查看: 12367|回复: 18
[技术探讨] 斐讯空气净化器 A1 api记录
27hh
教程狂人论坛风云人物
发表于 2018-3-25 10:37:20 | 显示全部楼层 |阅读模式
期待大神写插件
可用操作
public interface a {
    @retrofit2.http.GET("aircleaner/getBindDevs")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse<com.phicomm.aircleaner.models.equipment.response.EnvDeviceListResponse>> a(@retrofit2.http.Header("Authorization") java.lang.String r1);
    @retrofit2.http.GET("aircleaner/countData_year")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse<com.phicomm.aircleaner.models.history.response.YearDataResponse.DataBean>> a(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("deviceID") java.lang.String r2);
    @retrofit2.http.POST("aircleaner/setDataSource")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse> a(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("catDeviceID") java.lang.String r2, @retrofit2.http.Query("cleanerDeviceID") java.lang.String r3);
    @retrofit2.http.GET("aircleaner/countData_day")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse<com.phicomm.aircleaner.models.history.response.DayDataResponse.DataBean>> a(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("deviceID") java.lang.String r2, @retrofit2.http.Query("startTime") java.lang.String r3, @retrofit2.http.Query("endTime") java.lang.String r4);
    @retrofit2.http.POST("scenarioautomation/aircleaner/addTask")
    io.reactivex.d<com.phicomm.aircleaner.models.task.beans.TaskResponse> a(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("deviceId") java.lang.String r2, @retrofit2.http.Query("name") java.lang.String r3, @retrofit2.http.Query("mode") java.lang.String r4, @retrofit2.http.Query("customMode") java.lang.String r5, @retrofit2.http.Query("repeatMode") java.lang.String r6, @retrofit2.http.Query("startTime") java.lang.String r7, @retrofit2.http.Query("endTime") java.lang.String r8);
    @retrofit2.http.POST("scenarioautomation/aircleaner/modifyTask")
    io.reactivex.d<com.phicomm.aircleaner.models.task.beans.TaskResponse> a(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("deviceId") java.lang.String r2, @retrofit2.http.Query("taskId") java.lang.String r3, @retrofit2.http.Query("name") java.lang.String r4, @retrofit2.http.Query("mode") java.lang.String r5, @retrofit2.http.Query("customMode") java.lang.String r6, @retrofit2.http.Query("repeatMode") java.lang.String r7, @retrofit2.http.Query("startTime") java.lang.String r8, @retrofit2.http.Query("endTime") java.lang.String r9);
    @retrofit2.http.GET("aircleaner/getIndexData")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse<com.phicomm.aircleaner.models.home.beans.DeviceResponse>> b(@retrofit2.http.Header("Authorization") java.lang.String r1);
    @retrofit2.http.GET("aircleaner/getDeviceData")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse<com.phicomm.aircleaner.models.home.beans.Device>> b(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("deviceID") java.lang.String r2);
    @retrofit2.http.POST("aircleaner/setChildLock")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse> b(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("deviceID") java.lang.String r2, @retrofit2.http.Query("childLock") java.lang.String r3);
    @retrofit2.http.GET("aircleaner/countData_day_hour")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse<com.phicomm.aircleaner.models.history.response.DayDataResponse.DataBean>> b(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("deviceID") java.lang.String r2, @retrofit2.http.Query("startTime") java.lang.String r3, @retrofit2.http.Query("endTime") java.lang.String r4);
