查看: 3063|回复: 3
[技术探讨] homebridge-config-ui-x插件是运行在哪个nodejs版本里的??
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-4-13 00:56:08 | 显示全部楼层 |阅读模式
/usr/bin/homebridge-config-ui-x -> /usr/lib/node_modules/homebridge-config-ui-x/dist/bin/standalone.js
> [email protected] install /usr/lib/node_modules/homebridge-config-ui-x/node_modules/node-pty
> node scripts/install.js
gyp ERR! configure error
gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.
gyp ERR! stack     at PythonFinder.failNoPython (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:483:19)
gyp ERR! stack     at PythonFinder.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:397:16)
gyp ERR! stack     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:16)
gyp ERR! stack     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:42:5
gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/mode.js:8:5
gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:152:21)
gyp ERR! System Linux 4.14.30-v7+
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /usr/lib/node_modules/homebridge-config-ui-x/node_modules/node-pty
gyp ERR! node -v v8.9.3
gyp ERR! node-gyp -v v3.6.2
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] install: `node scripts/install.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2018-04-12T16_48_30_329Z-debug.log
FATAL: Failed installing plugin homebridge-config-ui-x
[cont-init.d] 82-user-plugins.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
                Oops! Something went wrong.
mitu 手机认证
发表于 2018-4-13 09:07:50 | 显示全部楼层
我是直接安装7
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-4-14 03:24:31 | 显示全部楼层
gyp ERR! System Linux 4.9.80-v7+
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR!     /root/.npm/_logs/2018-04-13T19_21_55_967Z-debug.log
 We are so sorry, but something went terribly wrong when
 starting or running this add-on.
 Be sure to check the log above, line by line, for hints.
还是一直报错~~
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-4-15 12:26:37 | 显示全部楼层
gyp ERR! not ok
怎么解决啊 有人知道吗??
GMT+8, 2026-1-4 07:09 , Processed in 0.776646 second(s), 7 queries , MemCached On.
