查看: 615|回复: 2
[求助] 无法设置 Quiet 静音风
发表于 2025-7-11 10:36:39 | 显示全部楼层 |阅读模式
问题简述
使用homeassistant的robhofmann的Gree A/C插件,均已更新至最新版本,空调已添加,其他操作均正常。
但设置空调模式为Quiet时,空调实际被设置为Low。我的空调在格力+APP上操作,可以设置静音风。
求问,怎么可以设置静音风?
从log看设置Quiet成功,并且HA前端显示的是静音风,但是空调实际是低风。
Log:
2025-07-11 10:20:30.330 DEBUG (SyncWorker_7) [custom_components.gree.climate] Starting SyncState
2025-07-11 10:20:30.330 DEBUG (SyncWorker_7) [custom_components.gree.climate] Fetching(192.168.0.12, 7000, 10, {"cid":"app","i":0,"pack":"Cj5C7V2E86JOJcHJBM+KtolYJyjIE8KetKkJFBRUhaoZnlluFBAfoVgyFYlS8ZOTX4qBm59uG74tMuG7cG8nSvG6S2mFSUaoTXp6B5Pd9ngcfhSmzsWK7EoLQB+BuJyjQEFpS6UHnxX+d/B+gMJyYYk2l3Nl7KyRflBS3JjnxHIvv7PIlJFgX3iiBP88/oWMU6sbpki0O0usMscKQ4PVFAfnWq1U1YJlBkNH+C83OGqxtOxJXigGdoS7tyBO8/WWnGPvip3m5d7TwNpyogCOwEVuM5/UwxfMkgE0e1IqcFKKoUa7hxuStgtrlwA7FObQ","t":"pack","tcid":"a043b00dcbfd","uid":0})
2025-07-11 10:20:30.486 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting acOptions with retrieved HVAC values
2025-07-11 10:20:30.486 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Pow: 1
2025-07-11 10:20:30.486 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Mod: 1
2025-07-11 10:20:30.486 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting SetTem: 24
2025-07-11 10:20:30.486 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting WdSpd: 3
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Air: 0
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Blo: 1
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Health: 0
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting SwhSlp: 0
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Lig: 0
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting SwingLfRig: 2
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting SwUpDn: 6
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Quiet: 1
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Tur: 0
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting StHt: 0
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting TemUn: 0
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting HeatCoolType: 0
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting TemRec: 0
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting SvSt: 0
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting SlpMod: 0
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting TemSen: 27
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Done setting acOptions
2025-07-11 10:20:30.487 INFO (SyncWorker_7) [custom_components.gree.climate] UpdateHATargetTemperature: HA target temp set to: 24.0 °C. Device commands: SetTem: 24, TemRec: 0
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA lights option set according to HVAC state to: off
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA xfan option set according to HVAC state to: on
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA health option set according to HVAC state to: off
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA powersave option set according to HVAC state to: off
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA sleep option set according to HVAC state to: off
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA 8℃ heat option set according to HVAC state to: off
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA air option set according to HVAC state to: off
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA operation mode set according to HVAC state to: cool
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA swing mode set according to HVAC state to: Fixed in the lowest position
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA fan mode set according to HVAC state to: Quiet
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] method UpdateHACurrentTemperature: TemSen: 27
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] method UpdateHACurrentTemperature: User has not chosen an offset, using process_temp_sensor() to automatically determine offset.
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] method UpdateHACurrentTemperature: HA current temperature set with device built-in temperature sensor state : 27°C
2025-07-11 10:20:30.487 DEBUG (SyncWorker_7) [custom_components.gree.climate] Finished SyncState
2025-07-11 10:20:30.487 DEBUG (MainThread) [custom_components.gree.climate] supported_features(): 425
2025-07-11 10:20:30.487 DEBUG (MainThread) [custom_components.gree.climate] temperature_unit(): °C
2025-07-11 10:20:30.487 DEBUG (MainThread) [custom_components.gree.climate] hvac_modes(): [<HVACMode.AUTO: 'auto'>, <HVACMode.COOL: 'cool'>, <HVACMode.DRY: 'dry'>, <HVACMode.FAN_ONLY: 'fan_only'>, <HVACMode.HEAT: 'heat'>, <HVACMode.OFF: 'off'>]
2025-07-11 10:20:30.487 DEBUG (MainThread) [custom_components.gree.climate] min_temp(): 16
2025-07-11 10:20:30.487 DEBUG (MainThread) [custom_components.gree.climate] max_temp(): 30
2025-07-11 10:20:30.487 DEBUG (MainThread) [custom_components.gree.climate] target_temperature_step(): None
2025-07-11 10:20:30.487 DEBUG (MainThread) [custom_components.gree.climate] fan_list(): ['Auto', 'Low', 'Medium-Low', 'Medium', 'Medium-High', 'High', 'Turbo', 'Quiet']
2025-07-11 10:20:30.487 DEBUG (MainThread) [custom_components.gree.climate] swing_modes(): ['Default', 'Swing in full range', 'Fixed in the upmost position', 'Fixed in the middle-up position', 'Fixed in the middle position', 'Fixed in the middle-low position', 'Fixed in the lowest position', 'Swing in the downmost region', 'Swing in the middle-low region', 'Swing in the middle region', 'Swing in the middle-up region', 'Swing in the upmost region']
2025-07-11 10:20:30.487 INFO (MainThread) [custom_components.gree.climate] available(): Device is online
2025-07-11 10:20:30.487 DEBUG (MainThread) [custom_components.gree.climate] hvac_mode(): cool
2025-07-11 10:20:30.487 DEBUG (MainThread) [custom_components.gree.climate] current_temperature(): 27
2025-07-11 10:20:30.487 DEBUG (MainThread) [custom_components.gree.climate] target_temperature(): 24.0
2025-07-11 10:20:30.488 DEBUG (MainThread) [custom_components.gree.climate] fan_mode(): Quiet
2025-07-11 10:20:30.488 DEBUG (MainThread) [custom_components.gree.climate] swing_mode(): Fixed in the lowest position
