查看: 1471|回复: 4
[技术讨论] 分享个DIY气象站接入HA
发表于 2025-4-27 12:33:55 | 显示全部楼层 |阅读模式
esphome:
  friendly_name: Weather Station
esp8266:
  board: nodemcuv2
# 开启日志功能
#logger:
# 设置API
api:
time:
  - platform: homeassistant
    on_time:
      # 每天午夜清除累计降雨量
      - seconds: 0
        minutes: 0
        hours: 0
        then:
          - pulse_counter.set_total_pulses:
              value: 0  # 直接设置清零值
# 设置OTA
ota:
  - platform: esphome
    password: !secret ota_password
#设置WIFI
wifi:
  ssid: !secret wifi_ssid
  fast_connect: True  #不扫描直接连接,隐藏SSID必须启用
#  use_address: 192.168.88.57
  # 设置AP名称与密码
  ap:
    ssid: "WS"
    password: "12345678"
# 如果wifi连接失败,启动热点
captive_portal:
button:
  - platform: restart
  - platform: template
    name: "Reset Rainfall"
    on_press:
      then:
            value: 0  # 直接设置清零值
i2c:
  - id: bus_i2c
    sda: D1
    scl: D2
uart:
  tx_pin: D6
  rx_pin: D7
  baud_rate: 4800
  stop_bits: 1
modbus:
  send_wait_time: 200ms
modbus_controller:
  - id: wdmc
    address: 0x01                 ##风向传感器的地址码
    modbus_id: mod_bus
    command_throttle: 0ms
    setup_priority: -10
    update_interval: 1min
  - id: wsmc
    address: 0x02                 ##风速传感器的地址码
    modbus_id: mod_bus
    setup_priority: -10
  - id: rsmc
    address: 0x03                 ##B-RS-L30 光照度传感器
    modbus_id: mod_bus
    setup_priority: -10
  - id: htmc
    address: 0x04                 ## B-HT-RS30 温湿度传感器
    modbus_id: mod_bus
    setup_priority: -10
binary_sensor:
    device_class: MOISTURE
    lambda: |-
      if (id(rainy_state_voltage_sensor).state > 3.1) { //当ADC检测到电压低于3.1V返回false,否则返回true;
        return false; //返回false表示OFF
      } else {
        return true;  //返回true表示ON
# ESP8266仅内置1个10位ADC通道,该通道通过寄存器配置可选择测量外部电压(A0引脚)或系统电源电压(VCC)‌
#  - platform: adc
#    pin: VCC
#    name: "VCC Voltage"
  - platform: adc
    pin: A0
    name: "Rainy State Voltage"
#    internal: True       ##不在前端显示
    update_interval: 2s  # 采样间隔
    unit_of_measurement: "V"
    accuracy_decimals: 2  # 保留两位小数
    filters:
      - calibrate_linear:
          # 分压公式校准(关键配置)
          # ADC原始值 0.0(0V)对应实际 0V
          # ADC原始值 1.0(1V输入时)对应实际 5V
          - 0.0 -> 0.0
          - 1.0 -> 3.2  # (220K+100K)/100K = 3.2倍分压
      - sliding_window_moving_average:  # 噪声滤波
          window_size: 15
          send_every: 5
  - platform: wifi_signal
    update_interval: 10min
  - platform: uptime
  #  update_interval: 10min
  #  internal: true
    type: timestamp
  - platform: bmp280_i2c
    i2c_id: bus_i2c  # 明确指定使用的 I2C 总线
    address: 0x77
    update_interval: 60s
    temperature:
      name: "BMP280 temperature"
      oversampling: 16x
    pressure:
      name: "Air Pressure"
  - platform: modbus_controller
    modbus_controller_id: rsmc
    icon: mdi:brightness-5
    name: "Illuminance"            #B-RS-L30 光照度传感器
    address: 0x02                  #寄存器地址 2:光照度
    register_type: holding
    value_type: U_DWORD  # 32位无符号整型
    register_count: 2    # 读取连续2个寄存器(4字节)
    unit_of_measurement: "lx"
    accuracy_decimals: 0
    filters:
      - lambda: |-
          // 原始数据转换为浮点数并除以1000
          return (x / 1000.0f);
    modbus_controller_id: htmc
    icon: mdi:water-percent
    name: "Humidity"               #B-HT-RS30  温湿度传感器
    address: 0x00                  #寄存器地址 0:湿度
    #register_count: 2
    unit_of_measurement: "%"
    value_type: U_WORD
    accuracy_decimals: 1
    filters:
      - multiply: 0.1
    icon: mdi:home-thermometer-outline
    name: "Temperature"            #B-HT-RS30  温湿度传感器
    address: 0x01                  #寄存器地址 1:温度
    #register_count: 2
    unit_of_measurement: "°C"
    value_type: U_WORD
    filters:
      - multiply: 0.1
  - platform: absolute_humidity
    name: "Absolute Humidity"   ##绝对湿度
    temperature: HT_RS30_temperature
    humidity: HT_RS30_humidity
    name: "Dew Point"  ##露点计算
    lambda: |-
      return (243.5*(log(id(HT_RS30_humidity).state/100)+((17.67*id(HT_RS30_temperature).state)/
      (243.5+id(HT_RS30_temperature).state)))/(17.67-log(id(HT_RS30_humidity).state/100)-
