查看: 3335|回复: 1
[求助] 叮咚TOP搜索不到habridge,HUE也找不到
dr85
发表于 2018-3-25 23:05:34 | 显示全部楼层 |阅读模式
在ubuntu上安装的homeassistant和habridge。能在habridge web页面控制开关,
叮咚也连上网络,且与homeassistant同一网段,但是叮咚就是搜不到habridge。
hue这个APP ,也搜索不到。
habridge 的LOG
03-25-2018 14:18:12.856INFOreading from config file: data/habridge.configcom.bwssystems.HABridge.BridgeSettings
03-25-2018 14:18:12.873INFOHA Bridge initializing....com.bwssystems.HABridge.HABridge
03-25-2018 14:18:12.875INFOSystem control service started....com.bwssystems.HABridge.SystemControl
03-25-2018 14:18:12.878INFOInitializing UDP response Socket...com.bwssystems.HABridge.util.UDPDatagramSender
03-25-2018 14:18:12.878INFOUDP response Seocket initialized to: 50000com.bwssystems.HABridge.util.UDPDatagramSender
03-25-2018 14:18:12.879INFOHarmony Home created. No Harmony devices configured.com.bwssystems.HABridge.plugins.harmony.HarmonyHome
03-25-2018 14:18:12.879INFONest Home created. No Nest configured.com.bwssystems.HABridge.plugins.NestBridge.NestHome
03-25-2018 14:18:12.879INFOHue passthru Home created. No Hue passtrhu systems configured.com.bwssystems.HABridge.plugins.hue.HueHome
03-25-2018 14:18:12.879INFOHAL Home created. No HAL devices configured.com.bwssystems.HABridge.plugins.hal.HalHome
03-25-2018 14:18:12.879INFOMQTT Home created. No MQTT Clients configured.com.bwssystems.HABridge.plugins.mqtt.MQTTHome
03-25-2018 14:18:12.879INFOHomeAssistant Home created.com.bwssystems.HABridge.plugins.hass.HassHome
03-25-2018 14:18:12.879INFO== Spark has ignited ...spark.webserver.JettySparkServer
03-25-2018 14:18:12.880INFO>> Listening on 0.0.0.0:80spark.webserver.JettySparkServer
03-25-2018 14:18:12.896INFOCommand Home for system program execution created.com.bwssystems.HABridge.plugins.exec.CommandHome
03-25-2018 14:18:12.906INFOHttp Home created.com.bwssystems.HABridge.plugins.http.HTTPHome
03-25-2018 14:18:12.906INFOTCP Home created.com.bwssystems.HABridge.plugins.tcp.TCPHome
03-25-2018 14:18:12.906INFOUDP Home created.com.bwssystems.HABridge.plugins.udp.UDPHome
03-25-2018 14:18:12.907INFOVera Home created. No Veras configured.com.bwssystems.HABridge.plugins.vera.VeraHome
03-25-2018 14:18:12.907INFODomoticz Home created. No Domoticz devices configured.com.bwssystems.HABridge.plugins.domoticz.DomoticzHome
03-25-2018 14:18:12.907INFOSomfy Home created. No Somfys configured.com.bwssystems.HABridge.plugins.somfy.SomfyHome
03-25-2018 14:18:12.907INFOLifxDevice Home created. No LifxDevices configured.com.bwssystems.HABridge.plugins.lifx.LifxHome
03-25-2018 14:18:12.908WARNError reading the file: data/device.db - Does not exist or is not readable. continuing...com.bwssystems.HABridge.dao.DeviceRepository
03-25-2018 14:18:12.908INFOHABridge device management service started.... com.bwssystems.HABridge.devicemanagmeent.DeviceResource
03-25-2018 14:18:12.910INFOHue description service started....com.bwssystems.HABridge.upnp.UpnpSettingsResource
03-25-2018 14:18:12.911INFOHue emulator service started....com.bwssystems.HABridge.hue.HueMulator
03-25-2018 14:18:12.936INFOUPNP Discovery Listener starting....com.bwssystems.HABridge.upnp.UpnpListener
03-25-2018 14:18:12.941INFOUPNP Discovery Listener running and ready....com.bwssystems.HABridge.upnp.UpnpListener
03-25-2018 14:19:16.075INFOLink button pressed....com.bwssystems.HABridge.SystemControl
03-25-2018 14:19:46.078INFOLink button time ended....com.bwssystems.HABridge.LinkButtonPressed
03-25-2018 14:44:51.706INFOLink button pressed....com.bwssystems.HABridge.SystemControl
03-25-2018 14:45:21.710INFOLink button time ended....com.bwssystems.HABridge.LinkButtonPressed
发表于 2018-3-26 11:51:18 | 显示全部楼层
叮咚需要huebridge在80端口运行
我用habridge会导致ha报错,建议用虫子大神的这个,很好用
https://bbs.hassbian.com/thread-3135-1-1.html
GMT+8, 2025-12-25 06:00 , Processed in 0.050051 second(s), 6 queries , MemCached On.
