楼主: 191442029
[技术讨论] 2025年11月24日更新ESP32 Heart Rate Gateway 分布式心率监测系统接入homeassistant
发表于 2025-11-4 20:33:40 | 显示全部楼层
2.82和另外一个不带的什么区别?
发表于 2025-11-4 21:58:59 | 显示全部楼层
编不下去了,各种报错,豆包说的 行数跟实际也不一样,搞不懂了
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino: In member function 'virtual void MyAdvertisedDeviceCallbacks::onResult(BLEAdvertisedDevice)':
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:190:64: error: conversion from 'String' to non-scalar type 'std::string' {aka 'std::__cxx11::basic_string<char>'} requested
  190 |       std::string addr = advertisedDevice.getAddress().toString();
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:195:41: error: no match for 'operator=' (operand types are 'std::string' {aka 'std::__cxx11::basic_string<char>'} and 'String')
  195 |         name = advertisedDevice.getName();
In file included from C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/string:54,
                 from C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/locale_classes.h:40,
                 from C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/ios_base.h:41,
                 from C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/ios:44,
                 from C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/ostream:40,
                 from C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/unique_ptr.h:43,
                 from C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/memory:78,
                 from C:\Users\����\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\Network\src/NetworkClient.h:24,
                 from C:\Users\����\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\Network\src/Network.h:12,
                 from C:\Users\����\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\WiFi\src/WiFiGeneric.h:44,
                 from C:\Users\����\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\WiFi\src/WiFiSTA.h:30,
                 from C:\Users\����\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\WiFi\src/WiFi.h:34,
                 from D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:81:
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:941:8: note: candidate: 'template<class _Tp> constexpr std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::_If_sv<_Tp, std::__cxx11::basic_string<_CharT, _Traits, _Alloc>&> std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::operator=(const _Tp&) [with _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>]'
  941 |        operator=(const _Tp& __svt)
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:941:8: note:   template argument deduction/substitution failed:
In file included from C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/stl_pair.h:60,
                 from C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/stl_algobase.h:64,
                 from C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/specfun.h:43,
                 from C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/cmath:3898,
                 from C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/math.h:36,
                 from C:\Users\����\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\cores\esp32/esp32-hal.h:30,
                 from C:\Users\����\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\cores\esp32/Arduino.h:44,
                 from C:\Users\����\AppData\Local\arduino\sketches\DC35C61FB4475D85D687B17CD37E6F1E\sketch\ESP32_HRMLink_Fixed.ino.cpp:1:
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/type_traits: In substitution of 'template<bool _Cond, class _Tp> using std::enable_if_t = typename std::enable_if::type [with bool _Cond = false; _Tp = std::__cxx11::basic_string<char>&]':
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:149:8:   required by substitution of 'template<class _CharT, class _Traits, class _Alloc> template<class _Tp, class _Res> using std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::_If_sv = std::enable_if_t<((bool)std::__and_<std::is_convertible<const _Tp&, std::basic_string_view<_CharT, _Traits> >, std::__not_<std::is_convertible<const _Tp*, const std::__cxx11::basic_string<_CharT, _Traits, _Alloc>*> >, std::__not_<std::is_convertible<const _Tp&, const _CharT*> > >::value), _Res> [with _Tp = String; _Res = std::__cxx11::basic_string<char>&; _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>]'
  149 |         using _If_sv = enable_if_t<
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:941:8:   required by substitution of 'template<class _Tp> constexpr std::__cxx11::basic_string<char>::_If_sv<_Tp, std::__cxx11::basic_string<char>&> std::__cxx11::basic_string<char>::operator=(const _Tp&) [with _Tp = String]'
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:195:41:   required from here
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/type_traits:2696:11: error: no type named 'type' in 'struct std::enable_if<false, std::__cxx11::basic_string<char>&>'
 2696 |     using enable_if_t = typename enable_if<_Cond, _Tp>::type;
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:817:7: note: candidate: 'constexpr std::__cxx11::basic_string<_CharT, _Traits, _Alloc>& std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::operator=(const std::__cxx11::basic_string<_CharT, _Traits, _Alloc>&) [with _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>]'
  817 |       operator=(const basic_string& __str)
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:817:37: note:   no known conversion for argument 1 from 'String' to 'const std::__cxx11::basic_string<char>&'
