查看: 432|回复: 2
[流程系列] 这个是什么错误啊sensor节点
发表于 2025-12-3 22:34:02 | 显示全部楼层 |阅读模式
[color=var(--red-ui-secondary-text-color-inactive)][color=var(--red-ui-debug-message-text-color-meta)]sg : error
errorname: "InputError"
message: "Integration not loaded"
stack: stringInputError: Integration not loaded    at S.onInput (/config/node_modules/node-red-contrib-home-assistant-websocket/dist/common/controllers/SensorBaseController.js:1:1203)    at S.#t (/config/node_modules/node-red-contrib-home-assistant-websocket/dist/common/controllers/InputOutputController.js:1:1264)    at /opt/node_modules/@node-red/runtime/lib/nodes/Node.js:214:26    at Object.trigger (/opt/node_modules/@node-red/util/lib/hooks.js:166:13)    at u.Node._emitInput (/opt/node_modules/@node-red/runtime/lib/nodes/Node.js:206:11)    at u.Node.emit (/opt/node_modules/@node-red/runtime/lib/nodes/Node.js:190:25)    at u.Node.receive (/opt/node_modules/@node-red/runtime/lib/nodes/Node.js:499:10)    at deliverMessageToDestination (/opt/node_modules/@node-red/runtime/lib/flows/Flow.js:817:40)    at Immediate.<anonymous> (/opt/node_modules/@node-red/runtime/lib/flows/Flow.js:833:21)    at processImmediate (node:internal/timers:485:21)
发表于 2025-12-4 11:36:56 | 显示全部楼层
把你的需求和目的+错误代码扔给ai。基本都能解决了
发表于 2025-12-4 17:04:32 | 显示全部楼层
emmm看起来像是HA那边没有配置好nodered集成
GMT+8, 2026-1-23 02:21 , Processed in 0.049545 second(s), 8 queries , MemCached On.