      ((17.67*id(HT_RS30_temperature).state)/(243.5+id(HT_RS30_temperature).state))));
    unit_of_measurement: °C
    icon: 'mdi:thermometer-alert'
  - platform: modbus_controller   ##Modbus控制器平台;
    modbus_controller_id: wdmc    ##ModbusID;
    icon: mdi:sign-direction      ##实体图标;
    name: "Wind direction 360°"   ##实体名称 风向标;
    address: 0                    ##寄存器地址 0:风向(0-360°) 1:风向(0-15档);
    #register_count: 2
    unit_of_measurement: "°"      ##单位符号;
    value_type: U_WORD
    accuracy_decimals: 1          ##保留小数位数;
    filters:
      - multiply: 0.1             ##结果 x 0.1 ;
    modbus_controller_id: wsmc
    icon: mdi:wind-power
    name: "Wind speed"            #风速
    address: 0                    #寄存器地址 0:瞬时风速
    #register_count: 2
    unit_of_measurement: "m/s"
    value_type: U_WORD
    filters:
      - multiply: 0.1
##直接调用风速传感器值进行判断风力等级;
    name: "Wind scale"   #风力等级
    unit_of_measurement: "级风"
    value_type: U_WORD
    filters:
    lambda: |-
      if ( x <2 ) {id(wind_scale_text).publish_state("无风");return 0;}
      else if ( x <15 ){id(wind_scale_text).publish_state("软风");return 1;}
      else if ( x <33 ){id(wind_scale_text).publish_state("轻风");return 2;}
      else if ( x <54 ){id(wind_scale_text).publish_state("微风");return 3;}
      else if ( x <79 ){id(wind_scale_text).publish_state("和风");return 4;}
      else if ( x <107 ){id(wind_scale_text).publish_state("劲风");return 5;}
      else if ( x <138 ){id(wind_scale_text).publish_state("强风");return 6;}
      else if ( x <171 ){id(wind_scale_text).publish_state("疾风");return 7;}
      else if ( x <207 ){id(wind_scale_text).publish_state("大风");return 8;}
      else if ( x <244 ){id(wind_scale_text).publish_state("烈风");return 9;}
      else if ( x <284 ){id(wind_scale_text).publish_state("狂风");return 10;}
      else if ( x <326 ){id(wind_scale_text).publish_state("暴风");return 11;}
      else if ( x <369 ){id(wind_scale_text).publish_state("飓风");return 12;}
      else if ( x <414 ){id(wind_scale_text).publish_state("飓风");return 13;}
      else if ( x <461 ){id(wind_scale_text).publish_state("飓风");return 14;}
      else if ( x <509 ){id(wind_scale_text).publish_state("飓风");return 15;}
      else if ( x <560 ){id(wind_scale_text).publish_state("飓风");return 16;}
      else if ( x <612 ){id(wind_scale_text).publish_state("飓风");return 17;}
      else {return 99;}
# 脉冲计数传感器,IO14连接翻斗式雨量计,实测一个脉冲0.275mm
  - platform: pulse_counter
    name: "Rainfall Pulse" #降雨量脉冲计数
    icon: "mdi:weather-pouring"
    pin:
      number: GPIO14
      mode: INPUT_PULLUP  # 启用内部上拉电阻
      inverted: true      # 信号低电平有效(干簧管闭合触发)
    unit_of_measurement: "pps"
    internal_filter: 10ms  # 防抖动滤波(10毫秒)
    count_mode:
      rising_edge: DISABLE  # 仅下降沿触发(干簧管闭合)
      falling_edge: INCREMENT
    accuracy_decimals: 0   # 脉冲计数取整数
    total:
      unit_of_measurement: 'mm'
      accuracy_decimals: 2    # 降雨量显示精度(0.28mm)
      icon: "mdi:weather-rainy"
      filters:
        - multiply: 0.275  # 脉冲转降雨量系数
text_sensor:
  - platform: wifi_info
    ip_address:
      icon: mdi:ip
############ 风力输出中文名称 ############
    name: "Wind scale name"
############ 风向输出中文方位 ############
    bitmask: 0
    address: 1
    raw_encode: HEXBYTES
    name: "Wind direction 16Bit"
    filters:
      - map:
        - 0000 -> 北
        - 0001 -> 北东北
        - 0002 -> 东北
        - 0003 -> 东东北
        - 0004 -> 东
        - 0005 -> 东东南
        - 0006 -> 东南
        - 0007 -> 南东南
        - 0008 -> 南
        - 0009 -> 南西南
        - 000a -> 西南
        - 000b -> 西西南
        - 000c -> 西
        - 000d -> 西西北
        - 000e -> 西北
        - 000f -> 北西北
参与人数 1金钱 +10 收起 理由
kaka0992 + 10 感谢楼主分享!
发表于 2025-4-27 14:08:36 | 显示全部楼层
产品图有没有。看看你放着在哪里的,我想不到合适的位置放,阳台窗户外?问题是供电麻烦
 楼主| 发表于 2025-4-27 17:46:46 | 显示全部楼层
bugensui 发表于 2025-4-27 14:08
产品图有没有。看看你放着在哪里的,我想不到合适的位置放,阳台窗户外?问题是供电麻烦 ...
这里有,https://bbs.hassbian.com/thread-24797-1-1.html
发表于 2025-4-27 22:11:39 | 显示全部楼层
硬件能详细说下就完美了
发表于 2025-4-29 13:01:46 | 显示全部楼层
我最近也在搞,刚接好风速和雨雪传感器
GMT+8, 2025-10-19 15:19 , Processed in 0.099440 second(s), 10 queries , MemCached On.
