查看: 818|回复: 0
[已解决] 数据库报错
发表于 2025-3-27 17:20:57 | 显示全部楼层 |阅读模式
已经找到原因,请版主删帖。谢谢!----------------------------------------------------------
有没有人遇到这种情况
数据库一直在报超过限制。但是不知道原因。重启过几次还是这样。
2025-03-27 16:54:03.228 WARNING (Recorder) [homeassistant.components.recorder.db_schema] Event data for call_service exceed maximum size of 32768 bytes. This can cause database performance issues; Event data will not be stored
2025-03-27 16:54:03.229 WARNING (Recorder) [homeassistant.components.recorder.db_schema] Event data for logbook_entry exceed maximum size of 32768 bytes. This can cause database performance issues; Event data will not be stored
2025-03-27 16:54:03.252 WARNING (Recorder) [homeassistant.components.recorder.db_schema] Event data for call_service exceed maximum size of 32768 bytes. This can cause database performance issues; Event data will not be stored
2025-03-27 16:54:03.252 WARNING (Recorder) [homeassistant.components.recorder.db_schema] Event data for logbook_entry exceed maximum size of 32768 bytes. This can cause database performance issues; Event data will not be stored
2025-03-27 17:04:03.242 WARNING (Recorder) [homeassistant.components.recorder.db_schema] Event data for call_service exceed maximum size of 32768 bytes. This can cause database performance issues; Event data will not be stored
2025-03-27 17:04:03.243 WARNING (Recorder) [homeassistant.components.recorder.db_schema] Event data for logbook_entry exceed maximum size of 32768 bytes. This can cause database performance issues; Event data will not be stored
2025-03-27 17:04:03.265 WARNING (Recorder) [homeassistant.components.recorder.db_schema] Event data for call_service exceed maximum size of 32768 bytes. This can cause database performance issues; Event data will not be stored
2025-03-27 17:04:03.266 WARNING (Recorder) [homeassistant.components.recorder.db_schema] Event data for logbook_entry exceed maximum size of 32768 bytes. This can cause database performance issues; Event data will not be stored
2025-03-27 17:14:03.278 WARNING (Recorder) [homeassistant.components.recorder.db_schema] Event data for call_service exceed maximum size of 32768 bytes. This can cause database performance issues; Event data will not be stored
2025-03-27 17:14:03.279 WARNING (Recorder) [homeassistant.components.recorder.db_schema] Event data for logbook_entry exceed maximum size of 32768 bytes. This can cause database performance issues; Event data will not be stored
2025-03-27 17:14:03.286 WARNING (Recorder) [homeassistant.components.recorder.db_schema] Event data for call_service exceed maximum size of 32768 bytes. This can cause database performance issues; Event data will not be stored
2025-03-27 17:14:03.286 WARNING (Recorder) [homeassistant.components.recorder.db_schema] Event data for logbook_entry exceed maximum size of 32768 bytes. This can cause database performance issues; Event data will not be stored
GMT+8, 2025-12-17 23:53 , Processed in 0.986606 second(s), 5 queries , MemCached On.
