查看: 8859|回复: 0
[求助] AppDaemon2 安装
发表于 2018-3-6 19:20:32 | 显示全部楼层 |阅读模式
WARNING: You are using an non-recommended Home Assistant URL!WARNING: Setting the "ha_url" option in your AppDaemon config toWARNING: "http://hassio/homeassistant" is recommended![cont-init.d] 31-ha-url.sh: exited 0.[cont-init.d] 50-compiled-symlink.sh: executing... [cont-init.d] 50-compiled-symlink.sh: exited 0.[cont-init.d] 80-system-packages.sh: executing... [cont-init.d] 80-system-packages.sh: exited 0.[cont-init.d] 81-python-packages.sh: executing... [cont-init.d] 81-python-packages.sh: exited 0.[cont-init.d] done.[services.d] starting servicesstarting version 3.2.4[services.d] done.Traceback (most recent call last):  File "/usr/bin/appdaemon", line 11, in <module>    sys.exit(main())  File "/usr/lib/python3.6/site-packages/appdaemon/admain.py", line 230, in main    conf.logfile = config['AppDaemon'].get("logfile")KeyError: 'AppDaemon'Traceback (most recent call last):  File "/usr/bin/appdaemon", line 11, in <module>    sys.exit(main())  File "/usr/lib/python3.6/site-packages/appdaemon/admain.py", line 230, in main    conf.logfile = config['AppDaemon'].get("logfile")KeyError: 'AppDaemon'Traceback (most recent call last):  File "/usr/bin/appdaemon", line 11, in <module>    sys.exit(main())  File "/usr/lib/python3.6/site-packages/appdaemon/admain.py", line 230, in main    conf.logfile = config['AppDaemon'].get("logfile")KeyError: 'AppDaemon'Traceback (most recent call last):  File "/usr/bin/appdaemon", line 11, in <module>    sys.exit(main())  File "/usr/lib/python3.6/site-packages/appdaemon/admain.py", line 230, in main    conf.logfile = config['AppDaemon'].get("logfile")KeyError: 'AppDaemon'Traceback (most recent call last):  File "/usr/bin/appdaemon", line 11, in <module>    sys.exit(main())  File "/usr/lib/python3.6/site-packages/appdaemon/admain.py", line 230, in main    conf.logfile = config['AppDaemon'].get("logfile")KeyError: 'AppDaemon'求助,这个问题怎么解决各位大神?
GMT+8, 2025-12-25 07:53 , Processed in 0.073669 second(s), 7 queries , MemCached On.
