查看: 11804|回复: 4
[新奇玩法] homeassistant0.64直接支持siri~
laai
发表于 2018-3-2 23:34:09 | 显示全部楼层 |阅读模式
HomeKit
Native HomeKit support has arrived! Thanks to @cdce8p It is now possible to expose some devices over HomeKit to allow control via Siri and other things speaking the HomeKit protocol. Initial support has been added for temperature sensors and cover devices. Expect more devices to be added soon.
Check the HomeKit docs
谁知道怎么设置吗?
根据官网文件是不是这样就行了??
# Example for HomeKit setuphomekit:  pincode: '123-45-678'谢谢。。。
hugo
发表于 2018-3-3 00:02:17 | 显示全部楼层
是的,没错,但目前阶段只支持温度传感器和窗帘门帘类,没多少设备可用。
laai
 楼主| 发表于 2018-3-3 09:31:59 | 显示全部楼层
明白了, Initial support has been added for temperature sensors and cover devices. Expect more devices to be added soon.
想试试怎么连接。
发表于 2018-3-6 17:43:02 | 显示全部楼层
这里 pincode 是自定义吗?还是用原来 homebridge 里的?
wbc 手机认证
发表于 2018-3-6 18:04:04 | 显示全部楼层
自定义的, 跟 homebridge 没关系。
GMT+8, 2026-1-7 06:39 , Processed in 0.303382 second(s), 13 queries , MemCached On.
