小米多功能智能网关1代,摔后无法正常开机,刷机后日志如下,救各路大神指点,在此先谢谢了!!!!!!
uart ok
strap pin:0x416b8ae2
enable spi-nand
ROM ver:v1.1, sig:455cc27, time:2016.01.04-18:42+0800, CPU(400 MHz), DDR2(533 M Hz)
load efuse ok
init IP ok
rom_progress: 0x0600006d
load_data_from_storage(260): 0xbfe01540, 0x00000000, 0xbfd16f44
load_data_from_spi_nand_flash(70): 0xbfe01540, 0x00000000, 0xbfe03e18
check_image_header(72): h(69,72,61,6d), s(69,72,61,6d)
img sig ok
rom_progress: 0x0c00006d
load_data_from_spi_nand_flash(81) 0x00000004 0x000024ba
load_data_from_spi_nand_flash(86): 0xbfe01d40, 0x00000001, 0xbfe03e18
load_data_from_spi_nand_flash(86): 0xbfe02540, 0x00000002, 0xbfe03e18
load_data_from_spi_nand_flash(86): 0xbfe02d40, 0x00000003, 0xbfe03e18
load_data_from_spi_nand_flash(86): 0xbfe03540, 0x00000004, 0xbfe03e18
load_data_from_spi_nand_flash(90) read done (size:9402)
chksum ok
rom_progress: 0x0e00006d
load img ok
rom_progress: 0x1000006d
jump 0xbfe01550
Booting...
SPI NAND clock not enable
SPI Nand ID=00efaa21
SPI Nand die chipsize=0x08000000 byte
SPI Nand dienum=1,
SPI Nand blocksize=0x00020000 byte,
SPI Nand pagesize=0x00000800 byte,
SPI Nand oobsize=0x00000040 byte,
[rtkn_scan_bbt, line 1812], RBA=51, this->RBA_PERCENT = 5,block_v2r_num=1024
[rtkn_scan_bbt, line 1822] block_v2r_num 00000400
[rtk_scan_v2r_bbt]:678,RBA=00000033,2=00000400,
[rtk_scan_v2r_bbt]:684,block_v2r_num=000003cd
INFO: Stored BBT in Die 0: block=8 , block_status_p1=0x000000bb
load bbt v2r table:0 page:512
[rtk_scan_v2r_bbt] have created v2r bbt table:0 on block 8, just loads it !!
check v2r bbt table:0 OK
[rtk_nand_scan_bbt, line 393] mem_page_num=1 bbt_page 704
INFO: Stored BBT in Die 0: block=11 , block_status_p1=0x000000bb
load bbt table:0 page:704
[rtk_nand_scan_bbt] have created bbt table:0 on block 11, just loads it !!
check bbt table:0 OK
[dump_BBT] Nand BBT Content
[0] (00000000, 00000278, 00000000, 000003ff)
[1] (00000000, 000002b8, 00000000, 000003fe)
[2] (00000000, 0000023c, 00000000, 000003fd)
[3] (00000000, 000003fd, 00000000, 000003fc)
[4] (00000000, 00000366, 00000000, 000003fb)
[5] (00000000, 00000299, 00000000, 000003fa)
[6] (00000000, 000000f9, 00000000, 000003f9)
[7] (00000000, 000000fa, 00000000, 000003f8)
[8] (00000000, 000000ff, 00000000, 000003f7)
[9] (00000000, 00000013, 00000000, 000003f6)
[10] (00000000, 00000018, 00000000, 000003f5)
[11] (00000000, 00000019, 00000000, 000003f4)
[12] (00000000, 000000f0, 00000000, 000003f3)
[13] (00000000, 000000f1, 00000000, 000003f2)
[14] (00000000, 000000f2, 00000000, 000003f1)
[15] (00000000, 00000020, 00000000, 000003f0)
[16] (00000000, 00000011, 00000000, 000003ef)
[17] (00000000, 00000012, 00000000, 000003ee)
=>CPU Wake-up interrupt happen! GISR=09000084
Reboot Result from Watchdog Timeout!
Realtek RTL8197F boot code at 2020.09.17-17:27+0800 v3.4T-pre2.1 (993MHz)
-- version: 1.0.2.005 --
Info: Load boot_info success!
=== bootloader for mijia_gw ===
boot_info: ver:0
kernel: newest:0, curr:0
rootfs: newest:0, curr:0
kernel[0]: sum:0xcb5b, size:2157572, fail:0
[1]: sum:0xcb5b, size:2157572, fail:0
rootfs[0]: sum:0x0204, size:13377538, fail:0
[1]: sum:0x0204, size:13377538, fail:0
root_sum_check: off
watchdog_time: 0
boot_version: 1.0.2.005
priv mode
Info: loading kernel 0 ... Done
Info: checking kernel 0 ... Success
Info: select rootfs 0
Info: booting...
