0001ef6a3d
        to: 'off'
    action:
    - service: input_boolean.turn_off
script:
#執行2的紅外碼腳本
  open_door:
    sequence:
      - service: remote.send_command
        data:
          command:
          - '2'
          entity_id: remote.ir_remote
group:
  mi_open_door_temp:
    view: no
    control: hidden
    entities:
      - input_boolean.mi_open_door_temp
完成以後重啟HA就可以看到新增的按鈕
影片如下:
影片連結http://new-play.tudou.com/v/883930771.html?spm=a2hzp.8244740.0.0
以上小小分享 再次感謝論壇大家的分享
讓我的HA功能越來越完善
附檔含冷氣開關範例 packages.7z (670 Bytes, 下载次数: 122)
参与人数 4金钱 +47 收起 理由
a137537763 + 7
+ 20 膜拜大神!
neroxps + 10 谢谢分享!
windgo + 10 谢谢分享!
发表于 2018-4-13 17:39:31 | 显示全部楼层
楼主辛苦,感谢分享!
另外,提醒一下,插入video的时候,地址后面的?spm=xxxx那些要删除,否则视频无法播放哦~
 楼主| 发表于 2018-4-13 19:36:24 | 显示全部楼层
Jones 发表于 2018-4-13 17:39
楼主辛苦,感谢分享!
另外,提醒一下,插入video的时候,地址后面的?spm=xxxx那些要删除,否则视频无法播 ...
原來如此~~難怪我每次分享視頻都不成功  謝謝您
发表于 2018-7-22 00:39:24 | 显示全部楼层
想請問開關要做在哪個檔案??
我在configuration.yaml裡加入下列程式碼host跟token都改好了,
raw也抓到了~可是按鈕沒有改變?按鈕要在哪個檔案加入?
remote:
    host:
    token:
    slot: 14
    timeout: 30
    hidden: false
    commands:
      1:
        command:
          - raw:
 楼主| 发表于 2018-7-23 21:54:29 | 显示全部楼层
windpig 发表于 2018-7-22 00:39
想請問開關要做在哪個檔案??
raw也抓到了~ ...
其他按鈕和自動化與腳本 都放到packages資料夾裡的檔案(檔案名稱您可以自己設定)可以參考我的附件
发表于 2018-11-17 16:00:59 | 显示全部楼层
感谢分享!
发表于 2018-11-17 16:18:22 | 显示全部楼层
感谢分享!
发表于 2018-11-18 22:01:07 来自手机 | 显示全部楼层
学习了!
发表于 2018-12-27 15:41:04 | 显示全部楼层
请问一下步骤四的代码是放在哪儿文件里
 楼主| 发表于 2018-12-27 15:49:28 | 显示全部楼层
pwlmcs 发表于 2018-12-27 15:41
请问一下步骤四的代码是放在哪儿文件里
放到 packages資料夾內-我有提供範例附件-你可以下載後改成您的按鈕名稱
GMT+8, 2026-1-1 01:31 , Processed in 0.764956 second(s), 21 queries , MemCached On.
