楼主: gexing147
[基础教程] 博联BroadLink RM PRO RF CODE(射频码)学习
发表于 2018-6-17 19:08:41 | 显示全部楼层
看一下解决办法!!!
发表于 2018-6-18 14:11:05 | 显示全部楼层
学习学习!!!
发表于 2018-6-18 14:24:03 | 显示全部楼层
跟着大神进步
发表于 2018-6-18 21:06:28 | 显示全部楼层
kankan正找教材
发表于 2018-6-18 22:21:05 | 显示全部楼层
学习一下
发表于 2018-6-19 22:36:16 | 显示全部楼层
正需要,学习了
发表于 2018-6-19 23:03:19 | 显示全部楼层
q913794286 发表于 2018-4-2 19:02
一个大坑,学习射频码要长按遥控器,所以博联的设备根本无法接入Ha
这个真是 大坑吗, lz 怎么也不过来澄清一下 哦
发表于 2018-6-20 00:12:05 | 显示全部楼层
学习怎么识别
发表于 2018-6-20 01:09:40 | 显示全部楼层
bash-4.4# pip3 install pyaes
Collecting pyaes
  Retrying (Retry(total=4, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0xb65f1f6c>: Failed to establish a new connection: [Errno -3] Try again',)': /simple/pyaes/
  Retrying (Retry(total=3, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0xb65f1b4c>: Failed to establish a new connection: [Errno -3] Try again',)': /simple/pyaes/
  Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0xb65f15cc>: Failed to establish a new connection: [Errno -3] Try again',)': /simple/pyaes/
  Retrying (Retry(total=1, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0xb65f182c>: Failed to establish a new connection: [Errno -3] Try again',)': /simple/pyaes/
  Retrying (Retry(total=0, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<pip._vendor.requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0xb65f1a2c>: Failed to establish a new connection: [Errno -3] Try again',)': /simple/pyaes/
小白,搞不明白,请教怎么处理
发表于 2018-6-20 11:30:22 来自手机 | 显示全部楼层
学习了 万分感谢
GMT+8, 2026-1-15 06:50 , Processed in 0.284906 second(s), 17 queries , MemCached On.