Jump to image start=0x80a00000...
decompressing kernel:
Uncompressing Linux... done, booting the kernel.
done decompressing kernel.
start address: 0x8050ca80
[ 0.000000] Linux version 3.10.90 (luobo@compilex64-ipg) (gcc version 4.9.4 20151028 (prerelease)
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 00019385 (MIPS 24Kc)
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x00000000-0x03ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00000000-0x03ffffff]
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4088
[ 0.000000] Kernel command line: root=/dev/mtdblock6 console=ttyS0,38400
[ 0.000000] PID hash table entries: 256 (order: -4, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 1, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 0, 16384 bytes)
[ 0.000000] Writing ErrCtl register=0002be70
[ 0.000000] Readback ErrCtl register=0002be70
[ 0.000000] Memory: 58208k/65536k available (5203k kernel code, 7328k reserved, 1003k data, 192k i
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:192
[ 0.000000] Realtek GPIO IRQ init
[ 0.000000] Calibrating delay loop... 660.68 BogoMIPS (lpj=3303424)
[ 0.070000] pid_max: default: 32768 minimum: 301
[ 0.080000] Mount-cache hash table entries: 2048
[ 0.090000] [rtl819x_gpio_pin_enable][277]: mask=0xf00 mux=0x0 mux_reg=0xb8000844 val=0x100,
[ 0.100000] [rtl819x_gpio_direction_output][150]: set pin38 as output pin, default value=0, DIR_RE
[ 0.110000] [rtl819x_gpio_pin_enable][277]: mask=0xf0 mux=0x100 mux_reg=0xb8000844 val=0x10,
[ 0.120000] [rtl819x_gpio_direction_output][150]: set pin39 as output pin, default value=0, DIR_RE
[ 0.130000] [rtl819x_gpio_pin_enable][277]: mask=0xf000000 mux=0x0 mux_reg=0xb8000848 val=0x400000
[ 0.140000] [rtl819x_gpio_direction_output][150]: set pin42 as output pin, default value=0, DIR_RE
[ 0.150000] [rtl819x_gpio_pin_enable][277]: mask=0xf00000 mux=0x4000000 mux_reg=0xb8000848 val=0x4
[ 0.160000] [rtl819x_gpio_direction_output][150]: set pin43 as output pin, default value=1, DIR_RE
[ 0.170000] [rtl819x_gpio_pin_enable][277]: mask=0xf0000 mux=0x4400000 mux_reg=0xb8000848 val=0x60
[ 0.180000] [rtl819x_gpio_direction_output][150]: set pin44 as output pin, default value=1, DIR_RE
[ 0.190000] [rtl819x_gpio_pin_enable][277]: mask=0xf000 mux=0x4460000 mux_reg=0xb8000848 val=0x600
[ 0.200000] [rtl819x_gpio_direction_output][150]: set pin45 as output pin, default value=1, DIR_RE
[ 0.210000] [rtl819x_gpio_pin_enable][277]: mask=0xf000000 mux=0x11111000 mux_reg=0xb8000820 val=0
[ 0.220000] [rtl819x_gpio_direction_output][150]: set pin46 as output pin, default value=1, DIR_RE
[ 0.230000] [rtl819x_gpio_pin_enable][277]: mask=0xf0000000 mux=0x16111000 mux_reg=0xb8000820 val=
[ 0.240000] [rtl819x_gpio_direction_output][150]: set pin47 as output pin, default value=0, DIR_RE
[ 0.250000] [rtl819x_gpio_pin_enable][277]: mask=0xf00000 mux=0x66111000 mux_reg=0xb8000820 val=0x
[ 0.260000] [rtl819x_gpio_direction_output][150]: set pin48 as output pin, default value=1, DIR_RE
[ 0.270000] [rtl819x_gpio_pin_enable][277]: mask=0xf0000 mux=0x66611000 mux_reg=0xb8000820 val=0x7
[ 0.280000] [rtl819x_gpio_direction_output][150]: set pin49 as output pin, default value=1, DIR_RE
[ 0.290000] [rtl819x_gpio_pin_enable][277]: mask=0xf000 mux=0x66671000 mux_reg=0xb8000820 val=0x70
[ 0.300000] [rtl819x_gpio_direction_output][150]: set pin50 as output pin, default value=0, DIR_RE
[ 0.310000] [rtl819x_gpio_pin_enable][277]: mask=0xf0000000 mux=0x100000 mux_reg=0xb8000824 val=0x
[ 0.320000] [rtl819x_gpio_direction_output][150]: set pin51 as output pin, default value=1, DIR_RE
[ 0.330000] [rtl819x_gpio_pin_enable][277]: mask=0xf000000 mux=0x20100000 mux_reg=0xb8000824 val=0
[ 0.340000] [rtl819x_gpio_direction_output][150]: set pin52 as output pin, default value=0, DIR_RE
[ 0.350000] [rtl819x_gpio_pin_enable][277]: mask=0xf00000 mux=0x21100000 mux_reg=0xb8000824 val=0x
[ 0.360000] [rtl819x_gpio_direction_output][150]: set pin53 as output pin, default value=0, DIR_RE
[ 0.370000] [rtl819x_gpio_pin_enable][277]: mask=0xf000000 mux=0x33320000 mux_reg=0xb8000834 val=0
[ 0.380000] [rtl819x_gpio_direction_output][150]: set pin55 as output pin, default value=0, DIR_RE
[ 0.390000] NET: Registered protocol family 16
[ 0.400000] <<<<<Register PCI Controller>>>>>
[ 0.420000] Do MDIO_RESET
[ 0.450000] 40MHz
