查看: 7437|回复: 2
Tasmota无法接入,有经验的帮我一下
aaa
34
发表于 2018-3-24 14:16:17 | 显示全部楼层 |阅读模式
设置方法
https://bbs.hassbian.com/forum.php?mod=viewthread&tid=419&highlight=Tasmota
日志
Setup failed for light/switch: Component not found.
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午2:06 setup.py (ERROR)
Unable to find component light/switch
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午2:06 loader.py (ERROR)
Ended unfinished session (id=37 from 2018-03-24 05:55:23.149395)
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午2:05 components/recorder/__init__.py (WARNING)
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))] 屏幕截图(23).png
configuration.yaml
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]配置如下
light/switch:
  - platform: mqtt
    state_topic: "stat/S1/POWER"
    command_topic: "cmnd/S1/POWER"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))] 屏幕截图(21).png
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))] 屏幕截图(25).png
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]Mosquitto broker
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))][color=var(--paper-card-header-color, #000)]Log
starting version 3.2.21521871503: mosquitto version 1.4.12 (build date 2017-06-01 13:03:48+0000) starting1521871503: Config loaded from /etc/mosquitto.conf.1521871503: Opening ipv4 listen socket on port 1883.1521871503: Opening ipv6 listen socket on port 1883.1521871503: Warning: Mosquitto should not be run as root/administrator.1521871513: New connection from 192.168.70.8 on port 1883.1521871513: New client connected from 192.168.70.8 as DVES_86F8C3 (c1, k15, u'testuser').
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]请问哪里出了问题?
发表于 2018-3-24 17:02:33 | 显示全部楼层
light/switch:
只能选其一
light:
switch:
aaa
34
 楼主| 发表于 2018-3-24 19:32:22 | 显示全部楼层
感谢指导,我去试一下,连最简单的添加设备都卡半天
GMT+8, 2026-1-4 13:57 , Processed in 0.429423 second(s), 9 queries , MemCached On.