2025-07-11 10:20:30.488 DEBUG (MainThread) [custom_components.gree.climate] supported_features(): 425
2025-07-11 10:21:19.094 INFO (MainThread) [custom_components.gree.climate] available(): Device is online
2025-07-11 10:21:19.094 DEBUG (MainThread) [custom_components.gree.climate] supported_features(): 425
2025-07-11 10:21:19.094 DEBUG (MainThread) [custom_components.gree.climate] fan_list(): ['Auto', 'Low', 'Medium-Low', 'Medium', 'Medium-High', 'High', 'Turbo', 'Quiet']
2025-07-11 10:21:19.094 INFO (SyncWorker_14) [custom_components.gree.climate] set_fan_mode(): Medium
2025-07-11 10:21:19.094 INFO (SyncWorker_14) [custom_components.gree.climate] Setting normal fan mode to 3
2025-07-11 10:21:19.094 DEBUG (SyncWorker_14) [custom_components.gree.climate] Starting SyncState
2025-07-11 10:21:19.094 DEBUG (SyncWorker_14) [custom_components.gree.climate] Fetching(192.168.0.12, 7000, 10, {"cid":"app","i":0,"pack":"Cj5C7V2E86JOJcHJBM+KtolYJyjIE8KetKkJFBRUhaoZnlluFBAfoVgyFYlS8ZOTX4qBm59uG74tMuG7cG8nSvG6S2mFSUaoTXp6B5Pd9ngcfhSmzsWK7EoLQB+BuJyjQEFpS6UHnxX+d/B+gMJyYYk2l3Nl7KyRflBS3JjnxHIvv7PIlJFgX3iiBP88/oWMU6sbpki0O0usMscKQ4PVFAfnWq1U1YJlBkNH+C83OGqxtOxJXigGdoS7tyBO8/WWnGPvip3m5d7TwNpyogCOwEVuM5/UwxfMkgE0e1IqcFKKoUa7hxuStgtrlwA7FObQ","t":"pack","tcid":"a043b00dcbfd","uid":0})
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting acOptions with retrieved HVAC values
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting Pow: 1
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting Mod: 1
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting SetTem: 24
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting WdSpd: 3
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting Air: 0
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting Blo: 1
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting Health: 0
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting SwhSlp: 0
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting Lig: 0
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting SwingLfRig: 2
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting SwUpDn: 6
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting Quiet: 1
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting Tur: 0
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting StHt: 0
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting TemUn: 0
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting HeatCoolType: 0
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting TemRec: 0
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting SvSt: 0
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting SlpMod: 0
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Setting TemSen: 27
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Done setting acOptions
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Overwriting acOptions with new settings
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Overwriting WdSpd: 3
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Overwriting Tur: 0
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Overwriting Quiet: 0
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Done overwriting acOptions
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Sending with Buzzer_ON_OFF=0 (Silent mode HA toggle is ON: True)
2025-07-11 10:21:19.147 DEBUG (SyncWorker_14) [custom_components.gree.climate] Fetching(192.168.0.12, 7000, 10, {"cid":"app","i":0,"pack":"qOtN1ol9Qwow6BesFW4CswqYxySZlVVmDvudiGOLLL4Xsw9T0i2p8dvSEW0GdOgGtlGMgeGh9ZqleAbdpb+qLIAv0weB/YjMzU6MJSq0EQjFqOLlEnCW6DPXnqODJWrQSivQ6xB8ImbrdvI9YNbvVowpY+qIp8g6c4EbeN94A935FRYs/4OnWZWh7EnfDHhJctwjYUt4ic67jmk1kLtNvpq7e1hytcTrg8dQXtN5REH953erjzdz4E1X20O6Kq8bdEBvEj3kVlWCf+Wvd/JRgIqhqsI31VZfNJsd58QEHJa5GJH02cbNXIp3AsyjylWo","t":"pack","tcid":"a043b00dcbfd","uid":0})
2025-07-11 10:21:19.202 DEBUG (SyncWorker_14) [custom_components.gree.climate] Done sending state to HVAC: {'t': 'res', 'mac': 'a043b00dcbfd', 'val': [1, 1, 24, 3, 0, 1, 0, 0, 0, 2, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0], 'p': [1, 1, 24, 3, 0, 1, 0, 0, 0, 2, 6, 0, 0, 0, 0, 0, 0, 0, 0, 0], 'opt': ['Pow', 'Mod', 'SetTem', 'WdSpd', 'Air', 'Blo', 'Health', 'SwhSlp', 'Lig', 'SwingLfRig', 'SwUpDn', 'Quiet', 'Tur', 'StHt', 'TemUn', 'HeatCoolType', 'TemRec', 'SvSt', 'SlpMod', 'Buzzer_ON_OFF'], 'r': 200}
2025-07-11 10:21:19.202 INFO (SyncWorker_14) [custom_components.gree.climate] UpdateHATargetTemperature: HA target temp set to: 24.0 °C. Device commands: SetTem: 24, TemRec: 0
2025-07-11 10:21:19.202 DEBUG (SyncWorker_14) [custom_components.gree.climate] HA lights option set according to HVAC state to: off
2025-07-11 10:21:19.202 DEBUG (SyncWorker_14) [custom_components.gree.climate] HA xfan option set according to HVAC state to: on
2025-07-11 10:21:19.202 DEBUG (SyncWorker_14) [custom_components.gree.climate] HA health option set according to HVAC state to: off
2025-07-11 10:21:19.202 DEBUG (SyncWorker_14) [custom_components.gree.climate] HA powersave option set according to HVAC state to: off
2025-07-11 10:21:19.202 DEBUG (SyncWorker_14) [custom_components.gree.climate] HA sleep option set according to HVAC state to: off
2025-07-11 10:21:19.202 DEBUG (SyncWorker_14) [custom_components.gree.climate] HA 8℃ heat option set according to HVAC state to: off
2025-07-11 10:21:19.202 DEBUG (SyncWorker_14) [custom_components.gree.climate] HA air option set according to HVAC state to: off
2025-07-11 10:21:19.202 DEBUG (SyncWorker_14) [custom_components.gree.climate] HA operation mode set according to HVAC state to: cool
2025-07-11 10:21:19.202 DEBUG (SyncWorker_14) [custom_components.gree.climate] HA swing mode set according to HVAC state to: Fixed in the lowest position
2025-07-11 10:21:19.202 DEBUG (SyncWorker_14) [custom_components.gree.climate] HA fan mode set according to HVAC state to: Medium
2025-07-11 10:21:19.202 DEBUG (SyncWorker_14) [custom_components.gree.climate] method UpdateHACurrentTemperature: TemSen: 27
2025-07-11 10:21:19.202 DEBUG (SyncWorker_14) [custom_components.gree.climate] method UpdateHACurrentTemperature: User has not chosen an offset, using process_temp_sensor() to automatically determine offset.
