查看: 4573|回复: 0
[求助] home-assistant设备发现错误信息求助,怎么排除。添加iOS:出现
发表于 2018-3-5 12:39:53 | 显示全部楼层 |阅读模式
Mon Mar 05 2018 12:37:34 GMT+0800 (CST)
Error executing service <ServiceCall device_tracker.see: gps_accuracy=65, battery=39, dev_id=“ptlzx”的 iPhone, hostname=“ptlzx”的 iPhone, battery_status=Unplugged, gps=[25.434115336896113, 119.01457793293461]>
  File "/usr/src/app/homeassistant/core.py", line 1010, in _event_to_service_call
    yield from service_handler.func(service_call)
  File "/usr/src/app/homeassistant/components/device_tracker/__init__.py", line 209, in async_see_service
    yield from tracker.async_see(**args)
  File "/usr/src/app/homeassistant/components/device_tracker/__init__.py", line 272, in async_see
    dev_id = cv.slug(str(dev_id).lower())
  File "/usr/src/app/homeassistant/helpers/config_validation.py", line 299, in slug
    raise vol.Invalid('invalid slug {} (try {})'.format(value, slg))
voluptuous.error.Invalid: invalid slug “ptlzx”的 iphone (try _iphone)
GMT+8, 2025-12-25 07:53 , Processed in 0.083636 second(s), 7 queries , MemCached On.
