查看: 2319|回复: 0
[技术探讨] 哪位大神能指导一下呀?下面的错误log
发表于 2018-3-6 20:36:38 | 显示全部楼层 |阅读模式
Timer got out of sync. Resetting
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午8:18 core.py (ERROR)
Setup failed for cloud: Could not install all requirements.
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午8:18 setup.py (ERROR)
Not initializing cloud because could not install requirement warrant==0.6.1
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午8:18 requirements.py (ERROR)
Unable to install package warrant==0.6.1: Command "/usr/local/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-gp61dpno/pycryptodome/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-vwk5ud1a-record/install-record.txt --single-version-externally-managed --prefix --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-gp61dpno/pycryptodome/
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午8:18 util/package.py (ERROR)
Setup failed for homekit: Could not install all requirements.
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午8:16 setup.py (ERROR)
Not initializing homekit because could not install requirement HAP-python==1.1.5
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午8:16 requirements.py (ERROR)
Unable to install package HAP-python==1.1.5: Command "/usr/local/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-lem0l548/pycryptodome/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-014qr1qe-record/install-record.txt --single-version-externally-managed --prefix --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-lem0l548/pycryptodome/
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午8:16 util/package.py (ERROR)
Setup failed for discovery: Could not install all requirements.
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午8:13 setup.py (ERROR)
Not initializing discovery because could not install requirement netdisco==1.2.4
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午8:13 requirements.py (ERROR)
Unable to install package netdisco==1.2.4: Command "/usr/local/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-sln0dkww/netifaces/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-iylypm89-record/install-record.txt --single-version-externally-managed --prefix --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-sln0dkww/netifaces/
[color=var(--paper-item-body-secondary-color, var(--secondary-text-color))]下午8:13 util/package.py (ERROR)
GMT+8, 2026-1-6 22:01 , Processed in 0.805634 second(s), 9 queries , MemCached On.