2025-07-11 10:21:19.202 DEBUG (SyncWorker_14) [custom_components.gree.climate] method UpdateHACurrentTemperature: HA current temperature set with device built-in temperature sensor state : 27°C
2025-07-11 10:21:19.202 DEBUG (SyncWorker_14) [custom_components.gree.climate] Finished SyncState
2025-07-11 10:21:19.202 DEBUG (MainThread) [custom_components.gree.climate] supported_features(): 425
2025-07-11 10:21:19.202 DEBUG (MainThread) [custom_components.gree.climate] temperature_unit(): °C
2025-07-11 10:21:19.202 DEBUG (MainThread) [custom_components.gree.climate] hvac_modes(): [<HVACMode.AUTO: 'auto'>, <HVACMode.COOL: 'cool'>, <HVACMode.DRY: 'dry'>, <HVACMode.FAN_ONLY: 'fan_only'>, <HVACMode.HEAT: 'heat'>, <HVACMode.OFF: 'off'>]
2025-07-11 10:21:19.202 DEBUG (MainThread) [custom_components.gree.climate] min_temp(): 16
2025-07-11 10:21:19.202 DEBUG (MainThread) [custom_components.gree.climate] max_temp(): 30
2025-07-11 10:21:19.202 DEBUG (MainThread) [custom_components.gree.climate] target_temperature_step(): None
2025-07-11 10:21:19.202 DEBUG (MainThread) [custom_components.gree.climate] fan_list(): ['Auto', 'Low', 'Medium-Low', 'Medium', 'Medium-High', 'High', 'Turbo', 'Quiet']
2025-07-11 10:21:19.202 DEBUG (MainThread) [custom_components.gree.climate] swing_modes(): ['Default', 'Swing in full range', 'Fixed in the upmost position', 'Fixed in the middle-up position', 'Fixed in the middle position', 'Fixed in the middle-low position', 'Fixed in the lowest position', 'Swing in the downmost region', 'Swing in the middle-low region', 'Swing in the middle region', 'Swing in the middle-up region', 'Swing in the upmost region']
2025-07-11 10:21:19.202 INFO (MainThread) [custom_components.gree.climate] available(): Device is online
2025-07-11 10:21:19.203 DEBUG (MainThread) [custom_components.gree.climate] hvac_mode(): cool
2025-07-11 10:21:19.203 DEBUG (MainThread) [custom_components.gree.climate] supported_features(): 425
2025-07-11 10:21:19.203 DEBUG (MainThread) [custom_components.gree.climate] temperature_unit(): °C
2025-07-11 10:21:19.203 DEBUG (MainThread) [custom_components.gree.climate] current_temperature(): 27
2025-07-11 10:21:19.203 DEBUG (MainThread) [custom_components.gree.climate] target_temperature(): 24.0
2025-07-11 10:21:19.203 DEBUG (MainThread) [custom_components.gree.climate] fan_mode(): Medium
2025-07-11 10:21:19.203 DEBUG (MainThread) [custom_components.gree.climate] swing_mode(): Fixed in the lowest position
2025-07-11 10:21:19.203 DEBUG (MainThread) [custom_components.gree.climate] should_poll()
2025-07-11 10:21:19.203 DEBUG (SyncWorker_8) [custom_components.gree.climate] update()
2025-07-11 10:21:19.203 DEBUG (SyncWorker_8) [custom_components.gree.climate] Starting SyncState
2025-07-11 10:21:19.203 DEBUG (SyncWorker_8) [custom_components.gree.climate] Fetching(192.168.0.12, 7000, 10, {"cid":"app","i":0,"pack":"Cj5C7V2E86JOJcHJBM+KtolYJyjIE8KetKkJFBRUhaoZnlluFBAfoVgyFYlS8ZOTX4qBm59uG74tMuG7cG8nSvG6S2mFSUaoTXp6B5Pd9ngcfhSmzsWK7EoLQB+BuJyjQEFpS6UHnxX+d/B+gMJyYYk2l3Nl7KyRflBS3JjnxHIvv7PIlJFgX3iiBP88/oWMU6sbpki0O0usMscKQ4PVFAfnWq1U1YJlBkNH+C83OGqxtOxJXigGdoS7tyBO8/WWnGPvip3m5d7TwNpyogCOwEVuM5/UwxfMkgE0e1IqcFKKoUa7hxuStgtrlwA7FObQ","t":"pack","tcid":"a043b00dcbfd","uid":0})
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting acOptions with retrieved HVAC values
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting Pow: 1
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting Mod: 1
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting SetTem: 24
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting WdSpd: 3
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting Air: 0
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting Blo: 1
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting Health: 0
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting SwhSlp: 0
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting Lig: 0
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting SwingLfRig: 2
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting SwUpDn: 6
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting Quiet: 0
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting Tur: 0
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting StHt: 0
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting TemUn: 0
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting HeatCoolType: 0
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting TemRec: 0
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting SvSt: 0
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting SlpMod: 0
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Setting TemSen: 27
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] Done setting acOptions
2025-07-11 10:21:20.025 INFO (SyncWorker_8) [custom_components.gree.climate] UpdateHATargetTemperature: HA target temp set to: 24.0 °C. Device commands: SetTem: 24, TemRec: 0
2025-07-11 10:21:20.025 DEBUG (SyncWorker_8) [custom_components.gree.climate] HA lights option set according to HVAC state to: off
2025-07-11 10:21:20.026 DEBUG (SyncWorker_8) [custom_components.gree.climate] HA xfan option set according to HVAC state to: on
2025-07-11 10:21:20.026 DEBUG (SyncWorker_8) [custom_components.gree.climate] HA health option set according to HVAC state to: off
2025-07-11 10:21:20.026 DEBUG (SyncWorker_8) [custom_components.gree.climate] HA powersave option set according to HVAC state to: off
2025-07-11 10:21:20.026 DEBUG (SyncWorker_8) [custom_components.gree.climate] HA sleep option set according to HVAC state to: off
2025-07-11 10:21:20.026 DEBUG (SyncWorker_8) [custom_components.gree.climate] HA 8℃ heat option set according to HVAC state to: off
2025-07-11 10:21:20.026 DEBUG (SyncWorker_8) [custom_components.gree.climate] HA air option set according to HVAC state to: off
2025-07-11 10:21:20.026 DEBUG (SyncWorker_8) [custom_components.gree.climate] HA operation mode set according to HVAC state to: cool
2025-07-11 10:21:20.026 DEBUG (SyncWorker_8) [custom_components.gree.climate] HA swing mode set according to HVAC state to: Fixed in the lowest position
2025-07-11 10:21:20.026 DEBUG (SyncWorker_8) [custom_components.gree.climate] HA fan mode set according to HVAC state to: Medium
2025-07-11 10:21:20.026 DEBUG (SyncWorker_8) [custom_components.gree.climate] method UpdateHACurrentTemperature: TemSen: 27
2025-07-11 10:21:20.026 DEBUG (SyncWorker_8) [custom_components.gree.climate] method UpdateHACurrentTemperature: User has not chosen an offset, using process_temp_sensor() to automatically determine offset.
