"id": "67fafcba2cd5e482",
"type": "tab",
"label": "当贝投影机",
"disabled": false,
"info": "",
"env": []
"id": "688be89a7397e2d3",
"type": "websocket out",
"z": "67fafcba2cd5e482",
"name": "",
"server": "",
"client": "3180962faa6346b6",
"x": 970,
"y": 220,
"wires": []
"id": "e59a4c1570fccf65",
"type": "function",
"name": "上",
"func": "msg.payload = {\n "sn": "",\n "data": {\n "command": {\n "value": "1", // 上\n "params": "",\n "command": "Operation",\n "from": 901\n },\n "toDeviceId": "0ba06e873c33b0d25fc64896c9cd6a45"\n },\n "toId": "fczAs/bZ2lc=",\n "fromId": "tYbuTOjizjQ=",\n "type": "HB7FxtN64oc="\n};\n\nreturn msg;\n",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 490,
"y": 100,
"wires": [
"688be89a7397e2d3"
"id": "2776a6bb4194f4f1",
"type": "function",
"name": "下",
"func": "msg.payload = {\n "sn": "",\n "data": {\n "command": {\n "value": "2",\n "params": "",\n "command": "Operation",\n "from": 901\n },\n "toDeviceId": "0ba06e873c33b0d25fc64896c9cd6a45"\n },\n "toId": "fczAs/bZ2lc=",\n "fromId": "tYbuTOjizjQ=",\n "type": "HB7FxtN64oc="\n};\n\nreturn msg;\n",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 490,
"y": 140,
"wires": [
"688be89a7397e2d3"
"id": "d7bec04d72634021",
"type": "function",
"name": "左",
"func": "msg.payload = {\n "sn": "",\n "data": {\n "command": {\n "value": "3", // 上\n "params": "",\n "command": "Operation",\n "from": 901\n },\n "toDeviceId": "0ba06e873c33b0d25fc64896c9cd6a45"\n },\n "toId": "fczAs/bZ2lc=",\n "fromId": "tYbuTOjizjQ=",\n "type": "HB7FxtN64oc="\n};\n\nreturn msg;\n",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 490,
"y": 180,
"wires": [
"688be89a7397e2d3"
"id": "f82ebe924786783b",
"type": "function",
"name": "右",
"func": "msg.payload = {\n "sn": "",\n "data": {\n "command": {\n "value": "4", // 上\n "params": "",\n "command": "Operation",\n "from": 901\n },\n "toDeviceId": "0ba06e873c33b0d25fc64896c9cd6a45"\n },\n "toId": "fczAs/bZ2lc=",\n "fromId": "tYbuTOjizjQ=",\n "type": "HB7FxtN64oc="\n};\n\nreturn msg;\n",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 490,
"y": 220,
"wires": [
"688be89a7397e2d3"
"id": "cfdc68af61bbb6d1",
"type": "function",
"name": "ok",
"func": "msg.payload = {\n "sn": "",\n "data": {\n "command": {\n "value": "5", // 上\n "params": "",\n "command": "Operation",\n "from": 901\n },\n "toDeviceId": "0ba06e873c33b0d25fc64896c9cd6a45"\n },\n "toId": "fczAs/bZ2lc=",\n "fromId": "tYbuTOjizjQ=",\n "type": "HB7FxtN64oc="\n};\n\nreturn msg;\n",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 490,
"y": 260,
"wires": [
"688be89a7397e2d3"
"id": "e6c19af1a9616ffe",
"type": "function",
"name": "音量-",
"func": "msg.payload = {\n "sn": "",\n "data": {\n "command": {\n "value": "10", // 上\n "params": "",\n "command": "Operation",\n "from": 901\n },\n "toDeviceId": "0ba06e873c33b0d25fc64896c9cd6a45"\n },\n "toId": "fczAs/bZ2lc=",\n "fromId": "tYbuTOjizjQ=",\n "type": "HB7FxtN64oc="\n};\n\nreturn msg;\n",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 490,
"y": 300,
"wires": [
"688be89a7397e2d3"
"id": "aec30bf35ea3c0ab",
"type": "function",
"name": "音量+",
"func": "msg.payload = {\n "sn": "",\n "data": {\n "command": {\n "value": "9", // 上\n "params": "",\n "command": "Operation",\n "from": 901\n },\n "toDeviceId": "0ba06e873c33b0d25fc64896c9cd6a45"\n },\n "toId": "fczAs/bZ2lc=",\n "fromId": "tYbuTOjizjQ=",\n "type": "HB7FxtN64oc="\n};\n\nreturn msg;\n",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 490,
"y": 340,
"wires": [
"688be89a7397e2d3"
"id": "94d1bdf06b7090c4",
"type": "function",
"name": "菜单",
"func": "msg.payload = {\n "sn": "",\n "data": {\n "command": {\n "value": "8", // 上\n "params": "",\n "command": "Operation",\n "from": 901\n },\n "toDeviceId": "0ba06e873c33b0d25fc64896c9cd6a45"\n },\n "toId": "fczAs/bZ2lc=",\n "fromId": "tYbuTOjizjQ=",\n "type": "HB7FxtN64oc="\n};\n\nreturn msg;\n",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 490,
