查看: 4413|回复: 0
[求助] 新手求助
发表于 2018-3-8 12:31:00 | 显示全部楼层 |阅读模式
按照群晖DSM 非docker 搭homeassistant,MQTT,启动后有好多错误 。如何解决https://weibo.com/ttarticle/p/show?id=2309404148648245106231
错误log
Unable to install package warrant==0.6.1: Command "/volume1/@appstore/py3k/usr/local/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-rndmtv8a/pycryptodome/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-6u73bfs1-record/install-record.txt --single-version-externally-managed --prefix --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-rndmtv8a/pycryptodome/
下午12:16 util/package.py (ERROR)
Setup failed for homekit: Could not install all requirements.
下午12:13 setup.py (ERROR)
Not initializing homekit because could not install requirement HAP-python==1.1.5
下午12:13 requirements.py (ERROR)
Unable to install package HAP-python==1.1.5: Command "/volume1/@appstore/py3k/usr/local/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-49jqddsq/pycryptodome/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-v1gpqbgj-record/install-record.txt --single-version-externally-managed --prefix --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-49jqddsq/pycryptodome/
下午12:13 util/package.py (ERROR)
Setup failed for discovery: Could not install all requirements.
下午12:10 setup.py (ERROR)
Not initializing discovery because could not install requirement netdisco==1.2.4
下午12:10 requirements.py (ERROR)
Unable to install package netdisco==1.2.4: Command "/volume1/@appstore/py3k/usr/local/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-cw268y1t/netifaces/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-epvriu7r-record/install-record.txt --single-version-externally-managed --prefix --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-cw268y1t/netifaces/
下午12:10 util/package.py (ERROR)
GMT+8, 2025-12-25 07:51 , Processed in 0.845533 second(s), 8 queries , MemCached On.