2025-07-11 10:21:20.026 DEBUG (SyncWorker_8) [custom_components.gree.climate] method UpdateHACurrentTemperature: HA current temperature set with device built-in temperature sensor state : 27°C
2025-07-11 10:21:20.026 DEBUG (SyncWorker_8) [custom_components.gree.climate] Finished SyncState
2025-07-11 10:21:20.026 DEBUG (MainThread) [custom_components.gree.climate] supported_features(): 425
2025-07-11 10:21:20.026 DEBUG (MainThread) [custom_components.gree.climate] temperature_unit(): °C
2025-07-11 10:21:20.026 DEBUG (MainThread) [custom_components.gree.climate] hvac_modes(): [<HVACMode.AUTO: 'auto'>, <HVACMode.COOL: 'cool'>, <HVACMode.DRY: 'dry'>, <HVACMode.FAN_ONLY: 'fan_only'>, <HVACMode.HEAT: 'heat'>, <HVACMode.OFF: 'off'>]
2025-07-11 10:21:20.026 DEBUG (MainThread) [custom_components.gree.climate] min_temp(): 16
2025-07-11 10:21:20.026 DEBUG (MainThread) [custom_components.gree.climate] max_temp(): 30
2025-07-11 10:21:20.026 DEBUG (MainThread) [custom_components.gree.climate] target_temperature_step(): None
2025-07-11 10:21:20.026 DEBUG (MainThread) [custom_components.gree.climate] fan_list(): ['Auto', 'Low', 'Medium-Low', 'Medium', 'Medium-High', 'High', 'Turbo', 'Quiet']
2025-07-11 10:21:20.026 DEBUG (MainThread) [custom_components.gree.climate] swing_modes(): ['Default', 'Swing in full range', 'Fixed in the upmost position', 'Fixed in the middle-up position', 'Fixed in the middle position', 'Fixed in the middle-low position', 'Fixed in the lowest position', 'Swing in the downmost region', 'Swing in the middle-low region', 'Swing in the middle region', 'Swing in the middle-up region', 'Swing in the upmost region']
2025-07-11 10:21:20.026 INFO (MainThread) [custom_components.gree.climate] available(): Device is online
2025-07-11 10:21:20.026 DEBUG (MainThread) [custom_components.gree.climate] hvac_mode(): cool
2025-07-11 10:21:20.027 DEBUG (MainThread) [custom_components.gree.climate] current_temperature(): 27
2025-07-11 10:21:20.027 DEBUG (MainThread) [custom_components.gree.climate] target_temperature(): 24.0
2025-07-11 10:21:20.027 DEBUG (MainThread) [custom_components.gree.climate] fan_mode(): Medium
2025-07-11 10:21:20.027 DEBUG (MainThread) [custom_components.gree.climate] swing_mode(): Fixed in the lowest position
2025-07-11 10:21:20.027 DEBUG (MainThread) [custom_components.gree.climate] supported_features(): 425
2025-07-11 10:21:30.332 DEBUG (MainThread) [custom_components.gree.climate] should_poll()
2025-07-11 10:21:30.333 DEBUG (SyncWorker_5) [custom_components.gree.climate] update()
2025-07-11 10:21:30.333 DEBUG (SyncWorker_5) [custom_components.gree.climate] Starting SyncState
2025-07-11 10:21:30.333 DEBUG (SyncWorker_5) [custom_components.gree.climate] Fetching(192.168.0.12, 7000, 10, {"cid":"app","i":0,"pack":"Cj5C7V2E86JOJcHJBM+KtolYJyjIE8KetKkJFBRUhaoZnlluFBAfoVgyFYlS8ZOTX4qBm59uG74tMuG7cG8nSvG6S2mFSUaoTXp6B5Pd9ngcfhSmzsWK7EoLQB+BuJyjQEFpS6UHnxX+d/B+gMJyYYk2l3Nl7KyRflBS3JjnxHIvv7PIlJFgX3iiBP88/oWMU6sbpki0O0usMscKQ4PVFAfnWq1U1YJlBkNH+C83OGqxtOxJXigGdoS7tyBO8/WWnGPvip3m5d7TwNpyogCOwEVuM5/UwxfMkgE0e1IqcFKKoUa7hxuStgtrlwA7FObQ","t":"pack","tcid":"a043b00dcbfd","uid":0})
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting acOptions with retrieved HVAC values
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting Pow: 1
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting Mod: 1
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting SetTem: 24
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting WdSpd: 3
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting Air: 0
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting Blo: 1
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting Health: 0
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting SwhSlp: 0
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting Lig: 0
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting SwingLfRig: 2
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting SwUpDn: 6
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting Quiet: 0
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting Tur: 0
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting StHt: 0
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting TemUn: 0
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting HeatCoolType: 0
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting TemRec: 0
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting SvSt: 0
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting SlpMod: 0
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Setting TemSen: 27
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] Done setting acOptions
2025-07-11 10:21:30.411 INFO (SyncWorker_5) [custom_components.gree.climate] UpdateHATargetTemperature: HA target temp set to: 24.0 °C. Device commands: SetTem: 24, TemRec: 0
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] HA lights option set according to HVAC state to: off
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] HA xfan option set according to HVAC state to: on
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] HA health option set according to HVAC state to: off
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] HA powersave option set according to HVAC state to: off
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] HA sleep option set according to HVAC state to: off
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] HA 8℃ heat option set according to HVAC state to: off
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] HA air option set according to HVAC state to: off
2025-07-11 10:21:30.411 DEBUG (SyncWorker_5) [custom_components.gree.climate] HA operation mode set according to HVAC state to: cool
2025-07-11 10:21:30.412 DEBUG (SyncWorker_5) [custom_components.gree.climate] HA swing mode set according to HVAC state to: Fixed in the lowest position
2025-07-11 10:21:30.412 DEBUG (SyncWorker_5) [custom_components.gree.climate] HA fan mode set according to HVAC state to: Medium
2025-07-11 10:21:30.412 DEBUG (SyncWorker_5) [custom_components.gree.climate] method UpdateHACurrentTemperature: TemSen: 27
2025-07-11 10:21:30.412 DEBUG (SyncWorker_5) [custom_components.gree.climate] method UpdateHACurrentTemperature: User has not chosen an offset, using process_temp_sensor() to automatically determine offset.
2025-07-11 10:21:30.412 DEBUG (SyncWorker_5) [custom_components.gree.climate] method UpdateHACurrentTemperature: HA current temperature set with device built-in temperature sensor state : 27°C
2025-07-11 10:21:30.412 DEBUG (SyncWorker_5) [custom_components.gree.climate] Finished SyncState
2025-07-11 10:21:30.412 DEBUG (MainThread) [custom_components.gree.climate] supported_features(): 425
2025-07-11 10:21:30.412 DEBUG (MainThread) [custom_components.gree.climate] temperature_unit(): °C
2025-07-11 10:21:30.412 DEBUG (MainThread) [custom_components.gree.climate] hvac_modes(): [<HVACMode.AUTO: 'auto'>, <HVACMode.COOL: 'cool'>, <HVACMode.DRY: 'dry'>, <HVACMode.FAN_ONLY: 'fan_only'>, <HVACMode.HEAT: 'heat'>, <HVACMode.OFF: 'off'>]
2025-07-11 10:21:30.412 DEBUG (MainThread) [custom_components.gree.climate] min_temp(): 16
2025-07-11 10:21:30.412 DEBUG (MainThread) [custom_components.gree.climate] max_temp(): 30
