楼主: lambilly
[UI界面] 【阿木制作】分享一下几个插件的蘑菇界面效果图
发表于 2025-10-21 10:22:50 | 显示全部楼层
看起来好高大上呀
发表于 2025-10-21 10:33:45 | 显示全部楼层
lambilly 发表于 2025-10-21 09:55
NODE-RED流非常多,请具体一个一个来
感谢,感谢
发表于 2025-10-21 12:35:44 | 显示全部楼层
学习学习
发表于 2025-10-21 12:49:30 | 显示全部楼层
溫度濕度那個用什麼卡片的?
 楼主| 发表于 2025-10-21 12:53:07 | 显示全部楼层
fung1006 发表于 2025-10-21 12:49
溫度濕度那個用什麼卡片的?
type: custom:stack-in-card
cards:
  - type: custom:mushroom-template-card
    icon: mdi:home
    entity: sensor.daikin_tvoc_sensor
    primary: 全屋空气
    secondary: >-
      {{ states('sensor.quan_wu_wen_du')  | float(0) | int }}°C|{{
      states('sensor.quan_wu_shi_du')  | float(0) | int }}%
    icon_tap_action:
      action: more-info
    color: >-
      {% set tvoc  = states(entity) | float(0) %} {{['green', 'blue', 'yellow',
      'orange', 'purple', 'red'] [(tvoc > 300) + (tvoc > 500) + (tvoc > 1000) +
      (tvoc > 2000) + (tvoc > 3000)]}}
    features_position: bottom
  - type: custom:mini-graph-card
    entities:
      - entity: sensor.quan_wu_wen_du
        icon: mdi:temperature-celsius
        color: var(--green-color)
      - entity: sensor.quan_wu_shi_du
        icon: mdi:water-percent
        color: var(--indigo-color)
        y_axis: secondary
    line_width: 1
    font_size: 75
    hours_to_show: 24
    points_per_hour: 4
    show:
      name_adaptive_color: true
      icon: false
      state: false
      legend: true
      fill: fade
  - type: horizontal-stack
    cards:
        icon: mdi:air-filter
        primary: 甲醛
        secondary: "{{ states('sensor.daikin_ch2o_sensor') | float(0) | int -13 }}µg/m³"
        entity: sensor.daikin_ch2o_sensor
        icon_tap_action:
          action: more-info
        color: >-
          {% set ch2o = states('sensor.daikin_ch2o_sensor') | float(0) | int -13
          %} {% if ch2o >500 %}brown{% elif ch2o >100 %}red{% elif ch2o >50
          %}orange{% else %}green{% endif %}
        vertical: true
        icon: mdi:molecule-co2
        primary: CO2
        secondary: "{{ states('sensor.daikin_co2_sensor') | float(0) | round(0) }}ppm"
        entity: sensor.daikin_co2_sensor
        icon_tap_action:
          action: more-info
        color: >-
          {% set co2 = states('sensor.daikin_co2_sensor') | float(0) | int %} {%
          if co2 >5000 %}brown{% elif co2 >2000 %}red{% elif co2 >1000
        vertical: true
        icon: mdi:molecule
        primary: PM2.5
        secondary: "{{ states('sensor.daikin_pm2_5_sensor') | float(0) | round(0) }}µg/m³"
        entity: sensor.daikin_pm2_5_sensor
        icon_tap_action:
          action: more-info
        color: >-
          {% set pm25 = states('sensor.daikin_pm2_5_sensor') | float(0) | int %}
          {% if pm25 > 250 %}brown{% elif pm25 > 150 %}red{% elif pm25 > 115
          %}orange{% elif pm25 > 75 %}yellow{% elif pm25 > 35 %}green{% else
          %}blue{% endif %}
        vertical: true
        icon: mdi:radiator
        primary: TVOC
        secondary: "{{ states('sensor.daikin_tvoc_sensor') | float(0) | round(0) }}µg/m³"
        icon_tap_action:
          action: more-info
        color: >-
          {% set tvoc  = states('sensor.daikin_tvoc_sensor') | float(0) %} {% if
          tvoc  > 3000 %}red  {% elif tvoc  > 2000 %}purple {% elif tvoc  > 1000
          %}orange {% elif tvoc  > 500 %}yellow  {% elif tvoc  > 300 %}blue  {%
          else %}green {% endif %}
        vertical: true
    entities:
      - entity: sensor.daikin_ch2o_sensor
        color: var(--purple-color)
        y_axis: secondary
      - entity: sensor.daikin_co2_sensor
        icon: mdi:molecule
      - entity: sensor.daikin_pm2_5_sensor
        icon: mdi:molecule
        color: var(--blue-color)
        y_axis: secondary
      - entity: sensor.daikin_tvoc_sensor
        color: var(--yellow-color)
    line_width: 1
    font_size: 75
    hours_to_show: 24
    points_per_hour: 4
    show:
      icon: false
      state: false
      legend: true
      fill: fade
发表于 2025-10-21 15:27:41 | 显示全部楼层
不错,不错,求抄作业
发表于 2025-10-21 22:26:28 | 显示全部楼层
谢谢大佬,谢谢学习!
发表于 2025-10-21 23:18:03 来自手机 | 显示全部楼层
看起来有点东西
发表于 2025-10-22 01:04:52 | 显示全部楼层
需要,学习一下
发表于 2025-10-22 02:08:05 | 显示全部楼层
【阿木制作】分享一下几个插件的蘑菇界面效果图 [修改]
GMT+8, 2026-1-24 11:08 , Processed in 0.054584 second(s), 11 queries , MemCached On.
