楼主: lidicn
[插件集成] 我伙呆【device_tracker】【时间记录器】
发表于 2018-10-25 00:17:52 | 显示全部楼层
多谢分享!
myxu 手机认证
发表于 2018-10-25 00:22:16 | 显示全部楼层
学习  学习
发表于 2018-11-1 14:51:54 | 显示全部楼层
谢谢分享
发表于 2018-11-4 13:55:16 | 显示全部楼层
学习学习
发表于 2018-11-4 17:51:14 | 显示全部楼层
好厉害!
发表于 2018-11-4 20:26:48 | 显示全部楼层
大佬,找你的帖子配置好了,刚开始几个徽章都出现了,显示“无法......”。我不知道懂了哪里,然后徽章全没了,但是历史记录还有。
log如下(请无视博联报错
2018-11-04 11:58:09 WARNING (MainThread) [homeassistant.loader] You are using a custom component for sensor.record_time which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-11-04 11:58:11 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform record_time
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
    return fut.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
    result = coro.send(None)
  File "/home/homeassistant/.homeassistant/custom_components/sensor/record_time.py", line 71, in async_setup_platform
    yield from data.async_update()
  File "/usr/lib/python3.5/asyncio/coroutines.py", line 210, in coro
    res = func(*args, **kw)
  File "/home/homeassistant/.homeassistant/custom_components/sensor/record_time.py", line 237, in async_update
    record_time_data = json.load(file_data)
  File "/usr/lib/python3.5/json/__init__.py", line 268, in load
    parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
  File "/usr/lib/python3.5/json/__init__.py", line 319, in loads
    return _default_decoder.decode(s)
  File "/usr/lib/python3.5/json/decoder.py", line 339, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/lib/python3.5/json/decoder.py", line 357, in raw_decode
    raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
2018-11-04 12:01:52 ERROR (Thread-14) [homeassistant.loader] Error loading custom_components.switch.broadlink_mp1. Make sure all dependencies are installed
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/loader.py", line 92, in get_component
    module = importlib.import_module(path)
  File "/usr/lib/python3.5/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 986, in _gcd_import
  File "<frozen importlib._bootstrap>", line 969, in _find_and_load
  File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 673, in exec_module
  File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_removed
  File "/home/homeassistant/.homeassistant/custom_components/switch/broadlink_mp1.py", line 19, in <module>
    from broadlink import mp1 as BroadlinkMP1Device
这几个设一个组就正常。是我哪里理解错了么......
发表于 2018-11-4 21:16:35 | 显示全部楼层
这个真的很棒了
发表于 2018-11-5 10:55:52 | 显示全部楼层
学习一下。
lp49 手机认证
发表于 2018-11-7 13:03:21 | 显示全部楼层
多谢lz 下载试试
发表于 2018-11-7 13:18:22 | 显示全部楼层
多翻翻L大 帖子,总有收获!
GMT+8, 2026-1-19 07:12 , Processed in 0.946965 second(s), 13 queries , MemCached On.
