查看: 682|回复: 3
[求助] 通过485接5路德力西电能表
发表于 2025-9-3 21:48:49 | 显示全部楼层 |阅读模式
电表用的德力西的ddsu6606
代码参考了这个https://bbs.hassbian.com/thread-19761-1-1.html,接单个电表没有问题,现在需要接5个电表,让AI帮忙写的修改版,刷上固件后一路都识别不了了,大神帮忙看看问题出在哪
substitutions:
  device_name: esp485
esphome:
  # platformio_options:
  #   board_build.flash_mode: dio
  #   board_build.mcu: esp32c3
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: arduino
logger:
api:
ota:
wifi:
  ssid: !secret wifi_ssid
  fast_connect: on
web_server:
  port: 80
button:
  - platform: restart
time:
  - platform: sntp
uart:
  rx_pin: 18
  tx_pin: 19
  baud_rate: 2400
  data_bits: 8
  stop_bits: 1
  parity: EVEN
modbus:
  send_wait_time: 200ms
modbus_controller:
  - id: ${device_name}_modbus_controller
    modbus_id: ${device_name}_modbus
    address: 0x01
    command_throttle: 200ms
    setup_priority: -10
    update_interval: 10s
text_sensor:
  - platform: wifi_info
    ip_address:
    mac_address:
  - platform: uptime
  - platform: wifi_signal
    update_interval: 60s
 #当前电压
  - platform: modbus_controller
    modbus_controller_id: ${device_name}_modbus_controller
    address: 0x0300
    register_count: 1
    unit_of_measurement: V
    register_type: holding
    value_type: U_WORD
    accuracy_decimals: 1
    device_class: voltage
    filters:
    - multiply: 0.1
 #当前电流
    address: 0x0303
    register_count: 1
    unit_of_measurement: A
    value_type: U_WORD
    accuracy_decimals: 2
    device_class: current
    filters:
      - multiply: 0.01
#瞬时A相有功功率
    address: 0x0306
    register_count: 1
    unit_of_measurement: kW
    value_type: U_WORD
    filters:
      - multiply: 0.01
    device_class: power
    address: 0x000A
    register_count: 2
    unit_of_measurement: kWh
    value_type: S_DWORD
    device_class: energy
    state_class: total_increasing
    filters:
      - multiply: 0.01
      - median:
          window_size: 3
          send_every: 3
AI修改的5路版本
substitutions:
  device_name: esp32_485_5p
  # 定义5个电能表的名称
  meter1_name: "energy_meter_1"
  meter2_name: "energy_meter_2"
  meter3_name: "energy_meter_3"
  meter4_name: "energy_meter_4"
  meter5_name: "energy_meter_5"
esphome:
esp32:
  board: esp32-s3-devkitm-1
  framework:
    type: arduino
# 日志
logger:
  level: DEBUG
# WiFi
wifi:
  ssid: "8888"
  password: "8888"
# API 供 Home Assistant 使用
api:
# OTA 更新
ota:
  - platform: esphome
button:
  - platform: restart
time:
  - platform: sntp
# UART (RS485 转换) - 所有电表共享
uart:
  tx_pin: 18  # TXD
  rx_pin: 19  # RXD
  baud_rate: 2400  # 根据电表实际波特率调整
  data_bits: 8
  stop_bits: 1
  parity: EVEN  # 电表常用偶校验
modbus:
# 五路Modbus控制器,地址从0x01到0x05
modbus_controller:
  - id: ${meter1_name}_controller
    address: 0x01
    setup_priority: -10
  - id: ${meter2_name}_controller
    address: 0x02
    setup_priority: -10
  - id: ${meter3_name}_controller
    address: 0x03
    setup_priority: -10
  - id: ${meter4_name}_controller
    address: 0x04
    setup_priority: -10
  - id: ${meter5_name}_controller
    address: 0x05
    setup_priority: -10
text_sensor:
    ip_address:
    mac_address:
  # 系统传感器
  - platform: uptime
  # DHT11 温湿度
  - platform: dht
    pin: 13
    model: DHT11
    temperature:
      name: "${device_name} Temperature"
    humidity:
      name: "${device_name} Humidity"
    update_interval: 30s
  # 第一路电能表 (地址0x01)
    modbus_controller_id: ${meter1_name}_controller
    address: 0x0300
    register_count: 1
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 0x0303
    register_count: 1
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 0x0306
    register_count: 1
    value_type: U_WORD
    device_class: power
    filters:
      - multiply: 0.01
    address: 0x000A
    register_count: 2
    value_type: S_DWORD
    filters:
      - multiply: 0.01
      - median:
          window_size: 3
          send_every: 3
  # 第二路电能表 (地址0x02)
    modbus_controller_id: ${meter2_name}_controller
    address: 0x0300
    register_count: 1
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 0x0303
    register_count: 1
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 0x0306
    register_count: 1
    value_type: U_WORD
    device_class: power
    filters:
      - multiply: 0.01
    address: 0x000A
    register_count: 2
    value_type: S_DWORD
    filters:
      - multiply: 0.01
      - median:
          window_size: 3
          send_every: 3
  # 第三路电能表 (地址0x03)
    modbus_controller_id: ${meter3_name}_controller
    address: 0x0300
    register_count: 1
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 0x0303
    register_count: 1
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 0x0306
    register_count: 1
    value_type: U_WORD
    device_class: power
    filters:
      - multiply: 0.01
    address: 0x000A
    register_count: 2
    value_type: S_DWORD
    filters:
      - multiply: 0.01
      - median:
          window_size: 3
          send_every: 3
  # 第四路电能表 (地址0x04)
    modbus_controller_id: ${meter4_name}_controller
    address: 0x0300
    register_count: 1
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 0x0303
    register_count: 1
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 0x0306
    register_count: 1
    value_type: U_WORD
    device_class: power
    filters:
      - multiply: 0.01
    address: 0x000A
    register_count: 2
    value_type: S_DWORD
    filters:
      - multiply: 0.01
      - median:
          window_size: 3
          send_every: 3
  # 第五路电能表 (地址0x05)
    modbus_controller_id: ${meter5_name}_controller
    address: 0x0300
    register_count: 1
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 0x0303
    register_count: 1
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 0x0306
    register_count: 1
    value_type: U_WORD
    device_class: power
    filters:
      - multiply: 0.01
    address: 0x000A
    register_count: 2
    value_type: S_DWORD
    filters:
      - multiply: 0.01
      - median:
          window_size: 3
          send_every: 3
发表于 2025-9-4 14:01:43 | 显示全部楼层
代码看起来没问题,看看日志,检查一下接线
发表于 2025-9-4 14:45:50 | 显示全部楼层
先写一个,接一个电表,OK后再增加
 楼主| 发表于 2025-9-4 21:53:19 | 显示全部楼层
这个时间要修改下每个错开
GMT+8, 2026-1-29 05:47 , Processed in 0.122238 second(s), 11 queries , MemCached On.
