查看: 45|回复: 2
[求助] 大家遇到过国网docker获取不到月度信息的问题吗?
发表于 昨天 16:54 | 显示全部楼层 |阅读模式
飞牛部署的sgcc_electricity_new的容器,获得不到月度的信息,是怎么回事呢?
2026-01-13 16:08:22  [INFO    ] ---- Click login button.
2026-01-13 16:08:23  [INFO    ] ---- Get electricity canvas image successfully.
2026-01-13 16:08:23  [INFO    ] ---- Image CaptCHA distance is 85.
2026-01-13 16:08:45  [INFO    ] ---- login successed !
2026-01-13 16:08:45  [INFO    ] ---- Login successfully on https://95598.cn/osgweb/login
2026-01-13 16:09:05  [INFO    ] ---- Try to get the userid list
2026-01-13 16:11:12  [INFO    ] ---- Here are a total of 1 userids, which are ['xxxxxxxxxx'] among which ['xxxxxxx', 'xxxxxxx', 'xxxxxxx'] will be ignored.
2026-01-13 16:13:58  [INFO    ] ---- Get electricity charge balance for xxxxxxxxxx successfully, balance is 132.27 CNY.
2026-01-13 16:17:27  [INFO    ] ---- Get year power usage for xxxxxxxxxx successfully, usage is 12367 kwh
2026-01-13 16:17:27  [INFO    ] ---- Get year power charge for xxxxxxxxxx successfully, yealrly charge is 5121.79 CNY
2026-01-13 16:18:51  [INFO    ] ---- Get daily power consumption for xxxxxxxxxx successfully, , 2026-01-11 usage is 86.21 kwh.
2026-01-13 16:18:51  [INFO    ] ---- enable_database_storage is true, we will store the data to the database.
2026-01-13 16:19:36  [INFO    ] ---- Database of /data/homeassistant.db created successfully.
2026-01-13 16:19:36  [INFO    ] ---- Table dailyxxxxxxxxxx created successfully
2026-01-13 16:19:36  [INFO    ] ---- Table dataxxxxxxxxxx created successfully
2026-01-13 16:19:36  [INFO    ] ---- The electricity consumption of 86.21KWh on 2026-01-11 has been successfully deposited into the database
2026-01-13 16:19:36  [INFO    ] ---- The electricity consumption of 83.51KWh on 2026-01-10 has been successfully deposited into the database
2026-01-13 16:19:36  [INFO    ] ---- The electricity consumption of 76.98KWh on 2026-01-09 has been successfully deposited into the database
2026-01-13 16:19:36  [INFO    ] ---- The electricity consumption of 82.43KWh on 2026-01-08 has been successfully deposited into the database
2026-01-13 16:19:36  [INFO    ] ---- The electricity consumption of 81.49KWh on 2026-01-07 has been successfully deposited into the database
2026-01-13 16:19:36  [INFO    ] ---- The electricity consumption of 74.07KWh on 2026-01-06 has been successfully deposited into the database
2026-01-13 16:19:36  [INFO    ] ---- Check the electricity bill balance, the notification will be sent = False
2026-01-13 16:19:36  [INFO    ] ---- Homeassistant sensor sensor.electricity_charge_balance_xxxx state updated: 132.27 CNY
2026-01-13 16:19:36  [INFO    ] ---- Homeassistant sensor sensor.last_electricity_usage_xxxx state updated: 86.21 kWh
2026-01-13 16:19:36  [INFO    ] ---- Homeassistant sensor sensor.yearly_electricity_usage_xxxxstate updated: 12367 kWh
2026-01-13 16:19:36  [INFO    ] ---- Homeassistant sensor sensor.yearly_electricity_charge_xxxx state updated: 5121.79 CNY
2026-01-13 16:19:36  [INFO    ] ---- User xxxxxxxxxx state-refresh task run successfully!
日志中也没有获取月度信息的操作,我看github上有人在issu中也提出来了,这个只能等作者修复了吗?
发表于 昨天 19:42 | 显示全部楼层
青龙面板未发现这个问题
 楼主| 发表于 昨天 22:00 | 显示全部楼层
xhack123 发表于 2026-1-13 19:42
青龙面板未发现这个问题
github上反馈问题那个人有三个户号,有一个户号能显示月度信息,另外两个不能显示,现在不知道具体是什么问题。
GMT+8, 2026-1-14 01:31 , Processed in 0.823465 second(s), 10 queries , MemCached On.
