查看: 27|回复: 0
[求助] 自己适配rk3399的板子tn3399-v3,core一直启动失败,请大佬指点
发表于 3 小时前 | 显示全部楼层 |阅读模式
编译的haos 16.3版本,初始化后自动重启core无法成功启动,日志没有什么有效信息,最新core12.2大概率一旦重启无法成功启动,手动ha core start偶尔可以启动成功,降级安装core10.3可以成功启动的概率提高,但还是偶尔会启动失败。是哪里的问题,请大佬指点。
硬件功能有线网卡、wifi、蓝牙正常,声卡在启动和关闭audio容器时会有个错误提示:
rt5640 1-001c: ASoC: error at snd_soc_dai_set_sysclk on rt5640-aif1: -22
[  205.543636] rt5640 1-001c: ASoC: error at snd_soc_dai_set_sysclk on rt5640-aif1: -22
core启动时错误提示:
Dec 08 13:46:19 homeassistant homeassistant[640]: services-up: info: copying legacy longrun home-assistant (no readiness notification)
Dec 08 13:46:20 homeassistant homeassistant[640]: s6-rc: info: service legacy-services successfully started
Dec 08 13:46:21 homeassistant audit[3512]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 subj=unconfined pid=3512 comm="python3" exe="/usr/local/bin/python3.13" sig=6 res=1
Dec 08 13:46:21 homeassistant systemd-coredump[3534]: Process 3512 (python3) of user 0 terminated abnormally with signal 6/ABRT, processing...
Dec 08 13:46:21 homeassistant audit: BPF prog-id=71 op=LOAD
Dec 08 13:46:21 homeassistant audit: BPF prog-id=72 op=LOAD
Dec 08 13:46:21 homeassistant audit: BPF prog-id=73 op=LOAD
Dec 08 13:46:21 homeassistant systemd[1]: Started Process Core Dump (PID 3534/UID 0).
Dec 08 13:46:21 homeassistant audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-coredump@2-3534-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 08 13:46:21 homeassistant systemd-timesyncd[627]: Network configuration changed, trying to establish connection.
Dec 08 13:46:22 homeassistant systemd-timesyncd[627]: Network configuration changed, trying to establish connection.
Dec 08 13:46:22 homeassistant systemd-timesyncd[627]: Contacted time server 203.107.6.88:123 (ntp.aliyun.com).
Dec 08 13:46:22 homeassistant systemd-coredump[3535]: Process 3512 (python3) of user 0 terminated abnormally without generating a coredump.
Dec 08 13:46:22 homeassistant systemd[1]: [email protected]: Deactivated successfully.
Dec 08 13:46:22 homeassistant audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-coredump@2-3534-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 08 13:46:22 homeassistant audit: BPF prog-id=73 op=UNLOAD
Dec 08 13:46:22 homeassistant audit: BPF prog-id=72 op=UNLOAD
Dec 08 13:46:22 homeassistant audit: BPF prog-id=71 op=UNLOAD
Dec 08 13:46:22 homeassistant homeassistant[640]: [05:46:22] INFO: Home Assistant Core finish process exit code 256
Dec 08 13:46:22 homeassistant homeassistant[640]: [05:46:22] INFO: Home Assistant Core finish process received signal 6
Dec 08 13:46:22 homeassistant homeassistant[640]: s6-rc: info: service legacy-services: stopping
Dec 08 13:46:22 homeassistant homeassistant[640]: s6-rc: info: service legacy-services successfully stopped
Dec 08 13:46:22 homeassistant homeassistant[640]: s6-rc: info: service legacy-cont-init: stopping
Dec 08 13:46:22 homeassistant homeassistant[640]: s6-rc: info: service legacy-cont-init successfully stopped
Dec 08 13:46:22 homeassistant homeassistant[640]: s6-rc: info: service fix-attrs: stopping
Dec 08 13:46:22 homeassistant homeassistant[640]: s6-rc: info: service fix-attrs successfully stopped
Dec 08 13:46:22 homeassistant homeassistant[640]: s6-rc: info: service s6rc-oneshot-runner: stopping
Dec 08 13:46:23 homeassistant homeassistant[640]: s6-rc: info: service s6rc-oneshot-runner successfully stopped
Dec 08 13:46:26 homeassistant systemd[1]: docker-8a5a2b219f7bd4dc321b2bd7acb94eb18487b66363ca49ad445420e071378b46.scope: Deactivated successfully.
Dec 08 13:46:26 homeassistant systemd[1]: docker-8a5a2b219f7bd4dc321b2bd7acb94eb18487b66363ca49ad445420e071378b46.scope: Consumed 2.562s CPU time, 56.3M memory peak, 400K written to disk.
Dec 08 13:46:26 homeassistant dockerd[640]: time="2025-12-08T05:46:26.107404033Z" level=info msg="ignoring event" container=8a5a2b219f7bd4dc321b2bd7acb94eb18487b66363ca49ad445420e071378b46 module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Dec 08 13:46:26 homeassistant containerd[578]: time="2025-12-08T05:46:26.107583410Z" level=info msg="shim disconnected" id=8a5a2b219f7bd4dc321b2bd7acb94eb18487b66363ca49ad445420e071378b46 namespace=moby
Dec 08 13:46:26 homeassistant containerd[578]: time="2025-12-08T05:46:26.107756953Z" level=info msg="cleaning up after shim disconnected" id=8a5a2b219f7bd4dc321b2bd7acb94eb18487b66363ca49ad445420e071378b46 namespace=moby
Dec 08 13:46:26 homeassistant containerd[578]: time="2025-12-08T05:46:26.107882955Z" level=info msg="cleaning up dead shim" id=8a5a2b219f7bd4dc321b2bd7acb94eb18487b66363ca49ad445420e071378b46 namespace=moby
Dec 08 13:46:26 homeassistant audit: BPF prog-id=70 op=UNLOAD
Dec 08 13:46:26 homeassistant systemd[1]: var-lib-docker-overlay2-bd5d40cfa872e396cdb8587119805d8791247622ebc2a3b05938ad7970c8b2d3-merged.mount: Deactivated successfully.
Dec 08 13:46:26 homeassistant systemd[1]: mnt-data-docker-overlay2-bd5d40cfa872e396cdb8587119805d8791247622ebc2a3b05938ad7970c8b2d3-merged.mount: Deactivated successfully.
Dec 08 13:46:29 homeassistant hassio_supervisor[640]: 2025-12-08 13:46:29.151 ERROR (MainThread) [supervisor.homeassistant.core] Home Assistant has crashed!
GMT+8, 2025-12-12 20:55 , Processed in 0.109302 second(s), 6 queries , MemCached On.