2025-07-11 10:21:30.412 DEBUG (MainThread) [custom_components.gree.climate] target_temperature_step(): None
2025-07-11 10:21:30.412 DEBUG (MainThread) [custom_components.gree.climate] fan_list(): ['Auto', 'Low', 'Medium-Low', 'Medium', 'Medium-High', 'High', 'Turbo', 'Quiet']
2025-07-11 10:21:30.412 DEBUG (MainThread) [custom_components.gree.climate] swing_modes(): ['Default', 'Swing in full range', 'Fixed in the upmost position', 'Fixed in the middle-up position', 'Fixed in the middle position', 'Fixed in the middle-low position', 'Fixed in the lowest position', 'Swing in the downmost region', 'Swing in the middle-low region', 'Swing in the middle region', 'Swing in the middle-up region', 'Swing in the upmost region']
2025-07-11 10:21:30.412 INFO (MainThread) [custom_components.gree.climate] available(): Device is online
2025-07-11 10:21:30.412 DEBUG (MainThread) [custom_components.gree.climate] hvac_mode(): cool
2025-07-11 10:21:30.412 DEBUG (MainThread) [custom_components.gree.climate] current_temperature(): 27
2025-07-11 10:21:30.412 DEBUG (MainThread) [custom_components.gree.climate] target_temperature(): 24.0
2025-07-11 10:21:30.412 DEBUG (MainThread) [custom_components.gree.climate] fan_mode(): Medium
2025-07-11 10:21:30.412 DEBUG (MainThread) [custom_components.gree.climate] swing_mode(): Fixed in the lowest position
2025-07-11 10:22:30.041 INFO (MainThread) [custom_components.gree.climate] available(): Device is online
2025-07-11 10:22:30.041 DEBUG (MainThread) [custom_components.gree.climate] supported_features(): 425
2025-07-11 10:22:30.041 DEBUG (MainThread) [custom_components.gree.climate] fan_list(): ['Auto', 'Low', 'Medium-Low', 'Medium', 'Medium-High', 'High', 'Turbo', 'Quiet']
2025-07-11 10:22:30.041 INFO (SyncWorker_10) [custom_components.gree.climate] set_fan_mode(): Quiet
2025-07-11 10:22:30.041 INFO (SyncWorker_10) [custom_components.gree.climate] Enabling quiet mode
2025-07-11 10:22:30.041 DEBUG (SyncWorker_10) [custom_components.gree.climate] Starting SyncState
2025-07-11 10:22:30.041 DEBUG (SyncWorker_10) [custom_components.gree.climate] Fetching(192.168.0.12, 7000, 10, {"cid":"app","i":0,"pack":"Cj5C7V2E86JOJcHJBM+KtolYJyjIE8KetKkJFBRUhaoZnlluFBAfoVgyFYlS8ZOTX4qBm59uG74tMuG7cG8nSvG6S2mFSUaoTXp6B5Pd9ngcfhSmzsWK7EoLQB+BuJyjQEFpS6UHnxX+d/B+gMJyYYk2l3Nl7KyRflBS3JjnxHIvv7PIlJFgX3iiBP88/oWMU6sbpki0O0usMscKQ4PVFAfnWq1U1YJlBkNH+C83OGqxtOxJXigGdoS7tyBO8/WWnGPvip3m5d7TwNpyogCOwEVuM5/UwxfMkgE0e1IqcFKKoUa7hxuStgtrlwA7FObQ","t":"pack","tcid":"a043b00dcbfd","uid":0})
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting acOptions with retrieved HVAC values
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting Pow: 1
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting Mod: 1
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting SetTem: 24
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting WdSpd: 3
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting Air: 0
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting Blo: 1
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting Health: 0
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting SwhSlp: 0
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting Lig: 0
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting SwingLfRig: 2
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting SwUpDn: 6
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting Quiet: 0
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting Tur: 0
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting StHt: 0
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting TemUn: 0
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting HeatCoolType: 0
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting TemRec: 0
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting SvSt: 0
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting SlpMod: 0
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Setting TemSen: 27
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Done setting acOptions
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Overwriting acOptions with new settings
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Overwriting Tur: 0
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Overwriting Quiet: 1
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Done overwriting acOptions
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Sending with Buzzer_ON_OFF=0 (Silent mode HA toggle is ON: True)
2025-07-11 10:22:30.165 DEBUG (SyncWorker_10) [custom_components.gree.climate] Fetching(192.168.0.12, 7000, 10, {"cid":"app","i":0,"pack":"qOtN1ol9Qwow6BesFW4CswqYxySZlVVmDvudiGOLLL4Xsw9T0i2p8dvSEW0GdOgGtlGMgeGh9ZqleAbdpb+qLIAv0weB/YjMzU6MJSq0EQjFqOLlEnCW6DPXnqODJWrQSivQ6xB8ImbrdvI9YNbvVowpY+qIp8g6c4EbeN94A935FRYs/4OnWZWh7EnfDHhJctwjYUt4ic67jmk1kLtNvpq7e1hytcTrg8dQXtN5REH953erjzdz4E1X20O6Kq8bdEBvEj3kVlWCf+Wvd/JRgKuZp0cvbDZXKshGfY9rXCi5GJH02cbNXIp3AsyjylWo","t":"pack","tcid":"a043b00dcbfd","uid":0})
2025-07-11 10:22:30.227 DEBUG (SyncWorker_10) [custom_components.gree.climate] Done sending state to HVAC: {'t': 'res', 'mac': 'a043b00dcbfd', 'val': [1, 1, 24, 3, 0, 1, 0, 0, 0, 2, 6, 1, 0, 0, 0, 0, 0, 0, 0, 0], 'p': [1, 1, 24, 3, 0, 1, 0, 0, 0, 2, 6, 1, 0, 0, 0, 0, 0, 0, 0, 0], 'opt': ['Pow', 'Mod', 'SetTem', 'WdSpd', 'Air', 'Blo', 'Health', 'SwhSlp', 'Lig', 'SwingLfRig', 'SwUpDn', 'Quiet', 'Tur', 'StHt', 'TemUn', 'HeatCoolType', 'TemRec', 'SvSt', 'SlpMod', 'Buzzer_ON_OFF'], 'r': 200}
2025-07-11 10:22:30.227 INFO (SyncWorker_10) [custom_components.gree.climate] UpdateHATargetTemperature: HA target temp set to: 24.0 °C. Device commands: SetTem: 24, TemRec: 0
2025-07-11 10:22:30.227 DEBUG (SyncWorker_10) [custom_components.gree.climate] HA lights option set according to HVAC state to: off
2025-07-11 10:22:30.227 DEBUG (SyncWorker_10) [custom_components.gree.climate] HA xfan option set according to HVAC state to: on
2025-07-11 10:22:30.227 DEBUG (SyncWorker_10) [custom_components.gree.climate] HA health option set according to HVAC state to: off
2025-07-11 10:22:30.227 DEBUG (SyncWorker_10) [custom_components.gree.climate] HA powersave option set according to HVAC state to: off
2025-07-11 10:22:30.227 DEBUG (SyncWorker_10) [custom_components.gree.climate] HA sleep option set according to HVAC state to: off
2025-07-11 10:22:30.227 DEBUG (SyncWorker_10) [custom_components.gree.climate] HA 8℃ heat option set according to HVAC state to: off
2025-07-11 10:22:30.227 DEBUG (SyncWorker_10) [custom_components.gree.climate] HA air option set according to HVAC state to: off
2025-07-11 10:22:30.227 DEBUG (SyncWorker_10) [custom_components.gree.climate] HA operation mode set according to HVAC state to: cool
2025-07-11 10:22:30.227 DEBUG (SyncWorker_10) [custom_components.gree.climate] HA swing mode set according to HVAC state to: Fixed in the lowest position
2025-07-11 10:22:30.227 DEBUG (SyncWorker_10) [custom_components.gree.climate] HA fan mode set according to HVAC state to: Quiet
2025-07-11 10:22:30.227 DEBUG (SyncWorker_10) [custom_components.gree.climate] method UpdateHACurrentTemperature: TemSen: 27
2025-07-11 10:22:30.227 DEBUG (SyncWorker_10) [custom_components.gree.climate] method UpdateHACurrentTemperature: User has not chosen an offset, using process_temp_sensor() to automatically determine offset.
