查看: 829|回复: 2
[求助] 根据启动信息,有没大神能指点如何修这台小蚁摄像头 ...
发表于 2025-7-14 09:45:23 | 显示全部楼层 |阅读模式
我有台小蚁摄像头,前段时间突然坏了,现象就是不断自动重启(黄、蓝灯来回亮),摄像头左右上下转动有动作,但一直重启无法进到正常工作状态。
今天把它焊好串口线,接到电脑看到了启动输出的信息流,最后的启动信息显示它是因为看门狗要求重启的。。。最后的关键信息段如下:
请有了解的大神帮看看,大概会是什么故障导致它的问题呢。(完整启动信息见)
Play this stream using the URL "rtsp://0.0.0.0/ch0_0.h264"
"ch0_2.h264" stream, from the file "/tmp/aac_audio_fifo"
AAC audio enabled
Play this stream using the URL "rtsp://0.0.0.0/ch0_2.h264"
Failed to connect to non-global ctrl_ifname: wlan0  error: Connection refused
[CPLD_PERIPH] limit switch 2!
x =2950 800 0 800 x_step =-150 0 x_step_2 =2950 0
killall: wpa_supplicant: no process killed
killall: udhcpc: no process killed
killall: recbackup: no process killed
umount: can't unmount /tmp/cifs: No such file or directory
ash: 1: unknown operand
umount: can't remount tmpfs read-only
umount: /dev/mtdblock5 busy - remounted read-only
can't run '/sbin/swapoff': No such file or directory
The system is going down NOW!
tcpsvd: got signal 15, exit
Sent SIGTERM to all processes
MMB LEAK(pid=947): 0x835A5000, 4096 bytes, 'AENC(0)StrmBuf'
mmz_userdev_release: mmb<0x835A5000> mapped to userspace 0xb6fb1000 will be forc
e unmaped!
MMB LEAK(pid=947): 0x835A6000, 32768 bytes, 'AENC(0) CirBuf'
mmz_userdev_release: mmb<0x835A6000> mapped to userspace 0xb6e17000 will be forc
e unmaped!
MMB LEAK(pid=947): 0x835B3000, 16384 bytes, 'AO(0,0) CirBuf'
mmz_userdev_release: mmb<0x835B3000> mapped to userspace 0xb6d13000 will be forc
e unmaped!
Sent SIGKILL to all processes
Requesting system reboot
********reboot by watchdog********
Restarting system.
到这,摄像头就自动重启了
发表于 2025-7-14 11:14:15 | 显示全部楼层
重刷固件
shay 手机认证
发表于 2025-7-14 11:28:56 | 显示全部楼层
问gpt回答更靠谱
GMT+8, 2025-12-16 03:18 , Processed in 0.413714 second(s), 7 queries , MemCached On.