    @retrofit2.http.GET("aircleaner/getDeviceStatus")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse> c(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("deviceID") java.lang.String r2);
    @retrofit2.http.POST("aircleaner/setDeviceMode")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse> c(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("deviceID") java.lang.String r2, @retrofit2.http.Query("mode") java.lang.String r3);
    @retrofit2.http.GET("aircleaner/countData_month")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse<com.phicomm.aircleaner.models.history.response.MonthDataResponse.DataBean>> c(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("deviceID") java.lang.String r2, @retrofit2.http.Query("startTime") java.lang.String r3, @retrofit2.http.Query("endTime") java.lang.String r4);
    @retrofit2.http.POST("aircleaner/resetFilter")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse> d(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("deviceID") java.lang.String r2);
    @retrofit2.http.POST("aircleaner/windSpeed")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse> d(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("deviceID") java.lang.String r2, @retrofit2.http.Query("windSpeed") java.lang.String r3);
    @retrofit2.http.GET("scenarioautomation/aircleaner/getTaskList")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse<java.util.List<com.phicomm.aircleaner.models.task.beans.TimerTask>>> e(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("deviceId") java.lang.String r2);
    @retrofit2.http.POST("scenarioautomation/aircleaner/delTask")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse> e(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("deviceId") java.lang.String r2, @retrofit2.http.Query("taskId") java.lang.String r3);
    @retrofit2.http.GET("scenarioautomation/aircleaner/getTask")
    io.reactivex.d<com.phicomm.aircleaner.common.http.client.BaseResponse<com.phicomm.aircleaner.models.task.beans.TimerTask>> f(@retrofit2.http.Header("Authorization") java.lang.String r1, @retrofit2.http.Query("taskId") java.lang.String r2);
设备开关及模式
public class AircleanDevice extends com.phicomm.aircleaner.models.home.beans.CatDevice {
    public static java.lang.String MODE_AUTO = "3";
    public static java.lang.String MODE_EFFIECT = "5";
    public static java.lang.String MODE_HAND = "2";
    public static java.lang.String MODE_OFF = "0";
    public static java.lang.String MODE_ON = "1";
    public static java.lang.String MODE_SLEEP = "4";
示例(HTTP POST):
https://aircleaner.phicomm.com/aircleaner/windSpeed?windSpeed=30&deviceID=30-B0:F8:93:AA:AA:AA&access_token=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.eyJ1aWQiOiI4NTk5MjE5MyIsImNvZGUiOiJmZWl4dW4uU0hfMSIsInR5cGUiOiJhY2Nlc3NfdG9rZW4iLCJpc3MiOiJQaGljb21tIiwibmJmIjoxNTIxOTE2MDYyLCJleHAiOjE1MjI0MzQ0NjIsInJlZnJlc2hUaW1lIjoiMjAxOC0wMy0yNyAwMjoyNzo0MiJ9.u94PBisQ8LeQstmo2cvoZdyKihVoTwlyYZFq_HyQIgY
执行后会将风速设置为最小。
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-3-25 10:56:47 | 显示全部楼层
666,期待插件~~~
活跃会员教程狂人
发表于 2018-3-25 11:19:43 | 显示全部楼层
希望大神顺便把体脂称也搞搞,哈哈哈哈。
所有过往,皆为序章。
发表于 2018-3-25 11:24:12 | 显示全部楼层
希望大神顺便把体脂称也搞搞,哈哈哈哈。
发表于 2018-3-25 11:24:45 | 显示全部楼层
A1不是早有插件了么?还是抓抓体脂秤吧
27hh
教程狂人论坛风云人物
 楼主| 发表于 2018-3-25 11:26:48 | 显示全部楼层
Jones 发表于 2018-3-25 11:24
A1不是早有插件了么?还是抓抓体脂秤吧
啊???我没找到啊,是发群里了?这是净化器,不是检测器。
发表于 2018-3-25 11:56:59 | 显示全部楼层
噢,净化器啊,那可能没有。
发表于 2018-3-26 15:45:50 | 显示全部楼层
A1不是早有插件了么?还是抓抓体脂秤吧
那是M1吧
发表于 2018-3-26 15:58:36 | 显示全部楼层
是的,我看错了。
发表于 2018-3-26 17:12:56 | 显示全部楼层
求分享抓包分过程。。
GMT+8, 2026-1-10 12:29 , Processed in 1.508176 second(s), 7 queries , MemCached On.