2025-07-11 10:22:30.227 DEBUG (SyncWorker_10) [custom_components.gree.climate] method UpdateHACurrentTemperature: HA current temperature set with device built-in temperature sensor state : 27°C
2025-07-11 10:22:30.227 DEBUG (SyncWorker_10) [custom_components.gree.climate] Finished SyncState
2025-07-11 10:22:30.227 DEBUG (MainThread) [custom_components.gree.climate] supported_features(): 425
2025-07-11 10:22:30.227 DEBUG (MainThread) [custom_components.gree.climate] temperature_unit(): °C
2025-07-11 10:22:30.227 DEBUG (MainThread) [custom_components.gree.climate] hvac_modes(): [<HVACMode.AUTO: 'auto'>, <HVACMode.COOL: 'cool'>, <HVACMode.DRY: 'dry'>, <HVACMode.FAN_ONLY: 'fan_only'>, <HVACMode.HEAT: 'heat'>, <HVACMode.OFF: 'off'>]
2025-07-11 10:22:30.227 DEBUG (MainThread) [custom_components.gree.climate] min_temp(): 16
2025-07-11 10:22:30.228 DEBUG (MainThread) [custom_components.gree.climate] max_temp(): 30
2025-07-11 10:22:30.228 DEBUG (MainThread) [custom_components.gree.climate] target_temperature_step(): None
2025-07-11 10:22:30.228 DEBUG (MainThread) [custom_components.gree.climate] fan_list(): ['Auto', 'Low', 'Medium-Low', 'Medium', 'Medium-High', 'High', 'Turbo', 'Quiet']
2025-07-11 10:22:30.228 DEBUG (MainThread) [custom_components.gree.climate] swing_modes(): ['Default', 'Swing in full range', 'Fixed in the upmost position', 'Fixed in the middle-up position', 'Fixed in the middle position', 'Fixed in the middle-low position', 'Fixed in the lowest position', 'Swing in the downmost region', 'Swing in the middle-low region', 'Swing in the middle region', 'Swing in the middle-up region', 'Swing in the upmost region']
2025-07-11 10:22:30.228 INFO (MainThread) [custom_components.gree.climate] available(): Device is online
2025-07-11 10:22:30.228 DEBUG (MainThread) [custom_components.gree.climate] hvac_mode(): cool
2025-07-11 10:22:30.228 DEBUG (MainThread) [custom_components.gree.climate] supported_features(): 425
2025-07-11 10:22:30.228 DEBUG (MainThread) [custom_components.gree.climate] temperature_unit(): °C
2025-07-11 10:22:30.228 DEBUG (MainThread) [custom_components.gree.climate] current_temperature(): 27
2025-07-11 10:22:30.228 DEBUG (MainThread) [custom_components.gree.climate] target_temperature(): 24.0
2025-07-11 10:22:30.228 DEBUG (MainThread) [custom_components.gree.climate] fan_mode(): Quiet
2025-07-11 10:22:30.228 DEBUG (MainThread) [custom_components.gree.climate] swing_mode(): Fixed in the lowest position
2025-07-11 10:22:30.228 DEBUG (MainThread) [custom_components.gree.climate] should_poll()
2025-07-11 10:22:30.229 DEBUG (SyncWorker_0) [custom_components.gree.climate] update()
2025-07-11 10:22:30.229 DEBUG (SyncWorker_0) [custom_components.gree.climate] Starting SyncState
2025-07-11 10:22:30.229 DEBUG (SyncWorker_0) [custom_components.gree.climate] Fetching(192.168.0.12, 7000, 10, {"cid":"app","i":0,"pack":"Cj5C7V2E86JOJcHJBM+KtolYJyjIE8KetKkJFBRUhaoZnlluFBAfoVgyFYlS8ZOTX4qBm59uG74tMuG7cG8nSvG6S2mFSUaoTXp6B5Pd9ngcfhSmzsWK7EoLQB+BuJyjQEFpS6UHnxX+d/B+gMJyYYk2l3Nl7KyRflBS3JjnxHIvv7PIlJFgX3iiBP88/oWMU6sbpki0O0usMscKQ4PVFAfnWq1U1YJlBkNH+C83OGqxtOxJXigGdoS7tyBO8/WWnGPvip3m5d7TwNpyogCOwEVuM5/UwxfMkgE0e1IqcFKKoUa7hxuStgtrlwA7FObQ","t":"pack","tcid":"a043b00dcbfd","uid":0})
2025-07-11 10:22:30.334 DEBUG (MainThread) [custom_components.gree.climate] should_poll()
2025-07-11 10:22:30.334 DEBUG (MainThread) [custom_components.gree.climate] supported_features(): 425
2025-07-11 10:22:30.334 DEBUG (MainThread) [custom_components.gree.climate] temperature_unit(): °C
2025-07-11 10:22:30.334 DEBUG (MainThread) [custom_components.gree.climate] hvac_modes(): [<HVACMode.AUTO: 'auto'>, <HVACMode.COOL: 'cool'>, <HVACMode.DRY: 'dry'>, <HVACMode.FAN_ONLY: 'fan_only'>, <HVACMode.HEAT: 'heat'>, <HVACMode.OFF: 'off'>]
2025-07-11 10:22:30.334 DEBUG (MainThread) [custom_components.gree.climate] min_temp(): 16
2025-07-11 10:22:30.335 DEBUG (MainThread) [custom_components.gree.climate] max_temp(): 30
2025-07-11 10:22:30.335 DEBUG (MainThread) [custom_components.gree.climate] target_temperature_step(): None
2025-07-11 10:22:30.335 DEBUG (MainThread) [custom_components.gree.climate] fan_list(): ['Auto', 'Low', 'Medium-Low', 'Medium', 'Medium-High', 'High', 'Turbo', 'Quiet']
2025-07-11 10:22:30.335 DEBUG (MainThread) [custom_components.gree.climate] swing_modes(): ['Default', 'Swing in full range', 'Fixed in the upmost position', 'Fixed in the middle-up position', 'Fixed in the middle position', 'Fixed in the middle-low position', 'Fixed in the lowest position', 'Swing in the downmost region', 'Swing in the middle-low region', 'Swing in the middle region', 'Swing in the middle-up region', 'Swing in the upmost region']
2025-07-11 10:22:30.335 INFO (MainThread) [custom_components.gree.climate] available(): Device is online
2025-07-11 10:22:30.335 DEBUG (MainThread) [custom_components.gree.climate] hvac_mode(): cool
2025-07-11 10:22:30.335 DEBUG (MainThread) [custom_components.gree.climate] supported_features(): 425
2025-07-11 10:22:30.335 DEBUG (MainThread) [custom_components.gree.climate] temperature_unit(): °C
2025-07-11 10:22:30.335 DEBUG (MainThread) [custom_components.gree.climate] current_temperature(): 27
2025-07-11 10:22:30.335 DEBUG (MainThread) [custom_components.gree.climate] target_temperature(): 24.0
2025-07-11 10:22:30.335 DEBUG (MainThread) [custom_components.gree.climate] fan_mode(): Quiet
2025-07-11 10:22:30.335 DEBUG (MainThread) [custom_components.gree.climate] swing_mode(): Fixed in the lowest position
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting acOptions with retrieved HVAC values
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting Pow: 1
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting Mod: 1
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting SetTem: 24
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting WdSpd: 3
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting Air: 0
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting Blo: 1
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting Health: 0
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting SwhSlp: 0
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting Lig: 0
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting SwingLfRig: 2
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting SwUpDn: 6
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting Quiet: 1
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting Tur: 0
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting StHt: 0
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting TemUn: 0
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting HeatCoolType: 0
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting TemRec: 0
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting SvSt: 0
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting SlpMod: 0
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Setting TemSen: 27
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Done setting acOptions
2025-07-11 10:22:30.674 INFO (SyncWorker_0) [custom_components.gree.climate] UpdateHATargetTemperature: HA target temp set to: 24.0 °C. Device commands: SetTem: 24, TemRec: 0
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] HA lights option set according to HVAC state to: off
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] HA xfan option set according to HVAC state to: on
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] HA health option set according to HVAC state to: off
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] HA powersave option set according to HVAC state to: off
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] HA sleep option set according to HVAC state to: off
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] HA 8℃ heat option set according to HVAC state to: off
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] HA air option set according to HVAC state to: off
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] HA operation mode set according to HVAC state to: cool
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] HA swing mode set according to HVAC state to: Fixed in the lowest position
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] HA fan mode set according to HVAC state to: Quiet
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] method UpdateHACurrentTemperature: TemSen: 27
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] method UpdateHACurrentTemperature: User has not chosen an offset, using process_temp_sensor() to automatically determine offset.
