楼主: luzai
[经验分享] 2019-11-01更新:device_tracker-华硕组件-无法发现全部设备
发表于 2019-1-18 11:10:41 | 显示全部楼层
感谢分享,小白学习学习
发表于 2019-1-18 11:23:13 | 显示全部楼层
好东西,正需要
发表于 2019-1-26 12:15:51 | 显示全部楼层
发表于 2019-1-26 15:14:34 | 显示全部楼层
感謝大大大大
发表于 2019-1-26 23:15:26 | 显示全部楼层
谢谢分享,正在学习中
发表于 2019-1-27 13:56:50 | 显示全部楼层
活跃会员教程狂人
发表于 2019-1-27 14:10:10 | 显示全部楼层
这个最新版本0.86.2可用吗?试一试。
所有过往,皆为序章。
发表于 2019-1-27 16:48:00 | 显示全部楼层
土豆大佬也遭遇了0.86.2的华硕路由器崩溃吗?
我现在是频繁提示“ Updating device list from asuswrt took longer than the scheduled scan interval 0:00:12”
活跃会员教程狂人
发表于 2019-1-27 17:00:53 | 显示全部楼层
我现在是频繁提示“ Updating device list from asuswrt to ...
你才是大佬,我就是伸手党啊。,日志里面好像这种提示其实没事儿的吧,因为人脸识别组件就特么一直提示,但是不影响使用啊,我现在是直接提示失败。
只做了官方的配置,上次出问题按照你们的帖子配置了,一直没问题用到0.85,这次到了0.86.x,追踪用不了,自带的那几个鸡肋sensor也挂了。配置ssh方式,会报错:cryptography.exceptions.UnsupportedAlgorithm: X25519 is not supported by this version of OpenSSL.
配置telnet方式好像没啥反应,他启动之后同样报错,好像还是跟这个X25519有关:
2019-01-27 16:55:31 ERROR (MainThread) [homeassistant.setup] Error during setup of component asuswrt
  File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 145, in _async_setup_component
    hass, processed_config)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/asuswrt.py", line 61, in async_setup
    await api.connection.async_connect()
  File "/usr/local/lib/python3.6/site-packages/aioasuswrt/connection.py", line 66, in async_connect
    self._client = await asyncssh.connect(self._host, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/asyncssh/misc.py", line 182, in __await__
    return (yield from self._coro)
  File "/usr/local/lib/python3.6/site-packages/asyncssh/connection.py", line 5454, in connect
    conn, _ = yield from create_connection(None, host, port, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/asyncssh/connection.py", line 5110, in create_connection
    yield from auth_waiter
  File "/usr/local/lib/python3.6/site-packages/asyncssh/connection.py", line 627, in data_received
    while self._inpbuf and self._recv_handler():
  File "/usr/local/lib/python3.6/site-packages/asyncssh/connection.py", line 847, in _recv_packet
    processed = handler.process_packet(pkttype, seq, packet)
  File "/usr/local/lib/python3.6/site-packages/asyncssh/packet.py", line 215, in process_packet
    self._packet_handlers[pkttype](self, pkttype, pktid, packet)
  File "/usr/local/lib/python3.6/site-packages/asyncssh/connection.py", line 1414, in _process_kexinit
    self._kex = get_kex(self, kex_alg)
  File "/usr/local/lib/python3.6/site-packages/asyncssh/kex.py", line 122, in get_kex
    return handler(alg, conn, hash_alg, *args)
  File "/usr/local/lib/python3.6/site-packages/asyncssh/kex_ecdh.py", line 47, in __init__
    self._priv = ecdh_class(*args)
  File "/usr/local/lib/python3.6/site-packages/asyncssh/crypto/curve25519.py", line 31, in __init__
    self._priv_key = x25519.X25519PrivateKey.generate()
  File "/usr/local/lib/python3.6/site-packages/cryptography/hazmat/primitives/asymmetric/x25519.py", line 39, in generate
    _Reasons.UNSUPPORTED_EXCHANGE_ALGORITHM
倒是M大以前那个asus的插件可以用了,服了。
而且我遇到个新问题,人脸识别(L大的那个插件,包括后来坛友升级的),一点进去整个HA当前的界面(chrome或者ios客户端)都会卡死,看日志和开发者工具中这个ID的状态更新是正常的,见了鬼了,都不知道该怎么找原因。
所有过往,皆为序章。
发表于 2019-1-29 21:22:09 | 显示全部楼层
看看 谢谢分享
GMT+8, 2026-1-15 05:05 , Processed in 1.671868 second(s), 13 queries , MemCached On.
