查看: 3136|回复: 1
[技术探讨] MPD播放器崩溃 如何解决??
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-3-22 21:39:09 | 显示全部楼层 |阅读模式
INFO     Starting Mopidy 2.1.0
INFO     Loading config from builtin defaults
INFO     Loading config from /var/lib/mopidy/.config/mopidy/mopidy.conf
INFO     Loading config from command line options
INFO     Creating dir /root/.config/mopidy
INFO     Enabled extensions: mpd, http, file, stream, m3u, softwaremixer, moped, local, local-sqlite
INFO     Disabled extensions: spotify, gmusic
WARNING  Found gmusic configuration errors, the extension has been automatically disabled:
WARNING    gmusic/username must be set.
WARNING    gmusic/password must be set.
WARNING  Found spotify configuration errors, the extension has been automatically disabled:
WARNING    spotify/username must be set.
WARNING    spotify/client_secret must be set.
WARNING    spotify/password must be set.
WARNING    spotify/client_id must be set.
WARNING  Please fix the extension configuration errors or disable the extensions to silence these messages.
INFO     Found 1 files in media_dir.
INFO     Checking 1 tracks from library.
INFO     Removing 0 missing tracks.
INFO     Found 0 tracks which need to be updated.
INFO     Scanning...
INFO     Scanned 0 of 0 files in 0s.
INFO     Done scanning.
INFO     Starting Mopidy mixer: SoftwareMixer
INFO     Starting Mopidy audio
INFO     Starting Mopidy backends: StreamBackend, M3UBackend, FileBackend, LocalBackend
INFO     Audio output set to "autoaudiosink"
INFO     Loaded 1 local tracks using sqlite
INFO     Starting Mopidy core
INFO     Starting Mopidy frontends: MpdFrontend, HttpFrontend
INFO     MPD server running at [::ffff:0.0.0.0]:6600
INFO     HTTP server running at [::ffff:0.0.0.0]:6680
INFO     Starting GLib mainloop
INFO     New MPD connection from [::ffff:192.168.31.244]:47532
INFO     New MPD connection from [::ffff:192.168.31.244]:48252
INFO     New MPD connection from [::ffff:192.168.31.244]:50652
INFO     New MPD connection from [::ffff:192.168.31.244]:50674
INFO     New MPD connection from [::ffff:192.168.31.244]:50696
INFO     New MPD connection from [::ffff:192.168.31.244]:50718
INFO     New MPD connection from [::ffff:192.168.31.244]:50742
INFO     New MPD connection from [::ffff:192.168.31.244]:50762
INFO     New MPD connection from [::ffff:192.168.31.244]:50784
INFO     New MPD connection from [::ffff:192.168.31.244]:50802
INFO     New MPD connection from [::ffff:192.168.31.244]:50822
INFO     New MPD connection from [::ffff:192.168.31.244]:50844
INFO     New MPD connection from [::ffff:192.168.31.244]:50862
INFO     New MPD connection from [::ffff:192.168.31.244]:50884
INFO     New MPD connection from [::ffff:192.168.31.244]:50908
INFO     New MPD connection from [::ffff:192.168.31.244]:50926
INFO     New MPD connection from [::ffff:192.168.31.244]:50944
INFO     New MPD connection from [::ffff:192.168.31.244]:50966
INFO     New MPD connection from [::ffff:192.168.31.244]:50986
INFO     New MPD connection from [::ffff:192.168.31.244]:51006
INFO     New MPD connection from [::ffff:192.168.31.244]:51028
WARNING  Rejected connection from [::ffff:192.168.31.244]:51052
WARNING  Rejected connection from [::ffff:192.168.31.244]:51068
WARNING  Rejected connection from [::ffff:192.168.31.244]:51088
WARNING  Rejected connection from [::ffff:192.168.31.244]:51140
WARNING  Rejected connection from [::ffff:192.168.31.244]:51196
WARNING  Rejected connection from [::ffff:192.168.31.244]:51214
WARNING  Rejected connection from [::ffff:192.168.31.244]:51238
WARNING  Rejected connection from [::ffff:192.168.31.244]:51258
WARNING  Rejected connection from [::ffff:192.168.31.244]:51276
WARNING  Rejected connection from [::ffff:192.168.31.244]:51296
WARNING  Rejected connection from [::ffff:192.168.31.244]:51318
WARNING  Rejected connection from [::ffff:192.168.31.244]:51336
WARNING  Rejected connection from [::ffff:192.168.31.244]:51358
WARNING  Rejected connection from [::ffff:192.168.31.244]:51376
WARNING  Rejected connection from [::ffff:192.168.31.244]:51396
WARNING  Rejected connection from [::ffff:192.168.31.244]:51416
WARNING  Rejected connection from [::ffff:192.168.31.244]:51438
WARNING  Rejected connection from [::ffff:192.168.31.244]:51458
WARNING  Rejected connection from [::ffff:192.168.31.244]:51476
WARNING  Rejected connection from [::ffff:192.168.31.244]:51496
WARNING  Rejected connection from [::ffff:192.168.31.244]:51516
WARNING  Rejected connection from [::ffff:192.168.31.244]:51538
WARNING  Rejected connection from [::ffff:192.168.31.244]:51560
WARNING  Rejected connection from [::ffff:192.168.31.244]:51594
WARNING  Rejected connection from [::ffff:192.168.31.244]:51622
这是LOG。 为什么总是不停的扫描这么多的端口???而且现在是不可用状态
发表于 2018-3-23 23:40:33 | 显示全部楼层
一样的问题,大神指导!
GMT+8, 2026-1-4 13:57 , Processed in 0.492570 second(s), 6 queries , MemCached On.