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] method UpdateHACurrentTemperature: HA current temperature set with device built-in temperature sensor state : 27°C
2025-07-11 10:22:30.674 DEBUG (SyncWorker_0) [custom_components.gree.climate] Finished SyncState
2025-07-11 10:22:30.675 DEBUG (MainThread) [custom_components.gree.climate] supported_features(): 425
2025-07-11 10:22:30.675 DEBUG (MainThread) [custom_components.gree.climate] temperature_unit(): °C
2025-07-11 10:22:30.675 DEBUG (MainThread) [custom_components.gree.climate] hvac_modes(): [<HVACMode.AUTO: 'auto'>, <HVACMode.COOL: 'cool'>, <HVACMode.DRY: 'dry'>, <HVACMode.FAN_ONLY: 'fan_only'>, <HVACMode.HEAT: 'heat'>, <HVACMode.OFF: 'off'>]
2025-07-11 10:22:30.675 DEBUG (MainThread) [custom_components.gree.climate] min_temp(): 16
2025-07-11 10:22:30.675 DEBUG (MainThread) [custom_components.gree.climate] max_temp(): 30
2025-07-11 10:22:30.675 DEBUG (MainThread) [custom_components.gree.climate] target_temperature_step(): None
2025-07-11 10:22:30.675 DEBUG (MainThread) [custom_components.gree.climate] fan_list(): ['Auto', 'Low', 'Medium-Low', 'Medium', 'Medium-High', 'High', 'Turbo', 'Quiet']
2025-07-11 10:22:30.675 DEBUG (MainThread) [custom_components.gree.climate] swing_modes(): ['Default', 'Swing in full range', 'Fixed in the upmost position', 'Fixed in the middle-up position', 'Fixed in the middle position', 'Fixed in the middle-low position', 'Fixed in the lowest position', 'Swing in the downmost region', 'Swing in the middle-low region', 'Swing in the middle region', 'Swing in the middle-up region', 'Swing in the upmost region']
2025-07-11 10:22:30.675 INFO (MainThread) [custom_components.gree.climate] available(): Device is online
2025-07-11 10:22:30.675 DEBUG (MainThread) [custom_components.gree.climate] hvac_mode(): cool
2025-07-11 10:22:30.675 DEBUG (MainThread) [custom_components.gree.climate] current_temperature(): 27
2025-07-11 10:22:30.675 DEBUG (MainThread) [custom_components.gree.climate] target_temperature(): 24.0
2025-07-11 10:22:30.675 DEBUG (MainThread) [custom_components.gree.climate] fan_mode(): Quiet
2025-07-11 10:22:30.675 DEBUG (MainThread) [custom_components.gree.climate] swing_mode(): Fixed in the lowest position
2025-07-11 10:23:30.335 DEBUG (MainThread) [custom_components.gree.climate] should_poll()
2025-07-11 10:23:30.335 DEBUG (SyncWorker_12) [custom_components.gree.climate] update()
2025-07-11 10:23:30.336 DEBUG (SyncWorker_12) [custom_components.gree.climate] Starting SyncState
2025-07-11 10:23:30.336 DEBUG (SyncWorker_12) [custom_components.gree.climate] Fetching(192.168.0.12, 7000, 10, {"cid":"app","i":0,"pack":"Cj5C7V2E86JOJcHJBM+KtolYJyjIE8KetKkJFBRUhaoZnlluFBAfoVgyFYlS8ZOTX4qBm59uG74tMuG7cG8nSvG6S2mFSUaoTXp6B5Pd9ngcfhSmzsWK7EoLQB+BuJyjQEFpS6UHnxX+d/B+gMJyYYk2l3Nl7KyRflBS3JjnxHIvv7PIlJFgX3iiBP88/oWMU6sbpki0O0usMscKQ4PVFAfnWq1U1YJlBkNH+C83OGqxtOxJXigGdoS7tyBO8/WWnGPvip3m5d7TwNpyogCOwEVuM5/UwxfMkgE0e1IqcFKKoUa7hxuStgtrlwA7FObQ","t":"pack","tcid":"a043b00dcbfd","uid":0})
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting acOptions with retrieved HVAC values
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting Pow: 1
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting Mod: 1
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting SetTem: 24
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting WdSpd: 3
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting Air: 0
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting Blo: 1
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting Health: 0
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting SwhSlp: 0
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting Lig: 0
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting SwingLfRig: 2
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting SwUpDn: 6
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting Quiet: 1
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting Tur: 0
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting StHt: 0
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting TemUn: 0
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting HeatCoolType: 0
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting TemRec: 0
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting SvSt: 0
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting SlpMod: 0
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Setting TemSen: 27
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Done setting acOptions
2025-07-11 10:23:30.711 INFO (SyncWorker_12) [custom_components.gree.climate] UpdateHATargetTemperature: HA target temp set to: 24.0 °C. Device commands: SetTem: 24, TemRec: 0
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] HA lights option set according to HVAC state to: off
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] HA xfan option set according to HVAC state to: on
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] HA health option set according to HVAC state to: off
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] HA powersave option set according to HVAC state to: off
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] HA sleep option set according to HVAC state to: off
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] HA 8℃ heat option set according to HVAC state to: off
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] HA air option set according to HVAC state to: off
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] HA operation mode set according to HVAC state to: cool
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] HA swing mode set according to HVAC state to: Fixed in the lowest position
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] HA fan mode set according to HVAC state to: Quiet
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] method UpdateHACurrentTemperature: TemSen: 27
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] method UpdateHACurrentTemperature: User has not chosen an offset, using process_temp_sensor() to automatically determine offset.
