- 积分
- 276
- 金钱
- 222
- 威望
- 0
- 贡献
- 0
- HASS币
- 0
- 积分
- 276
- 金钱
- 222
- HASS币
- 0
楼主 |
发表于 2025-8-15 20:35:13
显示全部楼层
const fz = require('zigbee-herdsman-converters/converters/fromZigbee');
const tz = require('zigbee-herdsman-converters/converters/toZigbee');
const exposes = require('zigbee-herdsman-converters/lib/exposes');
const reporting = require('zigbee-herdsman-converters/lib/reporting');
const modernExtend = require('zigbee-herdsman-converters/lib/modernExtend');
const e = exposes.presets;
const ea = exposes.access;
const tuya = require('zigbee-herdsman-converters/lib/tuya');
const definition = {
// Since a lot of Tuya devices use the same modelID, but use different datapoints
// it's necessary to provide a fingerprint instead of a zigbeeModel
fingerprint: tuya.fingerprint("TS0726", ["_TZ3002_ovsw7u2p"]),
model: "TS0726_2",
vendor: "Tuya",
description: "2 gang switch with neutral wire",
fromZigbee: [fz.on_off, tuya.fz.power_on_behavior_2, fz.ignore_basic_report, fzLocal.TS0726_action],
toZigbee: [tz.on_off, tuya.tz.power_on_behavior_2, tzLocal.TS0726_switch_mode],
exposes: [
...[1, 2].map((ep) => e.switch().withEndpoint(`l${ep}`)),
...[1, 2].map((ep) => e.power_on_behavior().withEndpoint(`l${ep}`)),
...[1, 2].map((ep) => e.enum("switch_mode", ea.STATE_SET, ["switch", "scene"]).withEndpoint(`l${ep}`)),
e.action(["scene_1", "scene_2"]),
endpoint: (device) => {
return {l1: 1, l2: 2};
meta: {multiEndpoint: true},
configure: async (device, coordinatorEndpoint) => {
await tuya.configureMagicPacket(device, coordinatorEndpoint);
for (const ep of [1, 2]) {
await reporting.bind(device.getEndpoint(ep), coordinatorEndpoint, ["genOnOff"]);
module.exports = definition;
发现这个无法加载,有没有知道哪里错了? |
