查看: 2096|回复: 6
[技术讨论] armbian 配置为 Airplay 和 DLNA 音频服务器
发表于 2025-5-19 13:33:23 | 显示全部楼层 |阅读模式
我用的是 debian 12 发行版:
Airplay
编译安装 nqptp
git clone https://github.com/mikebrady/nqptp.git
cd nqptp
autoreconf -fi
./configure --with-systemd-startup
make
sudo make install
编译安装 alac
git clone https://github.com/mikebrady/alac.git
cd alac
autoreconf -fi
./configure
make
sudo make install
sudo ldconfig
编译安装 shairport-sync
sudo apt install --no-install-recommends build-essential git autoconf automake libtool libpopt-dev libconfig-dev libasound2-dev avahi-daemon libavahi-client-dev libssl-dev libsoxr-dev libplist-dev libsodium-dev libavutil-dev libavcodec-dev libavformat-dev uuid-dev libgcrypt-dev libmosquitto-dev xxd
git clone https://github.com/mikebrady/shairport-sync.git
cd shairport-sync
autoreconf -fi
./configure --sysconfdir=/etc --with-alsa --with-soxr --with-apple-alac --with-metadata --with-mqtt-client --with-avahi --with-ssl=openssl --with-systemd --with-airplay-2
make
sudo make install
启用服务
修改 /etc/shairport-sync.conf 来配置服务器
sudo systemctl daemon-reload
sudo systemctl enable nqptp
sudo systemctl start nqptp
sudo systemctl enable shairport-sync
sudo systemctl start shairport-sync
DLNA
编译安装 gmrender-resurrect
sudo apt install --no-install-recommends build-essential autoconf automake libtool pkg-config  libupnp-dev libgstreamer1.0-dev gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav gstreamer1.0-alsa git
git clone https://github.com/hzeller/gmrender-resurrect.git
目前主线有 bug ,无法将渲染器名设置为中文,我们引入这个 pr 解决这个问题:
cd gmrender-resurrect
git fetch origin pull/284/head:pr-284
git checkout pr-284
继续编译:
./autogen.sh
./configure
make
sudo make install
配置服务
编写 /usr/lib/systemd/system/gmrender-resurrect.service 内容如下:
[Unit]
Description=gmrender-resurrect service
After=network-online.target sound.target
Requires=network-online.target sound.target
[Service]
EnvironmentFile=/etc/default/gmrender
ExecStart=/usr/local/bin/gmediarender -f "$UPNP_DEVICE_NAME" -u "$UPNP_UUID" \
    --gstout-audiosink=alsasink --gstout-audiodevice "$AUDIO_DEVICE" \
    --logfile=/tmp/gmediarenderer.log --gstout-initial-volume-db=-10
Restart=always
[Install]
WantedBy=multi-user.target
执行如下命令生成配置文件
sudo tee /etc/default/gmrender <<EOF
UPNP_UUID=$(ip link show | awk '/ether/ {print "salt-" $2}' | head -1 | md5sum | awk '{print $1}')
UPNP_DEVICE_NAME="MyMediaRenderer"
AUDIO_DEVICE="sysdefault"
EOF
启用服务
sudo systemctl enable gmrender-resurrect.service
sudo systemctl start gmrender-resurrect.service
参与人数 1金钱 +12 收起 理由
隔壁的王叔叔 + 12
发表于 2025-6-3 11:26:12 | 显示全部楼层
很实用的帖子,另请问AirPlay/DLNA服务是否会独占音频输出设备?(即:Airplay播放时,启动Dlna,可以正常播放吗?)
发表于 2025-6-3 11:35:45 | 显示全部楼层
wh1tequartz 发表于 2025-6-3 11:26
很实用的帖子,另请问AirPlay/DLNA服务是否会独占音频输出设备?(即:Airplay播放时,启动Dlna,可以正常 ...
