查看: 846|回复: 3
[技术探讨] mqtt一直掉线再不断重连,请教大神指点。
发表于 2025-10-9 22:52:35 | 显示全部楼层 |阅读模式
之前用树莓派老版本haos,就很正常
换到最新版本haos,6.5.2版本的mqtt后,日志显示一直重新连接,很不稳定,贴一段日志,请教大神!!!折腾我一天了
2025-10-09 22:49:53: Client DVES_14FD12 has exceeded timeout, disconnecting.
2025-10-09 22:49:53: Client DVES_D57217 has exceeded timeout, disconnecting.
2025-10-09 22:49:53: Client DVES_DFB930 has exceeded timeout, disconnecting.
2025-10-09 22:49:56: New connection from 192.168.31.115:2522 on port 1883.
2025-10-09 22:49:56: New client connected from 192.168.31.115:2522 as DVES_DFB930 (p2, c1, k10, u'pi').
2025-10-09 22:49:57: New connection from 192.168.31.137:31176 on port 1883.
2025-10-09 22:49:57: New client connected from 192.168.31.137:31176 as DVES_412835 (p2, c1, k15, u'pi').
2025-10-09 22:49:58: Client DVES_734C54 has exceeded timeout, disconnecting.
2025-10-09 22:49:59: New connection from 192.168.31.136:30662 on port 1883.
2025-10-09 22:49:59: New client connected from 192.168.31.136:30662 as DVES_734C54 (p2, c1, k15, u'pi').
2025-10-09 22:50:01: New connection from 192.168.31.138:15039 on port 1883.
2025-10-09 22:50:01: New client connected from 192.168.31.138:15039 as DVES_14FD12 (p2, c1, k15, u'pi').
我的配置也很简单,就一个用户名和密码
logins:
  - username: pi
    password: raspberry
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
  active: false
  folder: mosquitto
到底是哪的原因啊?ping设备,网络连接也很正常
发表于 2025-10-10 15:36:30 | 显示全部楼层
没遇到过。实在不行可以docker跑mqtt
 楼主| 发表于 2025-10-22 20:47:58 | 显示全部楼层
应该是添加了两个mqtt造成的
发表于 2025-12-25 10:40:46 | 显示全部楼层
我也碰到了是不是协议版本不对?在配置流程中,找到「协议版本」选项,选择「MQTT 3.1.1」试一下能不能解决
GMT+8, 2026-1-16 18:33 , Processed in 0.430154 second(s), 10 queries , MemCached On.