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:828:7: note: candidate: 'constexpr std::__cxx11::basic_string<_CharT, _Traits, _Alloc>& std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::operator=(const _CharT*) [with _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>]'
  828 |       operator=(const _CharT* __s)
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:828:31: note:   no known conversion for argument 1 from 'String' to 'const char*'
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:840:7: note: candidate: 'constexpr std::__cxx11::basic_string<_CharT, _Traits, _Alloc>& std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::operator=(_CharT) [with _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>]'
  840 |       operator=(_CharT __c)
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:840:24: note:   no known conversion for argument 1 from 'String' to 'char'
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:858:7: note: candidate: 'constexpr std::__cxx11::basic_string<_CharT, _Traits, _Alloc>& std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::operator=(std::__cxx11::basic_string<_CharT, _Traits, _Alloc>&&) [with _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>]'
  858 |       operator=(basic_string&& __str)
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:858:32: note:   no known conversion for argument 1 from 'String' to 'std::__cxx11::basic_string<char>&&'
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:926:7: note: candidate: 'constexpr std::__cxx11::basic_string<_CharT, _Traits, _Alloc>& std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::operator=(std::initializer_list<_Tp>) [with _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>]'
  926 |       operator=(initializer_list<_CharT> __l)
C:/Users/����/AppData/Local/Arduino15/packages/esp32/tools/esp-rv32/2507/riscv32-esp-elf/include/c++/14.2.0/bits/basic_string.h:926:42: note:   no known conversion for argument 1 from 'String' to 'std::initializer_list<char>'
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino: In function 'void connectWiFi()':
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:277:12: error: 'class WiFiClass' has no member named 'enableIpV6'; did you mean 'enableIPv6'?
  277 |       WiFi.enableIpV6();
      |            enableIPv6
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:281:20: error: 'class WiFiClass' has no member named 'localIPv6'; did you mean 'localIP'?
  281 |       while (!WiFi.localIPv6().toString().startsWith("fe80:") && ipv6_attempts < 10) {
      |                    localIP
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:288:16: error: 'class WiFiClass' has no member named 'localIPv6'; did you mean 'localIP'?
  288 |       if (WiFi.localIPv6().toString().startsWith("fe80:")) {
      |                localIP
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:291:29: error: 'class WiFiClass' has no member named 'localIPv6'; did you mean 'localIP'?
  291 |         Serial.println(WiFi.localIPv6());
      |                             localIP
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino: In function 'void connectMQTT()':
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:313:28: warning: format '%X' expects argument of type 'unsigned int', but argument 4 has type 'long int' [-Wformat=]
  313 |     snprintf(clientId, 32, "ESP32-HRMLink-%04X", random(0xffff));
      |                                                        long int
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino: In function 'void sendMQTTDiscovery()':
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:339:28: warning: 'DynamicJsonDocument' is deprecated: use JsonDocument instead [-Wdeprecated-declarations]
  339 |   DynamicJsonDocument hrDoc(1024);
In file included from d:\ESP32_HRMLink_Fixed\libraries\ArduinoJson\src/ArduinoJson.hpp:65,
                 from d:\ESP32_HRMLink_Fixed\libraries\ArduinoJson\src/ArduinoJson.h:9,
                 from D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:88:
d:\ESP32_HRMLink_Fixed\libraries\ArduinoJson\src/ArduinoJson/compatibility.hpp:125:58: note: declared here
  125 | class ARDUINOJSON_DEPRECATED("use JsonDocument instead") DynamicJsonDocument
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:355:47: warning: 'ArduinoJson::V742PB22::JsonObject ArduinoJson::V742PB22::JsonDocument::createNestedObject(TChar*) [with TChar = const char]' is deprecated: use doc[key].to<JsonObject>() instead [-Wdeprecated-declarations]
  355 |   JsonObject device = hrDoc.createNestedObject("device");
In file included from d:\ESP32_HRMLink_Fixed\libraries\ArduinoJson\src/ArduinoJson.hpp:42:
d:\ESP32_HRMLink_Fixed\libraries\ArduinoJson\src/ArduinoJson/Document/JsonDocument.hpp:376:14: note: declared here
  376 |   JsonObject createNestedObject(TChar* key) {
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino: In function 'void publishMQTT()':
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:377:3: warning: 'template<unsigned int N> class ArduinoJson::V742PB22::StaticJsonDocument' is deprecated: use JsonDocument instead [-Wdeprecated-declarations]
  377 |   StaticJsonDocument<256> doc;
d:\ESP32_HRMLink_Fixed\libraries\ArduinoJson\src/ArduinoJson/compatibility.hpp:63:58: note: declared here
   63 | class ARDUINOJSON_DEPRECATED("use JsonDocument instead") StaticJsonDocument
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino: In function 'void handleApiStatus()':
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:834:3: warning: 'template<unsigned int N> class ArduinoJson::V742PB22::StaticJsonDocument' is deprecated: use JsonDocument instead [-Wdeprecated-declarations]
  834 |   StaticJsonDocument<350> doc;
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:845:24: error: 'class WiFiClass' has no member named 'localIPv6'; did you mean 'localIP'?
