查看: 4387|回复: 1
[求助] HA報錯一問
发表于 2018-4-7 23:12:21 | 显示全部楼层 |阅读模式
HA報錯,但找不到錯處,求大神出手幫忙~~thanks!!
2018-04-07 22:59:10 ERROR (MainThread) [homeassistant.config] Invalid config for [sensor.template]: [input_boolean.eric2] is an invalid option for [sensor.template]. Check: sensor.template->sensors->input_boolean.eric2. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.template/
  - platform: template
    sensors:
       input_boolean.eric2:
         friendly_name: "Eric2 away/home"
         value_template: >-
           {% if is_state('input_boolean.eric', 'on') %}
             home
           {% else %}
             away
           {% endif %}
                 home
           {% else %}
             away
           {% endif %}
 楼主| 发表于 2018-4-7 23:56:02 | 显示全部楼层
已經解決, thanks!!
GMT+8, 2025-12-25 07:53 , Processed in 0.202459 second(s), 7 queries , MemCached On.
