查看: 5751|回复: 6
[已解决] docker安装homeassistant连接博联RM2遇到的错误,大神看看
发表于 2018-3-6 11:00:52 | 显示全部楼层 |阅读模式
docker0.64版本,安装homeassistant遇到的错误提示无法连接到博联RM2,想问下有遇到过的朋友吗?然后是怎么解决的,万分感谢!
Press the button to load the full Home Assistant log.
2018-03-06 02:52:43 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform broadlinkTraceback (most recent call last):  File "/usr/local/lib/python3.6/site-packages/broadlink/__init__.py", line 5, in <module>    from Crypto.Cipher import AES  File "/usr/local/lib/python3.6/site-packages/Crypto/Cipher/__init__.py", line 3, in <module>    from Crypto.Cipher._mode_ecb import _create_ecb_cipher  File "/usr/local/lib/python3.6/site-packages/Crypto/Cipher/_mode_ecb.py", line 29, in <module>    from Crypto.Util._raw_api import (load_pycryptodome_raw_lib,  File "/usr/local/lib/python3.6/site-packages/Crypto/Util/_raw_api.py", line 32, in <module>    from Crypto.Util.py3compat import byte_stringImportError: cannot import name 'byte_string'During handling of the above exception, another exception occurred:Traceback (most recent call last):  File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 84, in async_setup    SLOW_SETUP_MAX_WAIT, loop=hass.loop)  File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for    return fut.result()  File "/usr/local/lib/python3.6/asyncio/futures.py", line 243, in result    raise self._exception  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run    result = self.fn(*self.args, **self.kwargs)  File "/usr/src/app/homeassistant/components/sensor/broadlink.py", line 60, in setup_platform    broadlink_data = BroadlinkData(update_interval, host, mac_addr, timeout)  File "/usr/src/app/homeassistant/components/sensor/broadlink.py", line 107, in __init__    import broadlink  File "/usr/local/lib/python3.6/site-packages/broadlink/__init__.py", line 7, in <module>    import pyaesModuleNotFoundError: No module named 'pyaes'2018-03-06 02:52:46 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform broadlinkTraceback (most recent call last):  File "/usr/local/lib/python3.6/site-packages/broadlink/__init__.py", line 5, in <module>    from Crypto.Cipher import AES  File "/usr/local/lib/python3.6/site-packages/Crypto/Cipher/__init__.py", line 3, in <module>    from Crypto.Cipher._mode_ecb import _create_ecb_cipher  File "/usr/local/lib/python3.6/site-packages/Crypto/Cipher/_mode_ecb.py", line 29, in <module>    from Crypto.Util._raw_api import (load_pycryptodome_raw_lib,  File "/usr/local/lib/python3.6/site-packages/Crypto/Util/_raw_api.py", line 32, in <module>    from Crypto.Util.py3compat import byte_stringImportError: cannot import name 'byte_string'During handling of the above exception, another exception occurred:
 楼主| 发表于 2018-3-6 11:04:26 | 显示全部楼层
解决办法 升级到 0.64.3即可!有遇到的朋友可以试试!~~
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-3-6 12:00:58 | 显示全部楼层
a903497400 发表于 2018-3-6 11:04
解决办法 升级到 0.64.4即可!有遇到的朋友可以试试!~~
出来了???我怎么在官网没看到??
发表于 2018-3-6 15:30:14 | 显示全部楼层
官网没看到有啊!
活跃会员
发表于 2018-3-6 20:55:25 | 显示全部楼层
官网0.64.3已经解决了博联的问题
 楼主| 发表于 2018-3-8 14:17:38 | 显示全部楼层
jyz_0501 发表于 2018-3-6 12:00
出来了???我怎么在官网没看到??
搞错了  是 0.64.3
 楼主| 发表于 2018-3-8 14:18:45 | 显示全部楼层
zhao_am 发表于 2018-3-6 15:30
官网没看到有啊!
搞错了  是 0.64.3
GMT+8, 2025-12-25 07:52 , Processed in 0.442263 second(s), 13 queries , MemCached On.