"y": 380,
"wires": [
"688be89a7397e2d3"
"id": "ef684200141d4a78",
"type": "function",
"name": "home",
"func": "msg.payload = {\n "sn": "",\n "data": {\n "command": {\n "value": "7", // 上\n "params": "",\n "command": "Operation",\n "from": 901\n },\n "toDeviceId": "0ba06e873c33b0d25fc64896c9cd6a45"\n },\n "toId": "fczAs/bZ2lc=",\n "fromId": "tYbuTOjizjQ=",\n "type": "HB7FxtN64oc="\n};\n\nreturn msg;\n",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 490,
"y": 420,
"wires": [
"688be89a7397e2d3"
"id": "feb09b19e6edc1e1",
"type": "function",
"name": "返回",
"func": "msg.payload = {\n "sn": "",\n "data": {\n "command": {\n "value": "6", // 上\n "params": "",\n "command": "Operation",\n "from": 901\n },\n "toDeviceId": "0ba06e873c33b0d25fc64896c9cd6a45"\n },\n "toId": "fczAs/bZ2lc=",\n "fromId": "tYbuTOjizjQ=",\n "type": "HB7FxtN64oc="\n};\n\nreturn msg;\n",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 490,
"y": 460,
"wires": [
"688be89a7397e2d3"
"id": "c8e55bd525393150",
"type": "function",
"name": "关闭",
"func": "msg.payload = {\n "sn": "",\n "data": {\n "command": {\n "value": "11", // 上\n "params": "",\n "command": "Operation",\n "from": 901\n },\n "toDeviceId": "0ba06e873c33b0d25fc64896c9cd6a45"\n },\n "toId": "fczAs/bZ2lc=",\n "fromId": "tYbuTOjizjQ=",\n "type": "HB7FxtN64oc="\n};\n\nreturn msg;\n",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 490,
"y": 500,
"wires": [
"2e595d4d88f6327e",
"688be89a7397e2d3"
"id": "2e595d4d88f6327e",
"type": "delay",
"name": "",
"pauseType": "delay",
"timeout": "2",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"allowrate": false,
"outputs": 1,
"x": 640,
"y": 500,
"wires": [
"7fad86779f8ac671"
"id": "7fad86779f8ac671",
"type": "function",
"name": "ok",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 770,
"y": 500,
"wires": [
"688be89a7397e2d3"
"id": "365b1b69986443ce",
"type": "mqtt in",
"name": "",
"topic": "danbei/ha",
"qos": "2",
"datatype": "auto-detect",
"broker": "506ce5dbba3051cf",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 100,
"y": 260,
"wires": [
"47c743d3a596f670",
"c6009a658123e513"
"id": "47c743d3a596f670",
"type": "switch",
"name": "",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "上",
"vt": "str"
"t": "eq",
"v": "下",
"vt": "str"
"t": "eq",
"v": "左",
"vt": "str"
"t": "eq",
"v": "右",
"vt": "str"
"t": "eq",
"v": "ok",
"vt": "str"
"t": "eq",
"v": "-",
"vt": "str"
"t": "eq",
"v": "+",
"vt": "str"
"t": "eq",
"v": "菜单",
"vt": "str"
"t": "eq",
"v": "home",
"vt": "str"
"t": "eq",
"v": "返回",
"vt": "str"
"t": "eq",
"v": "关闭",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 11,
"x": 250,
"y": 260,
"wires": [
"e59a4c1570fccf65",
"e23f6c10c7e22baf"
"2776a6bb4194f4f1"
"d7bec04d72634021"
"f82ebe924786783b"
"cfdc68af61bbb6d1"
"e6c19af1a9616ffe"
"aec30bf35ea3c0ab"
"94d1bdf06b7090c4"
"ef684200141d4a78"
"feb09b19e6edc1e1"
"c8e55bd525393150"
"id": "c6009a658123e513",
"type": "debug",
"name": "debug 4",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 180,
"y": 100,
"wires": []
"id": "e23f6c10c7e22baf",
"type": "debug",
"name": "debug 5",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 340,
"y": 40,
"wires": []
"id": "3180962faa6346b6",
"type": "websocket-client",
"path": "ws://192.168.68.215:6689",
"tls": "",
"wholemsg": "false",
"hb": "0",
"subprotocol": "",
"headers": []
"id": "506ce5dbba3051cf",
"type": "mqtt-broker",
"name": "",
"broker": "127.0.0.1",
"port": "1883",
"clientid": "",
"autoConnect": true,
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"autoUnsubscribe": true,
"birthTopic": "",
"birthQos": "0",
"birthRetain": "false",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closeRetain": "false",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willRetain": "false",
"willPayload": "",
"willMsg": {},
"userProps": "",
"sessionExpiry": ""