我手里三台垃圾盒子和一台树莓派3B都是同时安装了这两个服务,只有树莓派可以两个同时用,其他垃圾盒子不行,airplay播放后就无法dlna了,原因未知,我也搞不定。
 楼主| 发表于 2025-6-3 13:57:28 | 显示全部楼层
我最近在搞的,用PA而不是alsa,就能做到各个服务都能使用音频输出设备(同时出声)
我又加入了蓝牙,可以做到手机蓝牙连接到盒子之后自动切换播放手机声音(此时 dlna 和 airplay 就没声了)
发表于 2025-6-19 00:00:25 | 显示全部楼层
你好,按照这个教程,没有启动成功,日志如下:
问题应该出在这里:  Jun 18 23:06:11 armbian gmediarender[8055]: Failed to initialize: Unknown option -1
root@armbian:~# journalctl -u gmrender-resurrect.service
Jun 18 23:06:11 armbian systemd[1]: Started gmrender-resurrect.service - gmrender-resurrect service.
Jun 18 23:06:11 armbian systemd[1]: gmrender-resurrect.service: Main process exited, code=exited, status=1/FAILURE
Jun 18 23:06:11 armbian systemd[1]: gmrender-resurrect.service: Failed with result 'exit-code'.
Jun 18 23:06:11 armbian systemd[1]: gmrender-resurrect.service: Scheduled restart job, restart counter is at 1.
Jun 18 23:06:11 armbian systemd[1]: Stopped gmrender-resurrect.service - gmrender-resurrect service.
Jun 18 23:06:11 armbian gmediarender[8057]: Failed to initialize: Unknown option -1
Jun 18 23:06:12 armbian systemd[1]: gmrender-resurrect.service: Scheduled restart job, restart counter is at 2.
Jun 18 23:06:12 armbian systemd[1]: Stopped gmrender-resurrect.service - gmrender-resurrect service.
Jun 18 23:06:12 armbian systemd[1]: Started gmrender-resurrect.service - gmrender-resurrect service.
Jun 18 23:06:12 armbian gmediarender[8058]: Failed to initialize: Unknown option -1
Jun 18 23:06:12 armbian systemd[1]: gmrender-resurrect.service: Main process exited, code=exited, status=1/FAILURE
Jun 18 23:06:12 armbian systemd[1]: gmrender-resurrect.service: Failed with result 'exit-code'.
Jun 18 23:06:12 armbian systemd[1]: gmrender-resurrect.service: Scheduled restart job, restart counter is at 3.
Jun 18 23:06:12 armbian gmediarender[8059]: Failed to initialize: Unknown option -1
Jun 18 23:06:12 armbian systemd[1]: gmrender-resurrect.service: Scheduled restart job, restart counter is at 4.
Jun 18 23:06:12 armbian gmediarender[8060]: Failed to initialize: Unknown option -1
Jun 18 23:06:12 armbian systemd[1]: gmrender-resurrect.service: Scheduled restart job, restart counter is at 5.
Jun 18 23:06:12 armbian systemd[1]: gmrender-resurrect.service: Start request repeated too quickly.
Jun 18 23:06:12 armbian systemd[1]: Failed to start gmrender-resurrect.service - gmrender-resurrect service.
发表于 2025-6-19 00:03:11 | 显示全部楼层
配置文件如下:
root@armbian:~# cat  /usr/lib/systemd/system/gmrender-resurrect.service
[Unit]
[Service]
Restart=always
[Install]
以下文件没有使用tee创建,而使用vim创建(问题会不会出这里了?)
root@armbian:~# cat /etc/default/gmrender
请赐教
发表于 2025-6-19 00:07:27 | 显示全部楼层
我又加入了蓝牙,可以 ...
期待搞好了分享下,单独搞过AirPlay或DLNA,能自动切换就太好了,另外盒子有推荐吗?用3.5mm接口还是HDMI转之类
GMT+8, 2026-1-15 21:57 , Processed in 0.423697 second(s), 11 queries , MemCached On.
