楼主: kenlau
[进阶教程] Mikrotik路由的device_tracker[实测速度比原生的快]
发表于 2018-4-8 10:25:43 来自手机 | 显示全部楼层
Jones 发表于 2018-3-2 16:19
牛了牛了!只是没听说过这路由呢,感觉很高大上的样子
Ros系统,路由系统之王。ros的设置一本书都写不完
发表于 2018-4-12 17:43:44 | 显示全部楼层
这个要收藏 我用mikrotik
发表于 2018-4-19 15:39:54 | 显示全部楼层
04-19 15:28:53 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform mikrotik
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/__init__.py", line 181, in async_setup_platform
    platform.get_scanner, hass, {DOMAIN: p_config})
  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/mikrotik.py", line 37, in get_scanner
    scanner = MikrotikDeviceScanner(config[DOMAIN])
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/mikrotik.py", line 58, in __init__
    from routeros_api import RouterOsApiPool
ImportError: No module named 'routeros_api'
发表于 2018-4-19 15:58:37 | 显示全部楼层
插件内容我直接替换成lz你的了,配置是下面这个,就报错了
device_tracker:
  - platform: mikrotik
    host: 192.168.1.2
    username: admin
    password: admin
    interface: LAN
    address_range: 192.168.1.1-192.168.1.254
    interval_seconds: 10
    consider_home: 20
    new_device_defaults:
      track_new_devices : true
      hide_if_away: false
发表于 2018-4-19 16:02:55 | 显示全部楼层
device_tracker:
    host: 192.168.1.2
    username: admin
    password: admin
    interface: LAN
    consider_home: 20
      hide_if_away: false
 楼主| 发表于 2018-4-19 20:17:37 | 显示全部楼层
[code]device_tracker: ...
device_tracker:
  - platform: mikrotik_netwatch
    host: 192.168.1.2
    username: admin
    password: admin
    interface: LAN
    consider_home: 20
      hide_if_away: false
官方自带的是mikrotik,把脚本文件和名字改一下吧
发表于 2018-4-19 21:46:02 | 显示全部楼层
kenlau 发表于 2018-4-19 20:17
device_tracker:
    host: 192.168.1.2
因为没办法把你的脚本上传到该文件夹内,于是我把脚本里面的内容替换掉了,其实就是你的脚本
发表于 2018-4-19 22:53:37 | 显示全部楼层
重新上传了个文件,并改了名字,好像真的不一定了
-04-19 22:58:47 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.5/asyncio/tasks.py", line 241, in _step
    result = coro.throw(exc)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/__init__.py", line 744, in async_device_tracker_scan
    host_name = yield from scanner.async_get_device_name(mac)
    future.result()
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/mikrotik_netwatch.py", line 110, in get_device_name
    str(self._name_from_leases(mac)))
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/mikrotik_netwatch.py", line 123, in _name_from_leases
    lease = next((rec for rec in self.leases if rec['mac-address'] == mac), None)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/mikrotik_netwatch.py", line 123, in <genexpr>
KeyError: 'mac-address'
2018-04-19 22:58:58 ERROR (Thread-14) [homeassistant.components.device_tracker.mikrotik_netwatch] Can't define 192.168.1.208 IP mac address, neither ip-scan, nor DHCP Server - Leases has this info.
2018-04-19 22:58:58 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    future.result()
2018-04-19 22:59:00 ERROR (Thread-21) [homeassistant.components.light.yeelight] Failed to connect to bulb 192.168.0.190, yeelight_rgb_34ce0084e2ce: A socket error occurred when sending the command.
2018-04-19 22:59:09 ERROR (Thread-20) [homeassistant.components.device_tracker.mikrotik_netwatch] Can't define 192.168.1.208 IP mac address, neither ip-scan, nor DHCP Server - Leases has this info.
2018-04-19 22:59:09 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    future.result()
2018-04-19 22:59:20 ERROR (Thread-8) [homeassistant.components.device_tracker.mikrotik_netwatch] Can't define 192.168.1.208 IP mac address, neither ip-scan, nor DHCP Server - Leases has this info.
2018-04-19 22:59:20 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    future.result()
2018-04-19 22:59:31 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    future.result()
2018-04-19 22:59:42 ERROR (Thread-18) [homeassistant.components.device_tracker.mikrotik_netwatch] Can't define 192.168.1.208 IP mac address, neither ip-scan, nor DHCP Server - Leases has this info.
2018-04-19 22:59:42 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    future.result()
2018-04-19 22:59:53 ERROR (Thread-9) [homeassistant.components.device_tracker.mikrotik_netwatch] Can't define 192.168.1.208 IP mac address, neither ip-scan, nor DHCP Server - Leases has this info.
2018-04-19 22:59:53 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    future.result()
2018-04-19 23:00:04 ERROR (Thread-20) [homeassistant.components.device_tracker.mikrotik_netwatch] Can't define 192.168.1.208 IP mac address, neither ip-scan, nor DHCP Server - Leases has this info.
2018-04-19 23:00:04 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    future.result()
2018-04-19 23:00:15 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    future.result()
2018-04-19 23:00:25 ERROR (Thread-9) [homeassistant.components.device_tracker.mikrotik_netwatch] Can't define 192.168.1.208 IP mac address, neither ip-scan, nor DHCP Server - Leases has this info.
2018-04-19 23:00:25 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    future.result()
发表于 2018-4-19 23:42:11 | 显示全部楼层
单测一个ip,也报错。。。
发表于 2018-12-25 00:13:56 | 显示全部楼层
报错哎
2018-12-25 00:11:52 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform mikrotik_netwatch
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 176, in async_setup_platform
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/config/custom_components/device_tracker/mikrotik_netwatch.py", line 37, in get_scanner
  File "/config/custom_components/device_tracker/mikrotik_netwatch.py", line 58, in __init__
ModuleNotFoundError: No module named 'routeros_api'
GMT+8, 2025-12-15 23:37 , Processed in 0.547026 second(s), 15 queries , MemCached On.
