查看: 321|回复: 1
[求助] 请大佬帮忙看看ESPhome配置文件代码
wwjw 手机认证
发表于 2025-10-24 11:47:48 | 显示全部楼层 |阅读模式
我用esp32开发板(esp32dev)、编码器模块(ec11)、1.54寸tft屏幕(ST7789V)实现某些功能,编译正常并刷入了esp32,但是现在遇到2个问题:
1.HA里面不显示实体,按道理说集成后应该会自动发现;
2.屏幕没显示。代码想实现的是屏幕显示当前时间和DAC的输出百分比,但是屏幕显示是白色背景无任何内容。
个人技术不精,请大佬帮忙看看是哪里出了问题。另外,编码器的控制功能是正常的,旋转、按键均有正常的日志输出,可以控制屏幕亮度。
esphome:
  friendly_name: ESP32
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "U2utvgAJzotk+DlZkqo="
ota:
  - platform: esphome
    password: "f094c87da6b4d"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Fallback Hotspot"
    password: "cS01"
captive_portal:
time:
  - platform: homeassistant
    on_time_sync:
      then:
        - component.update: tft_display
font:
  - file: "gfonts://Roboto"
  - platform: uptime
    update_interval: 60s
  - platform: rotary_encoder
    pin_a: GPIO32
    pin_b: GPIO33
    resolution: 4
    filters:
      - debounce: 10ms
    on_clockwise:
      then:
        - number.increment: dac_level
    on_anticlockwise:
      then:
        - number.decrement: dac_level
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO27
      mode: INPUT_PULLUP
      inverted: false
    filters:
      - delayed_on: 50ms
    on_press:
      then:
        - switch.toggle: main_switch
output:
  - platform: esp32_dac
    pin: GPIO25
  - platform: ledc
    pin: GPIO17
    frequency: 1000Hz
number:
  - platform: template
    min_value: 0
    max_value: 100
    step: 1
    unit_of_measurement: "%"
    icon: mdi:gauge
    optimistic: true
    on_value:
      then:
        - output.set_level:
            level: !lambda 'return id(main_switch).state ? (id(dac_level).state / 100.0) : 0.0;'
switch:
  - platform: gpio
    pin: GPIO15
    restore_mode: RESTORE_DEFAULT_OFF
    on_turn_on:
      then:
        - output.set_level:
            level: 1.0
    on_turn_off:
      then:
        - output.set_level:
            level: 0.1
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO23
display:
  - platform: mipi_spi
    model: ST7789V
    dimensions: 240x240
    cs_pin: GPIO5
    dc_pin: GPIO16
    reset_pin: GPIO21
    rotation: 0
    update_interval: never
    lambda: |-
      static float last_dac = -1;
      static int last_hour = -1;
      static int last_minute = -1;
      static bool last_switch = false;
      auto time = id(ha_time).now();
      if (time.hour != last_hour || time.minute != last_minute) {
        it.filled_ring(0, 60, 240, 40, Color::BLACK);
        it.printf(120, 85, id(large_font), TextAlign::CENTER,
                 "%02d:%02d", time.hour, time.minute);
        last_hour = time.hour;
        last_minute = time.minute;
      if (id(dac_level).state != last_dac) {
        it.filled_ring(0, 130, 240, 20, Color::BLACK);
        it.printf(120, 145, id(small_font), TextAlign::CENTER,
                 "DAC输出: %.0f%%", id(dac_level).state);
        last_dac = id(dac_level).state;
wwjw 手机认证
 楼主| 发表于 2025-10-24 23:46:09 | 显示全部楼层
已解决,用官方表达式即可。
GMT+8, 2025-12-9 20:45 , Processed in 1.061653 second(s), 7 queries , MemCached On.