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] method UpdateHACurrentTemperature: HA current temperature set with device built-in temperature sensor state : 27°C
2025-07-11 10:23:30.711 DEBUG (SyncWorker_12) [custom_components.gree.climate] Finished SyncState
2025-07-11 10:23:30.712 DEBUG (MainThread) [custom_components.gree.climate] supported_features(): 425
2025-07-11 10:23:30.712 DEBUG (MainThread) [custom_components.gree.climate] temperature_unit(): °C
2025-07-11 10:23:30.712 DEBUG (MainThread) [custom_components.gree.climate] hvac_modes(): [<HVACMode.AUTO: 'auto'>, <HVACMode.COOL: 'cool'>, <HVACMode.DRY: 'dry'>, <HVACMode.FAN_ONLY: 'fan_only'>, <HVACMode.HEAT: 'heat'>, <HVACMode.OFF: 'off'>]
2025-07-11 10:23:30.712 DEBUG (MainThread) [custom_components.gree.climate] min_temp(): 16
2025-07-11 10:23:30.712 DEBUG (MainThread) [custom_components.gree.climate] max_temp(): 30
2025-07-11 10:23:30.712 DEBUG (MainThread) [custom_components.gree.climate] target_temperature_step(): None
2025-07-11 10:23:30.712 DEBUG (MainThread) [custom_components.gree.climate] fan_list(): ['Auto', 'Low', 'Medium-Low', 'Medium', 'Medium-High', 'High', 'Turbo', 'Quiet']
2025-07-11 10:23:30.712 DEBUG (MainThread) [custom_components.gree.climate] swing_modes(): ['Default', 'Swing in full range', 'Fixed in the upmost position', 'Fixed in the middle-up position', 'Fixed in the middle position', 'Fixed in the middle-low position', 'Fixed in the lowest position', 'Swing in the downmost region', 'Swing in the middle-low region', 'Swing in the middle region', 'Swing in the middle-up region', 'Swing in the upmost region']
2025-07-11 10:23:30.712 INFO (MainThread) [custom_components.gree.climate] available(): Device is online
2025-07-11 10:23:30.712 DEBUG (MainThread) [custom_components.gree.climate] hvac_mode(): cool
2025-07-11 10:23:30.712 DEBUG (MainThread) [custom_components.gree.climate] current_temperature(): 27
2025-07-11 10:23:30.712 DEBUG (MainThread) [custom_components.gree.climate] target_temperature(): 24.0
2025-07-11 10:23:30.712 DEBUG (MainThread) [custom_components.gree.climate] fan_mode(): Quiet
2025-07-11 10:23:30.712 DEBUG (MainThread) [custom_components.gree.climate] swing_mode(): Fixed in the lowest position
2025-07-11 10:24:30.338 DEBUG (MainThread) [custom_components.gree.climate] should_poll()
2025-07-11 10:24:30.338 DEBUG (SyncWorker_7) [custom_components.gree.climate] update()
2025-07-11 10:24:30.338 DEBUG (SyncWorker_7) [custom_components.gree.climate] Starting SyncState
2025-07-11 10:24:30.338 DEBUG (SyncWorker_7) [custom_components.gree.climate] Fetching(192.168.0.12, 7000, 10, {"cid":"app","i":0,"pack":"Cj5C7V2E86JOJcHJBM+KtolYJyjIE8KetKkJFBRUhaoZnlluFBAfoVgyFYlS8ZOTX4qBm59uG74tMuG7cG8nSvG6S2mFSUaoTXp6B5Pd9ngcfhSmzsWK7EoLQB+BuJyjQEFpS6UHnxX+d/B+gMJyYYk2l3Nl7KyRflBS3JjnxHIvv7PIlJFgX3iiBP88/oWMU6sbpki0O0usMscKQ4PVFAfnWq1U1YJlBkNH+C83OGqxtOxJXigGdoS7tyBO8/WWnGPvip3m5d7TwNpyogCOwEVuM5/UwxfMkgE0e1IqcFKKoUa7hxuStgtrlwA7FObQ","t":"pack","tcid":"a043b00dcbfd","uid":0})
2025-07-11 10:24:30.482 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting acOptions with retrieved HVAC values
2025-07-11 10:24:30.482 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Pow: 1
2025-07-11 10:24:30.482 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Mod: 1
2025-07-11 10:24:30.482 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting SetTem: 24
2025-07-11 10:24:30.482 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting WdSpd: 3
2025-07-11 10:24:30.482 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Air: 0
2025-07-11 10:24:30.482 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Blo: 1
2025-07-11 10:24:30.482 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Health: 0
2025-07-11 10:24:30.482 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting SwhSlp: 0
2025-07-11 10:24:30.482 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Lig: 0
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting SwingLfRig: 2
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting SwUpDn: 6
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Quiet: 1
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting Tur: 0
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting StHt: 0
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting TemUn: 0
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting HeatCoolType: 0
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting TemRec: 0
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting SvSt: 0
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting SlpMod: 0
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] Setting TemSen: 27
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] Done setting acOptions
2025-07-11 10:24:30.483 INFO (SyncWorker_7) [custom_components.gree.climate] UpdateHATargetTemperature: HA target temp set to: 24.0 °C. Device commands: SetTem: 24, TemRec: 0
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA lights option set according to HVAC state to: off
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA xfan option set according to HVAC state to: on
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA health option set according to HVAC state to: off
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA powersave option set according to HVAC state to: off
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA sleep option set according to HVAC state to: off
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA 8℃ heat option set according to HVAC state to: off
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA air option set according to HVAC state to: off
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA operation mode set according to HVAC state to: cool
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA swing mode set according to HVAC state to: Fixed in the lowest position
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] HA fan mode set according to HVAC state to: Quiet
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] method UpdateHACurrentTemperature: TemSen: 27
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] method UpdateHACurrentTemperature: User has not chosen an offset, using process_temp_sensor() to automatically determine offset.
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] method UpdateHACurrentTemperature: HA current temperature set with device built-in temperature sensor state : 27°C
2025-07-11 10:24:30.483 DEBUG (SyncWorker_7) [custom_components.gree.climate] Finished SyncState
3万
发表于 2025-7-11 14:15:29 | 显示全部楼层
空调实际上低风和实际上的静音风具体区别在哪里?
我理解的静音风就是最小风,强劲风就是最大风。
另外你的空调支持蜂鸣器提示音(Buzzer_ON_OFF)静音吗?
 楼主| 发表于 2025-7-11 17:26:30 | 显示全部楼层
另外你的 ...
低风和静音风不一样,格力+ APP上可以设置静音风,此时几乎没有声音,但是低风明显能听到声音。
支持蜂鸣器提示音。
GMT+8, 2025-12-16 03:19 , Processed in 0.652831 second(s), 5 queries , MemCached On.
