查看: 780|回复: 7
[流程系列] 求助:nodered安装节点失败
发表于 2025-7-25 15:20:39 | 显示全部楼层 |阅读模式
2025-07-24T15:33:21.015Z [err] npm error code E404
2025-07-24T15:33:21.016Z [err] npm error 404 Not Found - GET https://registry.npmjs.org/node-red-contrib-home-assistant-discovery/-/node-red-contrib-home-assistant-discovery-0.0.7.tgz - Not found
2025-07-24T15:33:21.016Z [err] npm error 404  ' node-red-contrib-home-assistant-discovery@ https://registry.npmjs.org/node-red-contrib-home-assistant-discovery/-/node-red-contrib-home-assistant-discovery-0.0.7.tgz' is not in this registry.
2025-07-24T15:33:21.016Z [err] npm error 404 Note that you can also install from a
2025-07-24T15:33:21.016Z [err] npm error 404 tarball, folder, http url, or git url.
2025-07-24T15:33:21.016Z [err] npm error A complete log of this run can be found in: /root/.npm/_logs/2025-07-24T15_32_48_976Z-debug-0.log
2025-07-24T15:33:21.019Z rc=1
请问怎么回事呀,是在UTM安装HAOS虚拟机,不管安装什么节点,都提示node-red-contrib-home-assistant-discovery-0.0.7.tgz 安装失败,请问有没有大佬知道怎么回事呀。
发表于 2025-7-25 16:43:09 | 显示全部楼层
搭个梯子试试
xulu 手机认证
发表于 2025-7-25 17:45:48 | 显示全部楼层
不是梯子的问题,安装是肯定安装好了的
 楼主| 发表于 2025-7-25 20:28:50 | 显示全部楼层
谢谢,解决了,在package.json里删掉这个依赖就好了
 楼主| 发表于 2025-7-25 20:30:06 | 显示全部楼层
xulu 发表于 2025-7-25 17:45
不是梯子的问题,安装是肯定安装好了的
发表于 2025-7-27 16:57:34 | 显示全部楼层
node-red-contrib-home-assistant-websocket
也是安装报错,提示-----------------------------------------------------------
2025-07-27T08:57:17.506Z 安装 : node-red-contrib-home-assistant-websocket 0.77.2
2025-07-27T08:57:18.010Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict [email protected]
2025-07-27T08:57:18.510Z [err] npm
2025-07-27T08:57:18.511Z [err]  WARN
2025-07-27T08:57:18.511Z [err]  config production Use `--omit=dev` instead.
2025-07-27T08:57:19.382Z [err] npm
2025-07-27T08:57:19.382Z [err]  ERR! code
2025-07-27T08:57:19.382Z [err]  EBADENGINE
2025-07-27T08:57:19.385Z [err] npm
2025-07-27T08:57:19.385Z [err] ERR! engine
2025-07-27T08:57:19.385Z [err]  Unsupported engine
2025-07-27T08:57:19.385Z [err] npm ERR! engine
2025-07-27T08:57:19.385Z [err]  Not compatible with your version of node/npm: [email protected]
2025-07-27T08:57:19.386Z [err] ERR! notsup Not compatible with your version of node/npm: [email protected]
2025-07-27T08:57:19.386Z [err] npm ERR! notsup
2025-07-27T08:57:19.386Z [err]  Required: {"node":">=18.2.0"}
2025-07-27T08:57:19.386Z [err] npm ERR! notsup Actual:   {"npm":"8.19.4","node":"v16.20.2"}
2025-07-27T08:57:19.388Z [err]
2025-07-27T08:57:19.389Z [err] npm ERR! A complete log of this run can be found in:
2025-07-27T08:57:19.389Z [err]      /data/.npm/_logs/2025-07-27T08_57_18_468Z-debug-0.log
2025-07-27T08:57:19.400Z rc=1
 楼主| 发表于 2025-7-29 12:05:33 | 显示全部楼层
也是安装报错,提示---------------------------------------- ...
node.js版本太低了,试试升级nodered或者安装低版本的node-red-contrib-home-assistant-websocket
发表于 2025-7-29 15:47:59 | 显示全部楼层
a784174467 发表于 2025-7-29 12:05
node.js版本太低了,试试升级nodered或者安装低版本的node-red-contrib-home-assistant-websocket ...
一阵见血,降级后者搞定
GMT+8, 2025-12-3 06:45 , Processed in 1.243517 second(s), 11 queries , MemCached On.
