查看: 701|回复: 0
【bug反馈】冬瓜HAOS重启后无法启动supervisor
发表于 2025-6-4 23:42:00 | 显示全部楼层 |阅读模式
今天盒子强制断电重启后,supervisor无法正常启动:
<div>~ # docker ps -a
CONTAINER ID   IMAGE                                                            COMMAND                  CREATED              STATUS                           PORTS        NAMES
ff452d339452   ghcr.io/home-assistant/aarch64-hassio-supervisor:latest          "/init"                  About a minute ago   Exited (0) About a minute ago
<div>~ # docker logs ff452d339452 -n 100
hassio-supervisor
[15:30:44] INFO: Using udev information from host
[15:30:44] INFO: Starting local supervisor watchdog...
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "/usr/src/supervisor/supervisor/__main__.py", line 15, in <module>
    from supervisor import bootstrap  # noqa: E402
  File "/usr/src/supervisor/supervisor/bootstrap.py", line 13, in <module>
    from .addons.manager import AddonManager
  File "/usr/src/supervisor/supervisor/addons/manager.py", line 12, in <module>
    from ..const import AddonBoot, AddonStartup, AddonState
  File "/usr/src/supervisor/supervisor/const.py", line 17
    URL_HASSIO_VERSION = "https://version.wghaos.com/s905x3_bigfs-release-B�.json?os=15.2&su=2025.05.6.dev3103&arch="
SyntaxError: (unicode error) 'utf-8' codec can't decode byte 0x81 in position 50: invalid start byte
[15:30:45] WARNING: Halt Supervisor
[15:30:45] INFO: Supervisor restart after closing
s6-rc: info: service legacy-services: stopping
[15:30:45] INFO: Watchdog restart after closing
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped</div></div>
问题出现在字符上,因为不是标准的utf-8字符,会导致python启动失败。我看了下Github源码,发现官方镜像此处的链接应为
URL_HASSIO_VERSION = "https://version.home-assistant.io/{channel}.json"
说明冬瓜HAOS有对该镜像做了专门的适配(盲猜是冬瓜HAOS的OTA)。上面的链接猜测是直接拼接了系统的版本信息(os=xxx)&使用区域(B�),但是没有判断拼接的内容是否合法,导致链接出现问题。
请问这里应该如何解决呢?
更新:
我在冬瓜HAOS伴侣里尝试降级OS的版本,也有类似的报错:
获取版本信息失败: parse "https://version.wghaos.com/s905x3_bigfs-release-B\x19\x81.json": net/url: invalid control character in URL
最终找到一个临时解决方法:我把容器里的“-B�” 去掉再重启容器,supervisor就正常启动了。但是如果以后要重建supervisor,估计也会有相同的问题
GMT+8, 2025-12-29 15:06 , Processed in 1.459036 second(s), 7 queries , MemCached On.