  845 |     doc["ipv6"] = WiFi.localIPv6().toString();
      |                        localIP
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino: In function 'void handleScan()':
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:869:16: warning: format '%d' expects argument of type 'int', but argument 3 has type 'uint32_t' {aka 'long unsigned int'} [-Wformat=]
  869 |   DEBUG_PRINTF("Free heap before scan: %d\n", ESP.getFreeHeap());
      |                                                              uint32_t {aka long unsigned int}
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:106:48: note: in definition of macro 'DEBUG_PRINTF'
  106 |   #define DEBUG_PRINTF(fmt, ...) Serial.printf(fmt, ##__VA_ARGS__)
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:871:48: error: conversion from 'BLEScanResults*' to non-scalar type 'BLEScanResults' requested
  871 |   BLEScanResults foundDevices = pBLEScan->start(5, false);
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:875:16: warning: format '%d' expects argument of type 'int', but argument 3 has type 'uint32_t' {aka 'long unsigned int'} [-Wformat=]
  875 |   DEBUG_PRINTF("Free heap after scan: %d\n", ESP.getFreeHeap());
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino: In function 'void handleApiConnect()':
D:\ESP32_HRMLink_Fixed\ESP32_HRMLink_Fixed.ino:981:3: warning: 'template<unsigned int N> class ArduinoJson::V742PB22::StaticJsonDocument' is deprecated: use JsonDocument instead [-Wdeprecated-declarations]
  981 |   StaticJsonDocument<128> doc;
grpc: error while marshaling: string field contains invalid UTF-8
Compilation error: conversion from 'String' to non-scalar type 'std::string' {aka 'std::__cxx11::basic_string<char>'} requested
 楼主| 发表于 2025-11-5 08:05:06 | 显示全部楼层
板子具体型号?我的是ESP32 DEV MODULE.要选择huge APP.看了下好像还是核心库版本不兼容。。开发板管理器 ESP32降级 2.0.X版本使用,别用3.X的
发表于 2025-11-5 08:12:53 | 显示全部楼层
191442029 发表于 2025-11-5 08:05
板子具体型号?要选择huge APP
esp32 c3.。。。哈哈我已经放弃了,没法抄作业
发表于 2025-11-5 09:39:22 来自手机 | 显示全部楼层
那个跑步机的步数有没有可能搞出来?同步到微信上?
发表于 2025-11-5 19:12:31 | 显示全部楼层
支持  高手
发表于 2025-11-5 21:54:04 | 显示全部楼层
问一下:除了华为的手表手环其他的能不能添加?不用任何配对秘钥之类的任何操作?在信号范围内可以直接抓包陌生人的设备?小米手环扫了一下没有被发现
 楼主| 发表于 2025-11-5 22:50:35 | 显示全部楼层
ck214 发表于 2025-11-5 21:54
问一下:除了华为的手表手环其他的能不能添加?不用任何配对秘钥之类的任何操作?在信号范围内可以直接抓包 ...
小米手环得看是几代,听说9代之后就是私有协议,操蛋了!摄像头也是小米开了个不好的头,手环也是!!
发表于 2025-11-10 11:20:03 | 显示全部楼层
厉害啊,有空试试
 楼主| 发表于 2025-11-12 20:24:37 | 显示全部楼层
预告双机方案……
GMT+8, 2025-12-24 22:06 , Processed in 0.456172 second(s), 12 queries , MemCached On.
